查看: 923|回復(fù): 0
紅外對
ID:918728 發(fā)表于 2024-4-12 11:11 | 顯示全部樓層 |閱讀模式
#include<reg52.h> //包含頭文件,一般情況不需要改動,頭文件包含特殊功能寄存器的定義
#include "HX711.h"
sbit KEY_ADD1=P1^0;  //定義紅外輸入端口
sbit KEY_ADD2=P1^1;
sbit KEY_ADD3=P1^2;
sbit KEY_ADD4=P1^3;
sbit KEY_ADD5=P1^4;
sbit LED1=P2^0;  //定義led輸出端口
sbit LED2=P2^1;  //定義led輸出端口
sbit LED3=P2^2;  //定義led輸出端口
sbit LED4=P2^3;  //定義led輸出端口
sbit LED5=P2^4;  //定義led輸出端口
sbit Buzzer = P3^7;
bit num1=0;
bit num2=0;
bit num3=0;
bit num4=0;
bit num5=0;
long Weight_Shiwu = 0;
unsigned int GapValue;
unsigned char Tx_Buf[12];
unsigned char Rx_buf[1];
uS延時函數(shù),含有輸入?yún)?shù) unsigned char t,無返回值
unsigned char 是定義無符號字符變量,其值的范圍是
0~255 這里使用晶振12M,精確延時請使用匯編,大致延時
長度如下 T=tx2+5 uS
void DelayUs2x(unsigned char t)
while(--t);
mS延時函數(shù),含有輸入?yún)?shù) unsigned char t,無返回值
void DelayMs(unsigned char t)
while(t--)
     //大致延時1mS
     DelayUs2x(245);
         DelayUs2x(245);
* @函數(shù)名稱    UartInit
* @功能描述    :串口程序
* @參數(shù)說明    None
* @創(chuàng)建日期    : 2023-04-17
void InitUART(void)                                 //這是串口的基本配置,配置他的波特率是9600.這些參數(shù)都是標(biāo)準(zhǔn)的。
    TMOD = 0x21;
    SCON = 0x50;
    TL0 = 0xb0;
    TH0 = 0x3c;                        //賦初值50ms
    TH1 = 0xFD;
    TL1 = TH1;
    PCON = 0x00;
    EA = 1;
    ES = 1;
    TR1 = 1;
    ET0 = 1;                                //打開定時器0中斷允許開關(guān)
    TR0 = 1;                                //打開定時器0定時開關(guān)
//**函數(shù)名稱 :putc_to_SerialPort(unsigned char c)
//**函數(shù)描述 :uart發(fā)送函數(shù)
//**輸    入 :buf
//**輸    出 :None
  void putc_to_SerialPort(unsigned char c)
        SBUF = c;
        while(TI == 0);
        TI = 0;
void puts_to_SerialPort(unsigned char *s)
        while(*s != '\0')
        putc_to_SerialPort(*s);
        s++;
        DelayMs(5);
void number(void)
    Tx_Buf[0] = 'Z';                                                //幀頭
    Tx_Buf[1] = 'L';                                                //將庫存數(shù)據(jù)送往發(fā)送數(shù)組,送給藍(lán)牙模塊讓手機APP顯示
    Tx_Buf[2] = ':';                                                //
    Tx_Buf[3] = Weight_Shiwu/100000 + 0x30;                //
    Tx_Buf[4] = Weight_Shiwu%100000/10000 + 0x30;
    Tx_Buf[5] = Weight_Shiwu%10000/1000 + 0x30;                                                //
    Tx_Buf[6] = '.';                                                //
    Tx_Buf[7] = Weight_Shiwu%1000/100 + 0x30;                                                //
    Tx_Buf[8] = Weight_Shiwu % 100 / 10 + 0x30;
    Tx_Buf[9] = Weight_Shiwu % 10 + 0x30;
    Tx_Buf[10] = 'k';                                                //幀尾
    Tx_Buf[11] = 'g';
/*------------------------------------------------                    紅外識別函數(shù)------------------------------------------------*/
void hongwai_KeyPress()
                if(!KEY_ADD1)  //如果檢測到低電平,說明按鍵按下
                         DelayMs(10); //延時去抖,一般10-20ms
                         if(!KEY_ADD1)     //再次確認(rèn)按鍵是否按下,沒有按下則退出
                                        while(!KEY_ADD1);//如果確認(rèn)按下按鍵等待按鍵釋放,沒有釋放則一直等待
                                                        num1=~num1;
                                                        if(num1==1)
        LED1 = 0;
        LED2 = 1;
        LED3 = 1;
        LED4 = 1;
        LED5 = 1;
                 puts_to_SerialPort("1 hao you wupin\r\n");
        LED1 = 1;
        LED2 = 1;
        LED3 = 1;
        LED4 = 1;
        LED5 = 1;
                 puts_to_SerialPort("1 hao wu wupin\r\n");
         if(!KEY_ADD2)  //如果檢測到低電平,說明按鍵按下
                         if(!KEY_ADD2)     //再次確認(rèn)按鍵是否按下,沒有按下則退出
                                        while(!KEY_ADD2);//如果確認(rèn)按下按鍵等待按鍵釋放,沒有釋放則一直等待
                                                        num2=~num2;
                                                        if(num2==1)
        LED1 = 1;
        LED2 = 0;
        LED3 = 1;
        LED4 = 1;
        LED5 = 1;
                 puts_to_SerialPort("2 hao you wupin\r\n");
        LED1 = 1;
        LED2 = 1;
        LED3 = 1;
        LED4 = 1;
        LED5 = 1;
                 puts_to_SerialPort("2 hao wu wupin\r\n");
                if(!KEY_ADD3)  //如果檢測到低電平,說明按鍵按下
                         if(!KEY_ADD3)     //再次確認(rèn)按鍵是否按下,沒有按下則退出
                                        while(!KEY_ADD3);//如果確認(rèn)按下按鍵等待按鍵釋放,沒有釋放則一直等待
                                                        num3=~num3;
                                                        if(num3==1)
        LED1 = 1;
        LED2 = 1;
        LED3 = 0;
        LED4 = 1;
        LED5 = 1;
                 puts_to_SerialPort("3 hao you wupin\r\n");
        LED1 = 1;
        LED2 = 1;
        LED3 = 1;
        LED4 = 1;
        LED5 = 1;
                 puts_to_SerialPort("3 hao wu wupin\r\n");
                if(!KEY_ADD4)  //如果檢測到低電平,說明按鍵按下
                         if(!KEY_ADD4)     //再次確認(rèn)按鍵是否按下,沒有按下則退出
                                        while(!KEY_ADD4);//如果確認(rèn)按下按鍵等待按鍵釋放,沒有釋放則一直等待
                                                        num4=~num4;
                                                        if(num4==1)
        LED1 = 1;
        LED2 = 1;
        LED3 = 1;
        LED4 = 0;
        LED5 = 1;
                 puts_to_SerialPort("4 hao you wupin\r\n");
        LED1 = 1;
        LED2 = 1;
        LED3 = 1;
        LED4 = 1;
        LED5 = 1;
                 puts_to_SerialPort("5 hao wu wupin\r\n");
                if(!KEY_ADD5)  //如果檢測到低電平,說明按鍵按下
                         if(!KEY_ADD5)     //再次確認(rèn)按鍵是否按下,沒有按下則退出
                                        while(!KEY_ADD5);//如果確認(rèn)按下按鍵等待按鍵釋放,沒有釋放則一直等待
                                                        num5=~num5;
                                                        if(num5==1)
        LED1 = 1;
        LED2 = 1;
        LED3 = 1;
        LED4 = 1;
        LED5 = 0;
                 puts_to_SerialPort("5 hao you wupin\r\n");
        LED1 = 1;
        LED2 = 1;
        LED3 = 1;
        LED4 = 1;
        LED5 = 1;
//稱重
void Get_Weight()
          long sum = 0;
    unsigned char count = 0;
    Weight_Shiwu = HX711_Read();
          for(count = 0;count<100;count++)
                sum += Weight_Shiwu;
          Weight_Shiwu=sum /100;
    if(Weight_Shiwu>=0)
//        Weight_Shiwu = (signed long)((float)(Weight_Shiwu*100)/35);         //計算實物的實際重量
                          Weight_Shiwu = Weight_Shiwu;
        if(Weight_Shiwu >= 10000)                //超重報警
            Buzzer = !Buzzer;
            puts_to_SerialPort("chaozhong\r\n");
             Buzzer = 1;
        Weight_Shiwu=0;
        Buzzer = 1;
                    主函數(shù)
void main (void)
        static unsigned char i;
        P2=0XFF; //紅外輸入端口電平置高
        P1=0XFF;
        InitUART();
        while (1)         //主循環(huán)
    DelayMs(10);
                i++;
                if(i>=2)
            hongwai_KeyPress();
                else if(i>=4)
      i=0;
      Get_Weight();
                        number();
void UART1_irq() interrupt 4 //處理接收的串口數(shù)據(jù)
   static unsigned char tmp;
    ES=0;
    if(RI)                                      //接收到字節(jié)
        tmp = SBUF;
        RI = 0;                                 //手動清零接收中斷標(biāo)志位
    ES=1;
