查看: 929|回復: 2
為什么一直報錯ADC_POWER沒有找到定義
ID:1125437 發(fā)表于 2024-6-16 11:38 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <stc15.h>
sbit key_up = P1^7;
sbit key_left = P1^6;
sbit key_center = P1^5;
sbit key_down = P1^4;
sbit key_right = P1^3;
sbit Led = P1^2;
sbit Beep = P0^4;
//1
bit flag = 0;
bit flash_flag = 0;
//2
code unsigned char dis_d[] = {0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
code unsigned char dis_w[] = {0x0e,0x0d,0x0b,0x07};
//3
char Key_Value = 0;
unsigned char time = 0,Key_Num =0, Location =0;
unsigned int AD_Value = 0,UP_Value = 4500,Down_Value = 1500;
//4
void InitBoard(void)
        P0M1 =0x00;
        P0M0 =0xFF;
        TMOD =0x01;
        TH0  =0xd8;
        TL0 =0xf0;
        IE =0xA2;
        TR0 = 1;
void InitADC(void)
        P1ASF =0x01;
        ADC_RES = 0;
        ADC_CONTR = ADC_POWER | ADC_SPEEDLL |ADC_START | 0;
        Delay_ADC(20);
void adc_isr()interrupt 5
        ADC_CONTR &= !ADC_FLAG; //Clear ADC interrupt flag
        AD_Value = (ADC_RES << 2)+ADC_LOW2;
//5
void timero () interrupt 1
         TH0 = 0xd8;
         TL0 = 0xf0;
         time ++;
         if (flag)
                 if (time >50)
                         Led = ~Led;
                         Beep = ~Beep;
                         time = 0;
                 if (time > 100)
                         Led = ~Led;
                         flash_flag = ~flash_flag;
                         time = 0;
//6
void Display(unsigned int Value)
         unsigned char dis[4],i;
        dis[0] = Value /1000;
        dis[1] = Value /100 % 10;
        dis[2] = Value /10 % 10;
        dis[3] = Value % 10;
        if ((Location == 0)|| ((Location != 0) && (flash_flag ==0)))
                for (i=0; i<4; i++)
                        P0 = P0 & 0xf0;
                        if(i == 0)
                                P3 = dis_d[dis[i]] & 0x7F;
                                P3 = dis_d[dis[i]];
                        P0 = P0 | dis_w[i];
                        Delay();
        if ((Location ! = 0) && (flash_flag == 1))
                for (i = 0; i<4 ;i++)
                if (i == (Location - 1))
               P0 = P0 & 0xf0;
                           P3=0xFF;
                           P0 = P0 | dis_w[i];
                        Delay();
                        P0 = P0 & 0xf0;
                        if(i == 0)
                                P3 = dis_d[dis[i]];
                        P0 = P0 | dis_w[i];
                        Delay();
//7
                if (Key_Num == 0)
                 AD_V =(AD_value * 5000000) /1024 ;
                Voltage = AD_V /100;
                if ((Voltage > UP_Value ) || (Voltage < DOWN_Value}
                                flag = 1;
                        flag = 0;
                        Beep = 1;
                Display(Voltage);
//8
if ((!key_center) && (flag == 0)
                while (!key_center)
                Key_Num++;
                Location = 4;
                if (Key_ Num == 1)
                        ge = UP_Value % 10;
                        sh = UP_Value / 10% 10;
                        ba = UP_Value / 100% 10;
                        qi= UP_Value / 1000;
                        if (Key_ Num == 2)
                        ge = UP_Value % 10;
                        if (Key_ Num > 2)
                        Key_Num = 0;
                        Location = 0;
//9
if ((Key_Num == 1))
        UP_Value =qi *1000 + ba*100 + sh*10 + ge;
        Display(UP_Value);
if ((Key_Num == 2))
        Display(UP_Value);
//10
if (!key_left)
         while(!key_left)
         KEY_Value = 0;
         Location--;
         if (Location < 1)
                 Location = 4;
         while(!key_right)
         KEY_Value = 0;
         Location++;
         if (Location > 4)
                 Location = 1;
// 11
if(!key_up)
        while (!key_up)
        if(Location == 4)
                ge++;
                if (ge >9)
                          ge=0;
        if (Location == 3)
                sh++;
                if (sh >9)
                          sh =0;
                if (Location == 2)
                ba++;
                if (ba >9)
                          ba =0;
        if (Location == 1)
                qi++;
                if (qi >9)
                          qi =0;
// 12
if(!key_down)
        while (!key_down)
        if(Location == 4)
                ge--;
                if (ge <0)
                          ge=9;
        if (Location == 3)
                sh--;
                if (sh < 0)
                          sh = 9;
                if (Location == 2)
                ba--;
                if (ba <0)
                          ba =9;
        if (Location == 1)
                qi--;
                if (qi <0)
                          qi =9;
ID:1109793 發(fā)表于 2024-6-16 17:11 | 只看該作者
沒找到就是沒有啊,你那個H文件里面應該沒有那個定義吧
ID:155507 發(fā)表于 2024-6-16 19:52 | 只看該作者
//宏定義ADC的操作命令
#define ADC_POWER   0x80                        //ADC power control dit (宏定義ADC電源控制位)1000 0000
#define ADC_START   0x08                        //ADC start control dit (宏定義ADC啟動控制位)0000 1000
#define ADC_FLAG    0x10                        //ADC complete flag (宏定義ADC完成標志位)    0001 0000
#define ADC_SPEEDLL 0x00                        //420 clocks (宏定義420時鐘)速度控制         0000 0000
Powered by 單片機教程網
