學(xué)習(xí)多級(jí)菜單,采用機(jī)智云上傳數(shù)據(jù),數(shù)據(jù)下發(fā)后更改閾值,寫入flash中,采用的屏幕是OLED,需要看邏輯得朋友下載,自己調(diào)試沒有問題。
#include "stm32f10x.h" // Device header
#include "gizwits_product.h"
#include "oled.h"
#include "menu.h"
#include "dht11.h"
#include "motor.h"
#include "key.h"
#include "buzzer.h"
#include "flash.h"
#include "usart.h"
#include "sys.h"
#include "relay.h"
#include "tim3.h"
#include "tim2.h"
#include "iwdg.h"
#include "mq2.h"
#include "gp2y1014au.h"
#define FLASH_START_ADDR 0x0801f000 //寫入的起始地址
u8 Menu = 1; //菜單變量
u8 Model_Flag; //系統(tǒng)模式標(biāo)志位
u8 Window_Flag_ON = 0; //開窗標(biāo)志位
u8 Window_Flag_OFF = 0; //關(guān)窗標(biāo)志位
u8 Temp_value,Humi_value; //溫度閾值和濕度閾值
u16 Smog_value,PM25_value; //煙霧閾值和PM2.5閾值
u8 old_Temp_value,old_Humi_value; //舊的煙霧閾值和PM2.5閾值
u16 old_Smog_value,old_PM25_value; //舊的煙霧閾值和PM2.5閾值
u8 value_Option_Num = 1; //閾值調(diào)節(jié)界面位置選擇變量
int main(void)
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
OLED_Init();
ADCX_Init();
GP2Y_Init();
MQ2_Init();
DHT11_UserConfig();
MOTOR_UserConfig();
Key_Init();
Relay_Init();
Buzzer_Init();
Temp_value = FLASH_R(FLASH_START_ADDR); //從指定頁的地址讀FLASH
Humi_value = FLASH_R(FLASH_START_ADDR+2); //從指定頁的地址讀FLASH
Smog_value = FLASH_R(FLASH_START_ADDR+4); //從指定頁的地址讀FLASH
PM25_value = FLASH_R(FLASH_START_ADDR+6); //從指定頁的地址讀FLASH
Timer2_Init(9,14398);
uart2_init(9600);
uart1_init(115200);
GENERAL_TIM_Init();
userInit(); //完成機(jī)智云初始賦值
gizwitsInit(); //開辟一個(gè)環(huán)形緩沖區(qū)
IWDG_Init(); //初始化看門狗
while (1)
IWDG_ReloadCounter(); //重新加載計(jì)數(shù)值 喂狗
switch(Menu)
case 1:
Menu1();
if(Window_Flag_ON == 1)
MOTOR_Direction_Angle(1,0,180,1);
MOTOR_STOP();
Window_Flag_ON = 0;
if(Window_Flag_OFF == 1)
MOTOR_Direction_Angle(0,0,180,1);
MOTOR_STOP();
break;
case 2:
OLED_Clear();
Menu2();
Menu = 3;
//用于判斷閾值數(shù)據(jù)有沒有被更改
old_Temp_value = Temp_value;
old_Humi_value = Humi_value;
old_Smog_value = Smog_value;
old_PM25_value = PM25_value;
break;
case 3:
//顯示傳感器閾值
OLED_ShowNum(1,13,Temp_value,2);
OLED_ShowNum(2,13,Humi_value,2);
OLED_ShowNum(3,13,Smog_value,4);
OLED_ShowNum(4,13,PM25_value,4);
//進(jìn)行閾值選擇
if(KeyNum == 1)
KeyNum = 0;
value_Option_Num++;
if(value_Option_Num > 4)
//顯示選擇標(biāo)識(shí)符“>”
OLED_Option(value_Option_Num);
//檢測(cè)閾值數(shù)值的調(diào)節(jié)
switch(value_Option_Num)
case 1:
if(KeyNum == 3)
KeyNum = 0;
Temp_value++;
if(Temp_value >= 100)
Temp_value = 1;
if(KeyNum == 4)
KeyNum = 0;
Temp_value--;
Temp_value = 99;
break;
case 2:
if(KeyNum == 3)
KeyNum = 0;
Humi_value++;
if(Humi_value >= 100)
Humi_value = 1;
if(KeyNum == 4)
KeyNum = 0;
Humi_value--;
Humi_value = 99;
break;
case 3:
if(KeyNum == 3)
KeyNum = 0;
Smog_value++;
if(Smog_value >= 331)
Smog_value = 1;
if(KeyNum == 4)
KeyNum = 0;
Smog_value--;
Smog_value = 330;
break;
case 4:
if(KeyNum == 3)
KeyNum = 0;
PM25_value++;
if(PM25_value >= 501)
PM25_value = 1;
if(KeyNum == 4)
KeyNum = 0;
PM25_value--;
PM25_value = 500;
break;
//退出閾值設(shè)置界面
if(KeyNum == 2)
KeyNum = 0;
//當(dāng)閾值數(shù)據(jù)被更改后,才會(huì)寫入FLASH中
if((old_Temp_value != Temp_value) || (old_Humi_value != Humi_value) || (old_Smog_value != Smog_value) || (old_PM25_value != PM25_value))
//寫入傳感器閾值數(shù)據(jù)
FLASH_W(FLASH_START_ADDR,Temp_value,Humi_value,Smog_value,PM25_value);
Menu = 1; //回到主菜單
OLED_Clear(); //清屏
break;
userHandle(); //更新機(jī)智云數(shù)據(jù)點(diǎn)變量存儲(chǔ)的值
gizwitsHandle((dataPoint_t *)¤tDataPoint); //數(shù)據(jù)上傳至機(jī)智云
原理圖: 無
仿真: 無
代碼:
多級(jí)菜單flash程序.7z
(234.5 KB, 下載次數(shù): 19)
2024-6-12 16:31 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
