查看: 1838|回復(fù): 3
單片機(jī)Proteus仿真4位數(shù)碼管顯示
proteus仿真圖
代碼:
  1. #include<reg51.h>
  2. #include<intrins.h>
  3. typedef unsigned char uchar;
  4. typedef unsigned int uint;
  5. #define Hidden  11
  6. #define CmdDat         0
  7. sbit Clock=P3^3;
  8. sbit Data=P3^2;
  9. const uint TimeOver=800;
  10. uchar code DispCode[]={
  11.         //0x28,0xee,0x32,0xa2,0xe4,
  12.        //                        0xa1,0x21,0xea,0x20,0xa0,
  13.        //                        0xff
  14.         0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,
  15.         0xF8,0x80,0x90,0xff
  16.         };
  17. uchar code DispBit[]={0x7f,0xfe,0xef,0xdf};
  18. uint DispData=0;
  19. uchar DispBuf[4]={0,0,0,0};
  20. uchar RecDatCount;
  21. uchar bdata RecDat;
  22. sbit         RecDat0=RecDat^0;
  23. bit renovate;
  24. bit ReciveMark=1;
  25. uchar DotCnt=1;
  26. uchar        MaskSing=0;
  27. bit   StartOverCount;
  28. bit                RecEnd;
  29. uint  OverCount;
  30. /**********************************************
  31. uS延時(shí)函數(shù)
  32. **********************************************/
  33. void DelayUs2x(unsigned char t)
  34. {
  35. while(--t);
  36. }
  37. /**********************************************
  38. mS延時(shí)函數(shù)
  39. ***********************************************/
  40. void DelayMs(unsigned char t)
  41. {
  42.
  43.     while(t--)
  44.     {
  45.      //大致延時(shí)1mS
  46.         DelayUs2x(245);
  47.         DelayUs2x(245);
  48.     }
  49. }
  50. void ReciveDate() interrupt 2
  51. {
  52.         ReciveMark=0;
  53.         if(!StartOverCount)
  54.                 StartOverCount=1;
  55.         RecDatCount++;
  56.         RecDat=RecDat<<1;
  57.         if(Data)
  58.                 RecDat0=1;
  59.         else
  60.                 RecDat0=0;
  61.         if(RecDatCount==8)
  62.         {
  63.                 MaskSing=RecDat;
  64.         }
  65.         else if(RecDatCount==16)
  66.         {
  67.                 if(MaskSing==CmdDat)
  68.                         DispData=RecDat*256;
  69.
  70.         }
  71.         else if(RecDatCount==24)
  72.         {
  73.                 if(MaskSing==CmdDat)
  74.                         DispData+=RecDat;
  75.
  76.         }
  77.         else if(RecDatCount==32)
  78.         {
  79.                 if(MaskSing==CmdDat)
  80.                         DispData=RecDat;
  81.                 renovate=1;
  82.                 RecDatCount=0;
  83.                 StartOverCount=0;
  84.                 OverCount=0;
  85.                 RecEnd=1;
  86.                 RecDat=0;
  87.
  88.         }
  89. }
  90. void Timer0() interrupt 1
  91. {
  92.         uchar temp;
  93.         static uchar Count;
  94.         if(StartOverCount)
  95.                 OverCount++;
  96.         Count++;
  97.         if(Count==4)
  98.                 Count=0;
  99.         P3|=0XB1;
  100.         temp=DispBit[Count];
  101.         P3&=temp;
  102.         temp=DispBuf[Count];
  103.         P1=DispCode[temp];
  104.         if(DotCnt==(4-Count))
  105.                 P1&=0XDF;
  106.         TH0=-(600/256);
  107.         TL0=-(600%256);
  108. }
  109. void main()
  110. {
  111.         uchar temp0,temp1,temp2,temp3;
  112.         uint temp;
  113.         TH0=-(600/256);
  114.         TL0=-(600%256);
  115.         TR0=1;
  116.         IT1=1;
  117.         EA=1;
  118.         ET0=1;
  119.         EX1=1;
  120.         PT0=0;
  121.         PX1=1;
  122.         renovate=1;
  123.         P1=0;
  124.         Clock=1;
  125.         Data=1;
  126.
  127.         //////////////////////
  128.         DispData=9999;
  129.         //DispData=8888;
  130.         //DispData=654;
  131.         for(;;)
  132.         {
  133.                 if(renovate)
  134.                 {
  135.                         temp=DispData;
  136.                         temp%=10000;
  137.                         temp3=temp%10;
  138.                         temp/=10;
  139.                         temp2=temp%10;
  140.                         temp/=10;
  141.                         temp1=temp%10;
  142.                         temp/=10;
  143.                         temp0=temp%10;
  144.
  145.                         if((temp0==0)&&(DotCnt<3))
  146.                                 DispBuf[0]=Hidden;
  147.                         else
  148.                                 DispBuf[0]=temp0;
  149.
  150.                         if((temp0==0)&&(temp1==0)&&(DotCnt<2))
  151.                                 DispBuf[1]=Hidden;
  152.                         else
  153.                                 DispBuf[1]=temp1;
  154.
  155.                         if(((temp0==0)&&(temp1==0)&&(temp2==0)
  156.                                         &&(DotCnt<1))||((temp3==0)&&(temp2==0)
  157.                                         &&(DotCnt>2)))
  158.                                 DispBuf[2]=Hidden;
  159.                         else
  160.                                 DispBuf[2]=temp2;
  161.                         if((temp3==0)&&(DotCnt>1))
  162.                                 DispBuf[3]=Hidden;
  163.                         else
  164.                                 DispBuf[3]=temp3;
  165.                         renovate=0;
  166.                 }
  167.                 if(OverCount>=TimeOver)
  168.                 {
  169.                         RecDatCount=0;
  170.                         StartOverCount=0;
  171.                         OverCount=0;
  172.                         RecEnd=1;
  173.                 }
  174.
  175.         }
  176. }
proteus仿真文件及C工程
通用顯示器.rar (199.44 KB, 下載次數(shù): 7)
收藏收藏2 分享淘帖 頂 踩
ID:1134911 發(fā)表于 2024-12-14 23:55 | 只看該作者
如果是實(shí)際直接接引腳的話(huà)電流會(huì)不會(huì)不夠?
ID:1057822 發(fā)表于 2025-5-27 16:55 | 只看該作者
顯示1234不行,
ID:619259 發(fā)表于 2025-5-30 18:18 | 只看該作者
一個(gè)簡(jiǎn)單的4位數(shù)碼管顯示,程序搞得這么復(fù)雜:
1.既然使用了定時(shí)器中斷掃描,程序中就不要再出現(xiàn)延時(shí)函數(shù)。
2.定義了很多無(wú)效的變量,干擾了對(duì)程序的理解,也不利用提煉成模塊化。
總之,程序并不是針對(duì)4位數(shù)碼管開(kāi)發(fā)出來(lái)的模塊化程序,像是從某個(gè)項(xiàng)目中硬搬出來(lái)的。
