他們芯片必須手動(dòng)加載芯片H頭文件,或者按照示范代碼操作
#include <SC95F876x_C.H>
void Uart1_send()
P2CON = 0xfc; //TX/RX設(shè)置為輸入帶上拉
P2PH = 0xff;
TXINX = 0X02; //指向定時(shí)器2
SCON|=0x50; //串口模式1,允許接收
TXCON |= 0X00; //UART0時(shí)鐘來(lái)源為定時(shí)器1
TMCON |= 0x02; //T1頻率源自于fsys
TH1=0X0D; //波特率9600
TL1=0x05;
TR1=0;//開定時(shí)器1中斷
ET1=0;
EA = 1;//開總中斷
EUART = 1;//開串口中斷
void Send_string(uchar byte1)
SBUF=byte1;
while(TI==0);
TI=0;
P0CON = 0xFF; //設(shè)置P0為強(qiáng)推挽模式
P0PH = 0x00;
Uart1_send();
//串口接收中斷函數(shù)
void Serial_INT() interrupt 4
if(TI) //UART0發(fā)送中斷
TI = 0;
if(RI==1) //UART0接收中斷
Send_string(SBUF);
RI = 0;
