前言
在學習stm32中....
發(fā)現(xiàn)此站一篇文章 下載文件需要黑幣 所以把做過像樣的程序發(fā)上來 希望能幫到有需要的人
硬件連接
GND -- GND
VCC -- 3.3v
SCL -- B8
SDA -- B9
驅(qū)動代碼
OLED.h頭文件
- #ifndef __OLED_H
- #define __OLED_H
- void OLED_Init(void);
- void OLED_Clear(void);
- void OLED_ShowChar(uint8_t Line, uint8_t Column, char Char);
- void OLED_ShowString(uint8_t Line, uint8_t Column, char *String);
- void OLED_ShowNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length);
- void OLED_ShowSignedNum(uint8_t Line, uint8_t Column, int32_t Number, uint8_t Length);
- void OLED_ShowHexNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length);
- void OLED_ShowBinNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length);
- #endif
復制代碼 OLED.c
- #include "stm32f10x.h"
- #include "OLED_Font.h"
- /*引腳配置*/
- #define OLED_W_SCL(x) GPIO_WriteBit(GPIOB, GPIO_Pin_8, (BitAction)(x))
- #define OLED_W_SDA(x) GPIO_WriteBit(GPIOB, GPIO_Pin_9, (BitAction)(x))
- /*引腳初始化*/
- void OLED_I2C_Init(void)
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
- GPIO_InitTypeDef GPIO_InitStructure;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
- OLED_W_SCL(1);
- OLED_W_SDA(1);
- * @brief I2C開始
- * @param 無
- * @retval 無
- void OLED_I2C_Start(void)
- OLED_W_SDA(1);
- OLED_W_SCL(1);
- OLED_W_SDA(0);
- OLED_W_SCL(0);
- * @brief I2C停止
- * @param 無
- * @retval 無
- void OLED_I2C_Stop(void)
- OLED_W_SDA(0);
- OLED_W_SCL(1);
- OLED_W_SDA(1);
- * @brief I2C發(fā)送一個字節(jié)
- * @param Byte 要發(fā)送的一個字節(jié)
- * @retval 無
- void OLED_I2C_SendByte(uint8_t Byte)
- uint8_t i;
- for (i = 0; i < 8; i++)
- OLED_W_SDA(Byte & (0x80 >> i));
- OLED_W_SCL(1);
- OLED_W_SCL(0);
- OLED_W_SCL(1); //額外的一個時鐘,不處理應答信號
- OLED_W_SCL(0);
- * @brief OLED寫命令
- * @param Command 要寫入的命令
- * @retval 無
- void OLED_WriteCommand(uint8_t Command)
- OLED_I2C_Start();
- OLED_I2C_SendByte(0x78); //從機地址
- OLED_I2C_SendByte(0x00); //寫命令
- OLED_I2C_SendByte(Command);
- OLED_I2C_Stop();
- * @brief OLED寫數(shù)據(jù)
- * @param Data 要寫入的數(shù)據(jù)
- * @retval 無
- void OLED_WriteData(uint8_t Data)
- OLED_I2C_Start();
- OLED_I2C_SendByte(0x40); //寫數(shù)據(jù)
- OLED_I2C_SendByte(Data);
- OLED_I2C_Stop();
- * @brief OLED設置光標位置
- * @param Y 以左上角為原點,向下方向的坐標,范圍:0~7
- * @param X 以左上角為原點,向右方向的坐標,范圍:0~127
- * @retval 無
- void OLED_SetCursor(uint8_t Y, uint8_t X)
- OLED_WriteCommand(0xB0 | Y); //設置Y位置
- OLED_WriteCommand(0x10 | ((X & 0xF0) >> 4)); //設置X位置高4位
- OLED_WriteCommand(0x00 | (X & 0x0F)); //設置X位置低4位
- * @brief OLED清屏
- * @param 無
- * @retval 無
- uint8_t i, j;
- for (j = 0; j < 8; j++)
- OLED_SetCursor(j, 0);
- for(i = 0; i < 128; i++)
- OLED_WriteData(0x00);
- * @brief OLED顯示一個字符
- * @param Line 行位置,范圍:1~4
- * @param Column 列位置,范圍:1~16
- * @param Char 要顯示的一個字符,范圍:ASCII可見字符
- * @retval 無
- uint8_t i;
- OLED_SetCursor((Line - 1) * 2, (Column - 1) * 8); //設置光標位置在上半部分
- OLED_WriteData(OLED_F8x16[Char - ' '][i]); //顯示上半部分內(nèi)容
- OLED_SetCursor((Line - 1) * 2 + 1, (Column - 1) * 8); //設置光標位置在下半部分
- OLED_WriteData(OLED_F8x16[Char - ' '][i + 8]); //顯示下半部分內(nèi)容
- * @brief OLED顯示字符串
- * @param Line 起始行位置,范圍:1~4
- * @param Column 起始列位置,范圍:1~16
- * @param String 要顯示的字符串,范圍:ASCII可見字符
- * @retval 無
- uint8_t i;
- for (i = 0; String[i] != '\0'; i++)
- OLED_ShowChar(Line, Column + i, String[i]);
- * @brief OLED次方函數(shù)
- * @retval 返回值等于X的Y次方
- uint32_t OLED_Pow(uint32_t X, uint32_t Y)
- uint32_t Result = 1;
- while (Y--)
- Result *= X;
- return Result;
- * @brief OLED顯示數(shù)字(十進制,正數(shù))
- * @param Number 要顯示的數(shù)字,范圍:0~4294967295
- * @param Length 要顯示數(shù)字的長度,范圍:1~10
- * @retval 無
- uint8_t i;
- for (i = 0; i < Length; i++)
- OLED_ShowChar(Line, Column + i, Number / OLED_Pow(10, Length - i - 1) % 10 + '0');
- * @brief OLED顯示數(shù)字(十進制,帶符號數(shù))
- * @param Number 要顯示的數(shù)字,范圍:-2147483648~2147483647
- * @retval 無
- uint8_t i;
- uint32_t Number1;
- if (Number >= 0)
- OLED_ShowChar(Line, Column, '+');
- Number1 = Number;
- else
- OLED_ShowChar(Line, Column, '-');
- Number1 = -Number;
- OLED_ShowChar(Line, Column + i + 1, Number1 / OLED_Pow(10, Length - i - 1) % 10 + '0');
- * @brief OLED顯示數(shù)字(十六進制,正數(shù))
- * @param Number 要顯示的數(shù)字,范圍:0~0xFFFFFFFF
- * @param Length 要顯示數(shù)字的長度,范圍:1~8
- * @retval 無
- uint8_t i, SingleNumber;
- SingleNumber = Number / OLED_Pow(16, Length - i - 1) % 16;
- if (SingleNumber < 10)
- OLED_ShowChar(Line, Column + i, SingleNumber + '0');
- else
- OLED_ShowChar(Line, Column + i, SingleNumber - 10 + 'A');
- * @brief OLED顯示數(shù)字(二進制,正數(shù))
- * @param Number 要顯示的數(shù)字,范圍:0~1111 1111 1111 1111
- * @param Length 要顯示數(shù)字的長度,范圍:1~16
- * @retval 無
- uint8_t i;
- OLED_ShowChar(Line, Column + i, Number / OLED_Pow(2, Length - i - 1) % 2 + '0');
- * @brief OLED初始化
- * @param 無
- * @retval 無
- uint32_t i, j;
- for (i = 0; i < 1000; i++) //上電延時
- for (j = 0; j < 1000; j++);
- OLED_I2C_Init(); //端口初始化
- OLED_WriteCommand(0xAE); //關閉顯示
- OLED_WriteCommand(0xD5); //設置顯示時鐘分頻比/振蕩器頻率
- OLED_WriteCommand(0x80);
- OLED_WriteCommand(0xA8); //設置多路復用率
- OLED_WriteCommand(0x3F);
- OLED_WriteCommand(0xD3); //設置顯示偏移
- OLED_WriteCommand(0x00);
- OLED_WriteCommand(0x40); //設置顯示開始行
- OLED_WriteCommand(0xA1); //設置左右方向,0xA1正常 0xA0左右反置
- OLED_WriteCommand(0xC8); //設置上下方向,0xC8正常 0xC0上下反置
- OLED_WriteCommand(0xDA); //設置COM引腳硬件配置
- OLED_WriteCommand(0x12);
- OLED_WriteCommand(0x81); //設置對比度控制
- OLED_WriteCommand(0xCF);
- OLED_WriteCommand(0xD9); //設置預充電周期
- OLED_WriteCommand(0xF1);
- OLED_WriteCommand(0xDB); //設置VCOMH取消選擇級別
- OLED_WriteCommand(0x30);
- OLED_WriteCommand(0xA4); //設置整個顯示打開/關閉
- OLED_WriteCommand(0xA6); //設置正常/倒轉顯示
- OLED_WriteCommand(0x8D); //設置充電泵
- OLED_WriteCommand(0x14);
- OLED_WriteCommand(0xAF); //開啟顯示
- OLED_Clear(); //OLED清屏
復制代碼
主函數(shù)main.c
- #include "OLED.h"
- #include "max30102.h"
- // 延時函數(shù)
- void delay_ms(uint32_t ms) {
- uint32_t i;
- for (i = 0; i < ms * 1000; i++) {
- __NOP();
- // LED 綠燈
- void LED_Init() {
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
- GPIO_InitTypeDef GPIO_InitStruct;
- GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStruct.GPIO_Pin = GPIO_Pin_13;
- GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOC, &GPIO_InitStruct);
- void countTime() {
- // 倒計時邏輯
- for (int i = 0; i <= 10; i++) {
- OLED_ShowNum(4, 7, i, 2); // 更新倒計時顯示
- OLED_ShowString(4, 9, "s");
- delay_ms(7000);
- //if(i == 0) {
- // i = 60;
- // 倒計時結束,顯示結束信息
- OLED_Clear();
- //OLED_ShowString(2, 1, "Time's up!");
- OLED_ShowString(1, 2, "Case: Max30102");
- OLED_ShowString(2, 4, "2024-04-07");
- OLED_ShowString(3, 1, "HR:");
- OLED_ShowString(4, 1, "SpO2:");
- // OLED屏顯示內(nèi)容
- void showOLED() {
- OLED_Init();
- OLED_ShowString(3, 1, "Put your finger");
- if(MAX30102_INIT_FAILED) {
- countTime();
- } else {
- OLED_ShowString(4, 4, "No finger");
- int main(void) {
- //LED_Init();
- showOLED();
復制代碼
效果
2024-4-7 22:38 上傳
