查看: 1177|回復(fù): 4
求51單片機(jī)的智能臺(tái)燈的原理圖和代碼
ID:1121518 發(fā)表于 2024-5-22 08:33 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
由于本論壇禁止直接求程序,禁止伸手黨,所以向大家請(qǐng)教一下大致的實(shí)現(xiàn)方法與思路,理清頭緒后我自己來寫程序去實(shí)現(xiàn),謝謝大家
ID:277550 發(fā)表于 2024-5-22 15:27 | 只看該作者
你想做到什么程度,調(diào)光?  人在燈亮、人走燈滅?濕溫度?還想什么功能呢
調(diào)光 pwm
自動(dòng)亮滅,現(xiàn)在使用雷達(dá)模塊
ID:961114 發(fā)表于 2024-5-22 16:02 | 只看該作者
先去學(xué)著看懂程序  ,MCU廠家都提供范例程序了  從呼吸燈學(xué)起
ID:961114 發(fā)表于 2024-5-22 16:03 | 只看該作者
#include "reg51.h"
#include "intrins.h"
#define CYCLE       0x1000
sfr     P_SW2   =   0xba;
sfr     PWMSET      =   0xF1;
sfr     PWMCFG01    =   0xF6;
sfr     PWMCFG23    =   0xF7;
sfr     PWMCFG45    =   0xFE;
#define PWM0C       (*(unsigned int  volatile xdata *)0xFF00)
#define PWM0CH      (*(unsigned char volatile xdata *)0xFF00)
#define PWM0CL      (*(unsigned char volatile xdata *)0xFF01)
#define PWM0CKS     (*(unsigned char volatile xdata *)0xFF02)
#define PWM0TADC    (*(unsigned int  volatile xdata *)0xFF03)
#define PWM0TADCH   (*(unsigned char volatile xdata *)0xFF03)
#define PWM0TADCL   (*(unsigned char volatile xdata *)0xFF04)
#define PWM0IF      (*(unsigned char volatile xdata *)0xFF05)
#define PWM0FDCR    (*(unsigned char volatile xdata *)0xFF06)
#define PWM00T1     (*(unsigned int  volatile xdata *)0xFF10)
#define PWM00T1H    (*(unsigned char volatile xdata *)0xFF10)
#define PWM00T1L    (*(unsigned char volatile xdata *)0xFF11)
#define PWM00T2H    (*(unsigned char volatile xdata *)0xFF12)
#define PWM00T2     (*(unsigned int  volatile xdata *)0xFF12)
#define PWM00T2L    (*(unsigned char volatile xdata *)0xFF13)
#define PWM00CR     (*(unsigned char volatile xdata *)0xFF14)
#define PWM00HLD    (*(unsigned char volatile xdata *)0xFF15)
sfr     P0M1    =   0x93;
sfr     P0M0    =   0x94;
sfr     P1M1    =   0x91;
sfr     P1M0    =   0x92;
sfr     P2M1    =   0x95;
sfr     P2M0    =   0x96;
sfr     P3M1    =   0xb1;
sfr     P3M0    =   0xb2;
sfr     P4M1    =   0xb3;
sfr     P4M0    =   0xb4;
sfr     P5M1    =   0xc9;
sfr     P5M0    =   0xca;
void PWM0_Isr() interrupt 22
    static bit dir = 1;
    static int val = 0;
    if (PWMCFG01 & 0x08)
        PWMCFG01 &= ~0x08;                      //清中斷標(biāo)志
        if (dir)
            val++;
            if (val >= CYCLE) dir = 0;
            val--;
            if (val <= 1) dir = 1;
        _push_(P_SW2);
        P_SW2 |= 0x80;
        PWM00T2 = val;
        _pop_(P_SW2);
    P0M0 = 0x00;
    P0M1 = 0x00;
    P1M0 = 0x00;
    P1M1 = 0x00;
    P2M0 = 0x00;
    P2M1 = 0x00;
    P3M0 = 0x00;
    P3M1 = 0x00;
    P4M0 = 0x00;
    P4M1 = 0x00;
    P5M0 = 0x00;
    P5M1 = 0x00;
    PWMSET = 0x01;                              //使能PWM0模塊(必須先使能模塊后面的設(shè)置才有效)
    P_SW2 = 0x80;
    PWM0CKS = 0x00;                             // PWM0時(shí)鐘為系統(tǒng)時(shí)鐘
    PWM0C = CYCLE;                              //設(shè)置PWM0周期
    PWM00T1= 0x0000;
    PWM00T2= 0x0001;
    PWM00CR= 0x80;                              //使能PWM00輸出
    P_SW2 = 0x00;
    PWMCFG01 = 0x05;                            //啟動(dòng)PWM0模塊并使能PWM0中斷
    EA = 1;
    while (1);
ID:1121518 發(fā)表于 2024-5-23 21:55 來自觸屏版 | 只看該作者
devcang 發(fā)表于 2024-5-22 15:27
調(diào)光 pwm
自動(dòng)亮滅,現(xiàn)在使用雷 ...
可以調(diào)光、可以使用wifi模塊連接云智能、人靠近燈亮,沒人就滅
