希望能幫到可以用到的小伙伴
單片機(jī)源程序如下:- #include "adc7606.h"
- //AD_OS0 PG4
- #define OS0_1() GPIOG->BSRRL = GPIO_Pin_4
- #define OS0_0() GPIOG->BSRRH = GPIO_Pin_4
- //AD_OS1 PG3
- #define OS1_1() GPIOG->BSRRL = GPIO_Pin_3
- #define OS1_0() GPIOG->BSRRH = GPIO_Pin_3
- //AD_OS2 PG2
- #define OS2_1() GPIOG->BSRRL = GPIO_Pin_2
- #define OS2_0() GPIOG->BSRRH = GPIO_Pin_2
- //PD11 CNVTA
- //PB15 CNVTB TIM_CH3N/TIM8_CH3N/TIM12_CH2
- #define CONVSTA_1() GPIOD->BSRRL = GPIO_Pin_11
- #define CONVSTA_0() GPIOD->BSRRH = GPIO_Pin_11
- #define CONVSTB_1() GPIOB->BSRRL = GPIO_Pin_15
- #define CONVSTB_0() GPIOB->BSRRH = GPIO_Pin_15
- //PD12 RANGE
- #define RANGE_1() GPIOD->BSRRL = GPIO_Pin_12
- #define RANGE_0() GPIOD->BSRRH = GPIO_Pin_12
- //AD_RESET PB14
- #define RESET_1() GPIOB->BSRRL = GPIO_Pin_14
- #define RESET_0() GPIOB->BSRRH = GPIO_Pin_14
- //AD7606 FSMC總線地址,只能讀,無需寫
- #define AD7606_RESULT() *(__IO uint16_t *)0x6C400000
- AD7606_VAR_T g_tAD7606; //定義1個全局變量,保存一些參數(shù)
- static void AD7606_CtrlLinesConfig(void);
- static void AD7606_FSMCConfig(void);
- *****-----功能介紹:AD7606初始化
- *****-----函數(shù) 名:AD7606_Init()
- *****-----入口參數(shù):無
- *****-----返回 值:無
- *****-----備 注:
- void AD7606_Init(void)
- AD7606_CtrlLinesConfig();
- AD7606_FSMCConfig();
- AD7606_SetOS(AD_OS_NO); //無過采樣
- AD7606_SetInputRange(0); //0表示輸入量程為正負(fù)5V, 1表示正負(fù)10V
- AD7606_Reset();
- CONVSTB_1(); //啟動轉(zhuǎn)換的GPIO平時設(shè)置為高
- *****-----功能介紹:配置AD7606控制口線,F(xiàn)SMC管腳設(shè)置為復(fù)用功能
- *****-----函數(shù) 名:AD7606_CtrlLinesConfig()
- *****-----返回 值:無
- *****-----備 注:
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC, ENABLE);/* 使能FSMC時鐘 */
- RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD | RCC_AHB1Periph_GPIOE | RCC_AHB1Periph_GPIOG, ENABLE);/* 使能 GPIO時鐘 */
- /* 設(shè)置 PD.00(D2), PD.01(D3), PD.04(NOE), PD.05(NWE), PD.08(D13), PD.09(D14),
- PD.10(D15), PD.14(D0), PD.15(D1) 為復(fù)用推挽輸出 */
- GPIO_PinAFConfig(GPIOD, GPIO_PinSource0, GPIO_AF_FSMC);
- GPIO_PinAFConfig(GPIOD, GPIO_PinSource1, GPIO_AF_FSMC);
- GPIO_PinAFConfig(GPIOD, GPIO_PinSource4, GPIO_AF_FSMC);
- GPIO_PinAFConfig(GPIOD, GPIO_PinSource5, GPIO_AF_FSMC);
- GPIO_PinAFConfig(GPIOD, GPIO_PinSource8, GPIO_AF_FSMC);
- GPIO_PinAFConfig(GPIOD, GPIO_PinSource9, GPIO_AF_FSMC);
- GPIO_PinAFConfig(GPIOD, GPIO_PinSource10, GPIO_AF_FSMC);
- GPIO_PinAFConfig(GPIOD, GPIO_PinSource14, GPIO_AF_FSMC);
- GPIO_PinAFConfig(GPIOD, GPIO_PinSource15, GPIO_AF_FSMC);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 |
- GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_14 |
- GPIO_Pin_15;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
- GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- PE.07(D4), PE.08(D5), PE.09(D6), PE.10(D7), PE.11(D8), PE.12(D9), PE.13(D10),
- PE.14(D11), PE.15(D12)
- GPIO_PinAFConfig(GPIOE, GPIO_PinSource7 , GPIO_AF_FSMC);
- GPIO_PinAFConfig(GPIOE, GPIO_PinSource8 , GPIO_AF_FSMC);
- GPIO_PinAFConfig(GPIOE, GPIO_PinSource9 , GPIO_AF_FSMC);
- GPIO_PinAFConfig(GPIOE, GPIO_PinSource10 , GPIO_AF_FSMC);
- GPIO_PinAFConfig(GPIOE, GPIO_PinSource11 , GPIO_AF_FSMC);
- GPIO_PinAFConfig(GPIOE, GPIO_PinSource12 , GPIO_AF_FSMC);
- GPIO_PinAFConfig(GPIOE, GPIO_PinSource13 , GPIO_AF_FSMC);
- GPIO_PinAFConfig(GPIOE, GPIO_PinSource14 , GPIO_AF_FSMC);
- GPIO_PinAFConfig(GPIOE, GPIO_PinSource15 , GPIO_AF_FSMC);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 |
- GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 |
- GPIO_Pin_15;
- GPIO_Init(GPIOE, &GPIO_InitStructure);
- /* 設(shè)置 PG12 為復(fù)用推挽輸出 */
- GPIO_PinAFConfig(GPIOG, GPIO_PinSource12, GPIO_AF_FSMC);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
- GPIO_Init(GPIOG, &GPIO_InitStructure);
- /* 配置幾個控制用的GPIO
- PG4/DCMI_D0/AD7606_OS0 ---> AD7606_OS0 OS2:OS0 選擇數(shù)字濾波參數(shù)
- PG3/DCMI_D1/AD7606_OS1 ---> AD7606_OS1
- PG2/DCMI_D2/AD7606_OS2 ---> AD7606_OS2
- PD11/DCMI_D3/AD7606_CONVSTA ---> AD7606_CONVSTA 啟動ADC轉(zhuǎn)換CH1-CH4
- PB15/DCMI_D3/AD7606_CONVSTB ---> AD7606_CONVSTB 啟動ADC轉(zhuǎn)換CH5-CH8
- PD12/DCMI_D4/AD7606_RAGE ---> AD7606_RAGE 輸入模擬電壓量程,正負(fù)5V或正負(fù)10V
- PB14/DCMI_D5/AD7606_RESET ---> AD7606_RESET 復(fù)位
- PB13/DCMI_D6/AD7606_BUSY ---> AD7606_BUSY 轉(zhuǎn)換結(jié)束的信號
- RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);/* 使能 GPIO時鐘 */
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_3 | GPIO_Pin_2;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- *****-----功能介紹:配置FSMC并口訪問時序
- *****-----函數(shù) 名:AD7606_FSMCConfig()
- *****-----返回 值:無
- *****-----備 注:
- FSMC_NORSRAMInitTypeDef init;
- FSMC_NORSRAMTimingInitTypeDef timing;
- AD7606規(guī)格書要求(3.3V時):RD讀信號低電平脈沖寬度最短21ns,高電平脈沖最短寬度15ns。
- 按照如下配置 讀數(shù)均正常。為了和同BANK的LCD配置相同,選擇3-0-6-1-0-0
- 3-0-5-1-0-0 : RD高持續(xù)75ns, 低電平持續(xù)50ns. 1us以內(nèi)可讀取8路樣本數(shù)據(jù)到內(nèi)存。
- 1-0-1-1-0-0 : RD高75ns,低電平執(zhí)行12ns左右,下降沿差不多也12ns. 數(shù)據(jù)讀取正確。
- /* FSMC_Bank1_NORSRAM4 configuration */
- timing.FSMC_AddressSetupTime = 3;
- timing.FSMC_AddressHoldTime = 0;
- timing.FSMC_DataSetupTime = 6;
- timing.FSMC_BusTurnAroundDuration = 1;
- timing.FSMC_CLKDivision = 0;
- timing.FSMC_DataLatency = 0;
- timing.FSMC_AccessMode = FSMC_AccessMode_A;
- LCD configured as follow:
- - Data/Address MUX = Disable
- - Memory Type = SRAM
- - Data Width = 16bit
- - Write Operation = Enable
- - Extended Mode = Enable
- - Asynchronous Wait = Disable
- init.FSMC_Bank = FSMC_Bank1_NORSRAM4;
- init.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
- init.FSMC_MemoryType = FSMC_MemoryType_SRAM;
- init.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
- init.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
- init.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;
- init.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
- init.FSMC_WrapMode = FSMC_WrapMode_Disable;
- init.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
- init.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
- init.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
- init.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
- init.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
- init.FSMC_ReadWriteTimingStruct = &timing;
- init.FSMC_WriteTimingStruct = &timing;
- FSMC_NORSRAMInit(&init);
- /* - BANK 1 (of NOR/SRAM Bank 1~4) is enabled */
- FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM4, ENABLE);
- *****-----功能介紹:配置AD7606數(shù)字濾波器,也就設(shè)置過采樣倍率。
- *****-----函數(shù) 名:AD7606_SetOS()
- *****-----入口參數(shù): _ucOS : 過采樣倍率
- *****-----返回 值:無
- *****-----備 注:
- 通過設(shè)置 AD7606_OS0、OS1、OS2口線的電平組合狀態(tài)決定過采樣倍率。
- 啟動AD轉(zhuǎn)換之后,AD7606內(nèi)部自動實(shí)現(xiàn)剩余樣本的采集,然后求平均值輸出。
- 過采樣倍率越高,轉(zhuǎn)換時間越長。
- 無過采樣時,AD轉(zhuǎn)換時間 4us;
- 2倍過采樣時 = 8.7us;
- 4倍過采樣時 = 16us
- 64倍過采樣時 = 286us
- void AD7606_SetOS(AD7606_OS_E _ucOS)
- g_tAD7606.ucOS = _ucOS;
- switch (_ucOS)
- case AD_OS_X2:
- OS2_0();
- OS1_0();
- OS0_1();
- break;
- case AD_OS_X4:
- OS2_0();
- OS1_1();
- OS0_0();
- break;
- case AD_OS_X8:
- OS2_0();
- OS1_1();
- OS0_1();
- break;
- case AD_OS_X16:
- OS2_1();
- OS1_0();
- OS0_0();
- break;
- case AD_OS_X32:
- OS2_1();
- OS1_0();
- OS0_1();
- break;
- case AD_OS_X64:
- OS2_1();
- OS1_1();
- OS0_0();
- break;
- case AD_OS_NO:
- default:
- g_tAD7606.ucOS = AD_OS_NO;
- OS2_0();
- OS1_0();
- OS0_0();
- break;
- *****-----功能介紹:配置AD7606模擬信號輸入量程
- *****-----函數(shù) 名:AD7606_SetInputRange()
- *****-----入口參數(shù):ucRange : 0 表示正負(fù)5V 1表示正負(fù)10V
- *****-----返回 值:無
- *****-----備 注:
- void AD7606_SetInputRange(uint8_t _ucRange)
- if (_ucRange == 0)
- g_tAD7606.ucRange = 0;
- RANGE_0(); /* 設(shè)置為正負(fù)5V */
- else
- g_tAD7606.ucRange = 1;
- RANGE_1(); /* 設(shè)置為正負(fù)10V */
- *****-----功能介紹:硬件復(fù)位AD7606。復(fù)位之后恢復(fù)到正常工作狀態(tài)
- *****-----函數(shù) 名:AD7606_Reset()
- *****-----返回 值:無
- *****-----備 注:
- void AD7606_Reset(void)
- RESET_0(); /* 退出復(fù)位狀態(tài) */
- RESET_1(); /* 進(jìn)入復(fù)位狀態(tài) */
- RESET_1(); /* 僅用于延遲。 RESET復(fù)位高電平脈沖寬度最小50ns。 */
- RESET_1();
- RESET_1();
- *****-----功能介紹:啟動1次ADC轉(zhuǎn)換
- *****-----函數(shù) 名:AD7606_StartConvst()
- *****-----返回 值:無
- *****-----備 注:
- void AD7606_StartConvst(void)
- /* page 7: CONVST 高電平脈沖寬度和低電平脈沖寬度最短 25ns */
- /* CONVST平時為高 */
- CONVSTB_0();
- CONVSTB_0();
- CONVSTB_0();
- CONVSTB_1();
- *****-----功能介紹:讀取8路采樣結(jié)果。結(jié)果存儲在全局變量 g_tAD7606
- *****-----函數(shù) 名:AD7606_ReadNowAdc()
- *****-----返回 值:無
- *****-----備 注:
- void AD7606_ReadNowAdc(void)
- g_tAD7606.sNowAdc[0] = AD7606_RESULT(); /* 讀第1路樣本 */
- g_tAD7606.sNowAdc[1] = AD7606_RESULT(); /* 讀第2路樣本 */
- g_tAD7606.sNowAdc[2] = AD7606_RESULT(); /* 讀第3路樣本 */
- g_tAD7606.sNowAdc[3] = AD7606_RESULT(); /* 讀第4路樣本 */
- g_tAD7606.sNowAdc[4] = AD7606_RESULT(); /* 讀第5路樣本 */
- g_tAD7606.sNowAdc[5] = AD7606_RESULT(); /* 讀第6路樣本 */
- g_tAD7606.sNowAdc[6] = AD7606_RESULT(); /* 讀第7路樣本 */
- g_tAD7606.sNowAdc[7] = AD7606_RESULT(); /* 讀第8路樣本 */
原理圖: 無
仿真: 無
代碼:
stm32f407+ad7606+8080并口+usart打印.7z
(295.75 KB, 下載次數(shù): 5)
2024-5-31 13:19 上傳
點(diǎn)擊文件名下載附件
源碼 下載積分: 黑幣 -5
