查看: 1281|回復(fù): 1
關(guān)于4x4矩陣鍵盤單片機(jī)代碼修改,小白求助
ID:993578 發(fā)表于 2024-4-3 15:09 | 顯示全部樓層 |閱讀模式
問(wèn)題:圖一是我仿真使用的矩陣鍵盤,仿真正常使用。在某一個(gè)寶買了一個(gè)圖二的矩陣鍵盤,行列原理圖是反著的請(qǐng)問(wèn)我該如何修改我的單片機(jī)代碼
  1. #include "button.h"
  2. #include "stm32f10x.h"
  3. #include "delay.h"
  4. extern u8 pass_word_state;        //輸密碼時(shí)判斷是輸入了第幾位
  5. u8 Key_Data=0;  //按鍵按下的數(shù)據(jù)
  6. u8 Key_flag=0;  //按鍵按下標(biāo)志位,區(qū)分按鍵按下一次的
  7. void KEY_Init(void)
  8. {
  9.         GPIO_InitTypeDef GPIO_InitStructure;
  10.
  11.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC, ENABLE);//開(kāi)啟時(shí)鐘
  12.
  13.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  14.         GPIO_PinRemapConfig(GPIO_Remap_SWJ_Disable, ENABLE); //改變指定管腳的映射完全禁用(JTAG+SW-DP)
  15.         GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//改變指定管腳的映射,JTAG-DP 禁用 + SW-DP 使能
  16.
  17.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;        //LED
  18.         GPIO_InitStructure.GPIO_Pin =GPIO_Pin_1;
  19.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  20.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  21.         LED0 = 0;
  22.
  23.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;        //蜂鳴器(beep) 低電平觸發(fā)
  24.         GPIO_InitStructure.GPIO_Pin =GPIO_Pin_0;
  25.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  26.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  27.         BEEP=1;
  28.
  29.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;        //繼電器(relay) 高電平觸發(fā)
  30.         GPIO_InitStructure.GPIO_Pin =GPIO_Pin_13;
  31.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  32.         GPIO_Init(GPIOC, &GPIO_InitStructure);
  33.         RELAY=0;
  34. }
  35. //按鍵賦值,這里是將八個(gè)按鍵拼接成一組51單片機(jī)里面的Io,目前測(cè)試可行
  36. void Key_assignment(unsigned char z)
  37. {
  38.         Key_Data=0x00;   //清零
  39.         if(z==0)
  40.         {
  41.                 key_LowOutPutConfig();
  42.                 key5_1;  key6_1;  key7_1;  key8_1;   //使用的方法是反轉(zhuǎn)法
  43.
  44.                 delay_us(500);  //短延時(shí)一下
  45.
  46.                 if(key1==1) Key_Data=Key_Data|0x8F;
  47.                 else if(key2==1) Key_Data=Key_Data|0x4F;
  48.                 else if(key3==1) Key_Data=Key_Data|0x2F;
  49.                 else if(key4==1) Key_Data=Key_Data|0x1F;
  50.                 else Key_Data=Key_Data|0x0F;
  51.         }
  52.         else
  53.         {
  54.                 key_HighOutPutConfig();
  55.                 key1_1;  key2_1;  key3_1;  key4_1;//使用的方法是反轉(zhuǎn)法
  56.                 delay_us(500);  //短延時(shí)一下
  57.
  58.                 if(key5==1) Key_Data=Key_Data|0xF8;
  59.                 else if(key6==1) Key_Data=Key_Data|0xF4;
  60.                 else if(key7==1) Key_Data=Key_Data|0xF2;
  61.                 else if(key8==1) Key_Data=Key_Data|0xF1;
  62.                 else Key_Data=Key_Data|0xF0;
  63.         }
  64. }
  65. u8 Key_Scan() //按鍵掃描函數(shù)
  66. {
  67.                  u8 num=16;  //這里一定要先賦個(gè)用不到的值
  68.      u8 Key_x;
  69.             Key_assignment(1); //狀態(tài) 0 ,此時(shí)按鍵沒(méi)有按下的話是 0x0f
  70.            delay_us(100);   //短延時(shí)
  71.            if(Key_Data!=0xF0) //只要是按鍵按下,就會(huì)使得 Key_Data!=0x0f
  72.                  {
  73.                                 Key_flag=1; //有按鍵按下,標(biāo)志位置1
  74.                           Key_x=Key_Data;//將此時(shí)的鍵值賦值
  75.                                  Key_assignment(0); //切換狀態(tài) 1
  76.                                  delay_us(100);  //短延時(shí)一下
  77.                                  Key_Data=Key_Data&Key_x;  //兩個(gè)數(shù)據(jù)按位與,就會(huì)產(chǎn)生獨(dú)一無(wú)二的數(shù)據(jù)
  78.
  79. //當(dāng)前情況下的鍵值        ,十六進(jìn)制數(shù)據(jù)
  80. //   88 48 28 18    →            7          8          9           12(add)
  81. //   84 44 24 14    →            4          5          6           13(sub)
  82. //   82 42 22 12    →            1          2          3           14(enter)
  83. //         81 41 21 11           →    10(xx) 0   11(yy) 15(back)
  84.                                   switch(Key_Data)
  85.                                    {
  86.                                      case 0x11 : num=back;   break;
  87.                                      case 0x12 : num=enter;  break;
  88.                                      case 0x14 : num=sub;   break;
  89.                                      case 0x18 : num=add;  break;
  90.
  91.                                      case 0x21 : num=yy;   break;
  92.                                      case 0x22 : num=3;   break;
  93.                                      case 0x24 : num=6;   break;
  94.                                      case 0x28 : num=9;  break;
  95.
  96.                                      case 0x41 : num=0;   break;
  97.                                      case 0x42 : num=2;   break;
  98.                                      case 0x44 : num=5;   break;
  99.                                      case 0x48 : num=8;  break;
  100.
  101.                                      case 0x81 : num=xx;  break;
  102.                                      case 0x82 : num=1;   break;
  103.                                      case 0x84 : num=4;  break;
  104.                                      case 0x88 : num=7;  break;
  105.                                    }
  106.                                 Key_assignment(0);
  107.                                 while(Key_Data!=0x0f)//松手檢測(cè)
  108.                                 {
  109.                                 Key_assignment(0);
  110.                                 }
  111.            }
  112.          return num;
  113. }
  114. void key_LowOutPutConfig(void)
  115. {
  116.         GPIO_InitTypeDef GPIO_InitStructure;
  117.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;        //下拉輸入
  118.         GPIO_InitStructure.GPIO_Pin =C1_pin;
  119.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  120.         GPIO_Init(C1_port, &GPIO_InitStructure);
  121.
  122.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;        //下拉輸入
  123.         GPIO_InitStructure.GPIO_Pin =C2_pin;
  124.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  125.         GPIO_Init(C2_port, &GPIO_InitStructure);
  126.
  127.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;        //下拉輸入
  128.         GPIO_InitStructure.GPIO_Pin =C3_pin;
  129.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  130.         GPIO_Init(C3_port, &GPIO_InitStructure);
  131.
  132.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;        //下拉輸入
  133.         GPIO_InitStructure.GPIO_Pin =C4_pin;
  134.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  135.         GPIO_Init(C4_port, &GPIO_InitStructure);
  136.
  137.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;        //推挽輸出
  138.         GPIO_InitStructure.GPIO_Pin =R1_pin;
  139.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  140.         GPIO_Init(R1_port, &GPIO_InitStructure);
  141.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;        //推挽輸出
  142.         GPIO_InitStructure.GPIO_Pin =R2_pin;
  143.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  144.         GPIO_Init(R2_port, &GPIO_InitStructure);
  145.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;        //推挽輸出
  146.         GPIO_InitStructure.GPIO_Pin =R3_pin;
  147.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  148.         GPIO_Init(R3_port, &GPIO_InitStructure);
  149.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;        //推挽輸出
  150.         GPIO_InitStructure.GPIO_Pin =R4_pin;
  151.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  152.         GPIO_Init(R4_port, &GPIO_InitStructure);
  153. }
  154. void key_HighOutPutConfig(void)
  155. {
  156.         GPIO_InitTypeDef GPIO_InitStructure;
  157.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;        //推挽輸出
  158.         GPIO_InitStructure.GPIO_Pin =C1_pin;
  159.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  160.         GPIO_Init(C1_port, &GPIO_InitStructure);
  161.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;        //推挽輸出
  162.         GPIO_InitStructure.GPIO_Pin =C2_pin;
  163.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  164.         GPIO_Init(C2_port, &GPIO_InitStructure);
  165.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;        //推挽輸出
  166.         GPIO_InitStructure.GPIO_Pin =C3_pin;
  167.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  168.         GPIO_Init(C3_port, &GPIO_InitStructure);
  169.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;        //推挽輸出
  170.         GPIO_InitStructure.GPIO_Pin =C4_pin;
  171.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  172.         GPIO_Init(C4_port, &GPIO_InitStructure);
  173.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;        //下拉輸入
  174.         GPIO_InitStructure.GPIO_Pin =R1_pin;
  175.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  176.         GPIO_Init(R1_port, &GPIO_InitStructure);
  177.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;        //下拉輸入
  178.         GPIO_InitStructure.GPIO_Pin =R2_pin;
  179.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  180.         GPIO_Init(R2_port, &GPIO_InitStructure);
  181.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;        //下拉輸入
  182.         GPIO_InitStructure.GPIO_Pin =R3_pin;
  183.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  184.         GPIO_Init(R3_port, &GPIO_InitStructure);
  185.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;        //下拉輸入
  186.         GPIO_InitStructure.GPIO_Pin =R4_pin;
  187.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  188.         GPIO_Init(R4_port, &GPIO_InitStructure);
  189. }
這個(gè)是我仿真使用的矩陣鍵盤
這個(gè)是我仿真使用的矩陣鍵盤
ID:712097 發(fā)表于 2024-4-7 17:08 | 顯示全部樓層
感覺(jué)一模一樣啊,不用改。
