查看: 997|回復(fù): 1
蹲蹲大佬,用單片機(jī)adc控制pwm占空比,在占空比低的時候會閃爍?
ID:1076567 發(fā)表于 2024-6-14 09:35 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
用的是stc8g1k08a單片機(jī)芯片,用adc把0-5v的模擬信號轉(zhuǎn)成pwm輸出,占空比小于10%的時候會有點輕微的閃爍我就在占空比小于10%的時候把它關(guān)掉,但是在那個臨界的時候led會一直閃是為什么呀,我后面測了led閃爍時的電壓,它一直在九點多v到十點多v變化,是adc的精度不夠嗎還是什么原因呀,代碼是之前一位工程師寫的,但是他離職了,總工就扔給我一個菜雞了
#include "intrins.h"
#include "main.h"
#include "Adc.h"
#define CYCLE       0x1000
AboutPwmPara        PwmPara;                        //PWM相關(guān)參數(shù)
void delay_us(int n)
   while (--n);
void delay()
    int i, j;
    for (i=0; i<10; i++)
    for (j=0; j<1; j++);
** 函數(shù)名稱:        Main_Init()
** 函數(shù)功能:        參數(shù)初始化
** 函數(shù)參數(shù):
** 返 回 值:        無
void Main()
        P3M0 = 0x00;
        P3M1 = 0x00;
        PwmPara.PwmCnt        =        0;                //Pwm占空比計數(shù)器
        PwmPara.PwmPercentage        =        0;
        PwmPara.PwmLast        =        0;
        TMOD = 0x00;
  TL0 = 0xa3;                                 //65536-11.0592M/12/1000
  TH0 = 0xff;
  TR0 = 1;                                    //啟動定時器
  ET0 = 1;                                    //使能定時器中斷
        Adc_Init();
        EADC        =        1;                //開啟ADC中斷
        EA                =        1;
                PwmPara.PwmNow        =        AdcPara.AdcVal/1024*100;
                if(PwmPara.PwmLast        ==        0)
                        PwmPara.PwmLast        =        PwmPara.PwmNow;
                PwmPara.PwmLast        =        PwmPara.PwmLast*0.8f+PwmPara.PwmNow*0.2f;
                PwmPara.PwmPercentage        =        (uint8_t)(PwmPara.PwmLast+0.5f);
** 函數(shù)名稱:        Time0()
** 函數(shù)功能:        定時器0中斷處理函數(shù)
** 函數(shù)參數(shù):
** 返 回 值:        無
void TM0_Isr() interrupt 1
        if(PwmPara.PwmCnt>100)
                PwmPara.PwmCnt        =        0;
        PwmPara.PwmCnt++;
        if(PwmPara.PwmPercentage        <10)
                        P32 = 0;
        if((PwmPara.PwmCnt>0)&&(PwmPara.PwmCnt        <        PwmPara.PwmPercentage))
                if(P32        ==        0)
                        P32        =        1;
                if(P32        ==        1)
                        P32        =        0;
adc文件
AboutAdcContrVal        AdcContrVal;                        //控制寄存器參數(shù)
AboutAdcCfgVal        AdcCfgVal;                                        //配置寄存器參數(shù)
AboutAdcTimVal        AdcTimVal;                                        //時序寄存器
AboutAdcPara        AdcPara;                                                        //ADC相關(guān)參數(shù)
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
** 函數(shù)名稱:        Adc_Init()
** 函數(shù)功能:        初始化
** 函數(shù)參數(shù):
** 返 回 值:        無
void Adc_Init(void)
        AdcContrVal.AllVal        =        0;
        AdcCfgVal.AllVal                =        0;
//        AdcTimVal.AllVal                =        0;
        AdcPara.ConvertCnt        =        0;        //連續(xù)轉(zhuǎn)換次數(shù)計數(shù)器
        AdcPara.AdcVal                        =        0;        //ADC轉(zhuǎn)換值
        AdcContrVal.ControlPara.Adc_Power        =        1;                                                //打開ADC電源
        AdcContrVal.ControlPara.Adc_Chs                =        ADC_CHS_P55;        //選擇ADC引腳
        AdcContrVal.ControlPara.Adc_Start        =        1;                                                //開啟ADC轉(zhuǎn)換
        AdcCfgVal.ControlPara.Speed        =        0x0f;        //將ADC系統(tǒng)時鐘設(shè)定為SYSclk/2/16
        AdcCfgVal.ControlPara.Resfmt        =        1;        //將ADC轉(zhuǎn)換結(jié)果右對齊
//   ADCTIM = AdcTimVal.AllVal;                 //設(shè)置 ADC 內(nèi)部時序
   ADCCFG = AdcCfgVal.AllVal;                         //寄存器賦值
   ADC_CONTR = AdcContrVal.AllVal;         //寄存器賦值
** 函數(shù)名稱:        Adc_Isr()
** 函數(shù)功能:        ADC轉(zhuǎn)換中斷處理函數(shù)
** 函數(shù)參數(shù):
** 返 回 值:        無
void Adc_Isr() interrupt 5
        if(AdcPara.ConvertCnt        >=        CONVERT_TIMES)
                AdcPara.SunVal                        =        0;        //ADC轉(zhuǎn)換值
                for(AdcPara.Temp=0;AdcPara.Temp<CONVERT_TIMES;AdcPara.Temp++)
                        AdcPara.SunVal        +=        AdcPara.ConvertVal[AdcPara.Temp];
                        AdcPara.ConvertVal[AdcPara.Temp]        =        0;
                if(AdcPara.SunVal        !=        0)
                        AdcPara.AdcVal        =        AdcPara.SunVal/CONVERT_TIMES;
                        AdcPara.AdcVal        =        0;
        AdcPara.ConvertVal[AdcPara.ConvertCnt]        =        ADC_RES*256 + ADC_RESL;
        AdcPara.ConvertCnt++;
        AdcContrVal.ControlPara.Adc_Flag        =        0;        //中斷標(biāo)志位清0
Adjust.rar
66.27 KB, 下載次數(shù): 3
ID:1076567 發(fā)表于 2024-6-14 09:36 | 只看該作者
