查看: 1954|回復(fù): 1
一款基于錦銳單片機遙控接收1527碼的軟解碼程序
ID:66086 發(fā)表于 2024-3-25 16:08 | 顯示全部樓層 |閱讀模式
  1. #ifndef _MAIN_C_
  2. #define _MAIN_C_
  3. /*********************************************************************************************************************/
  4. #include "ca51f_config.h"
  5. #include "includes\ca51f3sfr.h"
  6. #include "includes\ca51f3xsfr.h"
  7. #include "includes\gpiodef_f3.h"
  8. #include "Library\includes\delay.h"
  9. #include "Library\includes\uart.h"
  10. #include "Library\includes\system_clock.h"
  11. #include "Library\Includes\rtc.h"
  12. #include "Library\Includes\pwm.h"
  13. #include "includes\system.h"
  14. #include "Library\includes\adc.h"
  15. #include "Library\includes\wdt.h"
  16. /*********************************************************************************************************************/
  17. #include "TS_Lib\Includes\ts_configuration.h"
  18. #include "TS_Lib\Includes\ts_def.h"
  19. #include "TS_Lib\Includes\ts_api.h"
  20. #include "TS_Lib\Includes\ts_service.h"
  21. /*********************************************************************************************************************/
  22. #include "tm1628.h"
  23. #include "time.h"
  24. //#include "74hc595.h"
  25. unsigned char read_inner_trim(void)
  26. {
  27.         unsigned char value;
  28.         FSCMD = 0x80;
  29.         PTSH = 0x00;
  30.         PTSL = 0x24;
  31.         FSCMD = 0x81;
  32.         value = FSDAT;
  33.         FSCMD = 0;
  34.         return value;
  35. }
  36. void SystemInit(void)
  37. {
  38. #ifdef LVD_RST_ENABLE
  39.         LVDCON = 0xE1;        //設(shè)置LVD復(fù)位電壓為2V
  40. #endif
  41. #if (SYSCLK_SRC == PLL)
  42.         Sys_Clk_Set_PLL(PLL_Multiple);
  43. #endif
  44. #ifdef UART0_EN
  45.         Uart0_Initial(UART0_BAUTRATE);
  46. #endif
  47. #ifdef UART1_EN
  48.         Uart1_Initial(UART1_BAUTRATE);
  49. #endif
  50. #if (RTC_CLK_SELECT == IRCL)
  51. //看門狗時鐘源為IRCL
  52.         CKCON |= ILCKE;        //使能IRCL
  53.         WDCON  = WDTS(WDTS_IRCL) | WDRE(WDRE_reset);           //設(shè)置看門狗時鐘源為ILCKE,模式為復(fù)位模式
  54. #elif (RTC_CLK_SELECT == XOSCL)
  55.         CKCON |= XLCKE;
  56.         while(!(CKCON & XLSTA));
  57.         WDCON  = WDTS(WDTS_XOSCL) | WDRE(WDRE_reset);   //設(shè)置看門狗時鐘源為XOSCL,模式為復(fù)位模式
  58. #endif
  59.         WDVTHH = 0;        //看門狗復(fù)位閾值高八位設(shè)置 當前值為5s
  60.         WDVTHL = 75;        //看門狗復(fù)位閾值低八位設(shè)置
  61.         WDFLG = 0xA5;
  62.
  63.
  64.         ADCFGH = (ADCFGH&0xC0) | VTRIM(read_inner_trim());        //加載ADC內(nèi)部基準校準值
  65. }
  66. void main(void)
  67. {
  68.         unsigned char i;
  69.         SystemInit();
  70.         EA = 1;
  71.         TS_init();
  72.         Timer1_mode2_Init();
  73. //        Uart0_PutChar(0xab);
  74.   user_EEprom_init();
  75.         Read_Buff();
  76.         Out0=0;
  77.         Out1=0;
  78.         Out2=0;
  79.         Out3=0;
  80.         while(1)
  81.         {
  82.                 TS_Action();
  83.                 Study_Key();
  84.                 Study_RF();
  85.                 if(rf_Ok&&(!Study_flag))                 //非學(xué)習(xí)狀態(tài)
  86.                 {
  87.                         rf_Ok = 0;
  88.                         KeyTo1527();                                 //轉(zhuǎn)換數(shù)據(jù)
  89.                         for(i=0;i<KEY_num;i++)
  90.                         {
  91.                                 if((RfBuff[0]==key_number[i*3+1])&&(RfBuff[1]==key_number[i*3+2])&&(RfBuff[2]==key_number[i*3+3]))
  92.                                 {
  93. //                                        VT = 1;
  94.                                         Hold_Time = 0;
  95.                                         if(!LM)        //點動
  96.                                         {
  97.                                                 if((RfBuff[3]&0x10) == 0x10) Out0 = 0;
  98.                                                 if((RfBuff[3]&0x20) == 0x20) Out1 = 0;
  99.                                                 if((RfBuff[3]&0x40) == 0x40) Out2 = 0;
  100.                                                 if((RfBuff[3]&0x80) == 0x80) Out3 = 0;
  101.                                                 Uart0_PutChar(RfBuff[3]);
  102.                                         }
  103.                                         else if(LM&&!Decod_Ok)        //自鎖
  104.                                         {
  105.                                                 if((RfBuff[3]&0x10) == 0x10) Out0 = !Out0;
  106.                                                 if((RfBuff[3]&0x20) == 0x20) Out1 = !Out1;
  107.                                                 if((RfBuff[3]&0x40) == 0x40) Out2 = !Out2;
  108.                                                 if((RfBuff[3]&0x80) == 0x80) Out3 = !Out3;
  109. //            Uart0_PutChar(RfBuff[3]);
  110.                                         }
  111.                                         Decod_Ok = 1;
  112.                                         break;
  113.                                 }
  114.                         }
  115.                 }
  116.         }
  117.
  118. }
  119. #endif
原理圖: 無
仿真: 無
代碼: CA51F3_1527解碼程序.7z (97.79 KB, 下載次數(shù): 18)
admin + 50 共享資料的黑幣獎勵!
ID:712493 發(fā)表于 2024-3-25 21:42 | 顯示全部樓層
樓主,調(diào)試命令放在那個文件?
