查看: 1272|回復(fù): 4
STM32單片機矩陣鍵盤邏輯寫的沒有問題,但一直不出功能,求大佬
ID:1119762 發(fā)表于 2024-6-13 14:43 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
STM32矩陣鍵盤邏輯寫的沒有問題,但一直不出功能,求大佬
ID:59202 發(fā)表于 2024-6-13 16:28 | 只看該作者
啥也沒有能說啥
ID:1125104 發(fā)表于 2024-6-13 18:21 | 只看該作者
Many microcontrollers have different locations for accesing the inputs and outputs. For example on ATMEL AVR microcontroler to read or write the logical values to port B you use PORTB. To read the actual phisical value of port B you will need to use PINB. Example: "in r16,PINB" will read the physical bits of port B. This is what you need to use to read the keyboard matrix.
ID:1125104 發(fā)表于 2024-6-13 18:25 | 只看該作者
Maybe you are reading the logical value of the keyboard matrix i/o port instead of reading the phisical value.
On ATMEL AVR microcontroller, to read the logical value of port b for example you use:
in r16,PORTB
To read the actual phisical value of port b you will use:
in r16,PINB
So, in your matrix keyboard you need to read the physical value (the real value), not the logical value from the port.
ID:1125137 發(fā)表于 2024-6-13 22:02 | 只看該作者
不發(fā)原理圖,不發(fā)代碼,誰知道你寫的啥啊,一個矩陣鍵盤能需要什么邏輯
