查看: 992|回復(fù): 0
九齊單片機輸出呼吸燈程序
ID:1125252 發(fā)表于 2024-6-19 17:25 | 顯示全部樓層 |閱讀模式
#define   LED1  PA0
unsigned char compare,count;
void Timer0_Init(void)
    //1ms
    //TMRH = 0X30;
    TMR0 = 160;                                //向上計數(shù) 8M 2T 4分頻
    T0MD = C_PS0_TMR0 | C_PS0_Div2;      //
    INTE = C_INT_TMR0;
void isr(void) __interrupt(0)
    if(INTFbits.T0IF)
        count++;
        count %= 100;
        if(count<compare)
             LED1=1;
            LED1=0;
        INTF= (unsigned char)~(C_INT_TMR0);    // Clear T0IF flag bit
            for(int i =0;i<100;i++)
                  compare=i;
            for(int i=100;i>=0;i--)
                 compare=i;
