C# 上位機(jī)開發(fā) modbus rtu master 通訊協(xié)議類源碼
1、讀取保持型寄存器 功能碼0x03
2、預(yù)置單字保持型寄存器 功能碼0x06
3、預(yù)置雙字保持型寄存器 功能碼0x10
4、讀取輸出線圈 功能碼0x01
5、讀取輸入線圈 功能碼0x02
6、強(qiáng)制單線圈 功能碼0x05
- using System;
- using System.Collections.Generic;
- using System.IO.Ports;
- using System.Linq;
- using System.Text;
- using System.Threading;
- using System.Threading.Tasks;
- namespace IProgram
- public class Modbus
- //定義串口類對象
- private SerialPort MyCom;
- //定義CRC校驗高低位
- private byte ucCRCHi = 0xFF;
- private byte ucCRCLo = 0xFF;
- //定義接收字節(jié)數(shù)組
- byte[] bData = new byte[1024];
- //byte mReceiveByte;
- //int mReceiveByteCount = 0;
- //定義設(shè)備地址
- int CurrentAddr;
- int iMWordLen;
- int iMBitLen;
- //定義返回報文
- string strUpData = string.Empty;
- public Modbus(ComPort sp)
- // MyCom = new SerialPort();
- MyCom = sp;
- #region 打開關(guān)閉串口方法
- /// <summary>
- /// 打開串口方法【9600 N 8 1】
- /// </summary>
- /// <param name="iBaudRate">波特率</param>
- /// <param name="iPortNo">端口號</param>
- /// <param name="iDataBits">數(shù)據(jù)位</param>
- /// <param name="iParity">校驗位</param>
- /// <param name="iStopBits">停止位</param>
- /// <returns></returns>
- public bool OpenMyComm(int iBaudRate, string iPortNo, int iDataBits, Parity iParity, StopBits iStopBits)
- try
- //關(guān)閉已打開串口
- MyCom.Close();
- if (MyCom.IsOpen)
- MyCom.Close();
- //設(shè)置串口屬性
- MyCom.BaudRate = iBaudRate;
- MyCom.PortName = iPortNo;
- MyCom.DataBits = iDataBits;
- MyCom.Parity = iParity;
- MyCom.StopBits = iStopBits;
- MyCom.ReceivedBytesThreshold = 1;
- MyCom.DataReceived += new SerialDataReceivedEventHandler(MyCom_DataReceived);
- MyCom.Open();
- return true;
- catch
- return false;
- /// <summary>
- /// 關(guān)閉串口方法
- /// </summary>
- public void ClosePort()
- MyCom.Close();
- #endregion
- #region //所有輸出口打開
- /// <summary>
- /// 所以輸出口打開
- /// </summary>
- public void SetAllOn()
- byte[] SendCommand = new byte[11] { 0x01,0x0F,0x00,0x00,0x00,0x10,0x02,0xFF,0xFF,0xE3,0x90 };
- MyCom.QueryBytes(SendCommand, 8, 2000);
- #endregion
- #region //所有輸出口關(guān)閉
- public void SetAllOff()
- byte[] SendCommand = new byte[11] { 0x01, 0x0F, 0x00, 0x00, 0x00, 0x10, 0x02, 0x00, 0x00, 0xE2, 0x20 };
- #endregion
- #region //獲取輸入狀態(tài)
- /// <summary>
- /// 獲取輸入信號狀態(tài)
- /// </summary>
- /// <param name="X">輸入口位</param>
- public bool GetInput(int X)
- int my_cmd = 0;
- byte[] Static = ReadInputStatus(0x01, 0x00, 0x08);
- my_cmd = 1 << (X);
- if ((Static[3] & my_cmd) == my_cmd)
- Thread.Sleep(100);
- return true;
- return false;
- #endregion
- public void DioOutput(int Y,int time)
- SetOut(Y, true);
- Thread.Sleep(time);
- SetOut(Y, false);
- #region //指定端口輸出
- /// <summary>
- /// 設(shè)置端口輸出
- /// </summary>
- /// <param name="Y">輸出端口位</param>
- /// <param name="En"></param>
- public bool SetOut(int Y,bool En)
- int my_cmd;
- if ( ForceCoil(0x01,Y,En))
- Thread.Sleep(200);
- byte[] Static = ReadOutputStatus(0x01, 0, 10);
- if(En)
- my_cmd = 0;
- my_cmd = 1 << (Y);
- return true;
- else
- my_cmd = 0xFFFF;
- my_cmd = 0 << (Y);
- return true;
- return false;
- #endregion
- //#region 串口接受數(shù)據(jù)事件
- ///// <summary>
- ///// 串口接受數(shù)據(jù)事件
- ///// </summary>
- ///// <param name="sender"></param>
- ///// <param name="e"></param>
- void MyCom_DataReceived(object sender, SerialDataReceivedEventArgs e)
- while (MyCom.BytesToRead > 0)
- mReceiveByte = (byte)MyCom.ReadByte();
- bData[mReceiveByteCount] = mReceiveByte;
- mReceiveByteCount += 1;
- if (mReceiveByteCount >= 1024)
- mReceiveByteCount = 0;
- //清除輸入緩存區(qū)
- MyCom.DiscardInBuffer();
- return;
- #region 讀取保持型寄存器 功能碼0x03
- /// <summary>
- /// 讀取保持型寄存器 功能碼0x03
- /// </summary>
- /// <param name="iDevAdd">從站地址</param>
- /// <param name="iAddress">起始地址</param>
- /// <param name="iLength">長度</param>
- public byte[] ReadKeepReg(int iDevAdd, int iAddress, int iLength)
- //byte[] ResByte = null;
- iMWordLen = iLength;
- CurrentAddr = iDevAdd;
- //第一步:拼接報文
- byte[] SendCommand = new byte[8];
- SendCommand[0] = (byte)iDevAdd;
- SendCommand[1] = 0x03;
- SendCommand[2] = (byte)((iAddress - iAddress % 256) / 256);
- SendCommand[3] = (byte)(iAddress % 256);
- SendCommand[4] = (byte)((iLength - iLength % 256) / 256);
- SendCommand[5] = (byte)(iLength % 256);
- Crc16(SendCommand, 6);
- SendCommand[6] = ucCRCLo;
- SendCommand[7] = ucCRCHi;
- //第二步:發(fā)送報文
- try
- //MyCom.Write(SendCommand, 0, 8);
- return MyCom.QueryBytes(SendCommand, 8, 2000);
- catch (Exception)
- return null;
- //第三步:解析報文
- //mReceiveByteCount = 0;
- //Thread.Sleep(300);
- //ResByte = HexStringToByteArray(this.strUpData, 3, 2);
- //return ResByte;
- #endregion
- #region 預(yù)置單字保持型寄存器 功能碼0x06
- /// <summary>
- /// 預(yù)置單字保持型寄存器 功能碼0x06
- /// </summary>
- /// <param name="iDevAdd"></param>
- /// <param name="iAddress"></param>
- /// <param name="SetValue"></param>
- public bool PreSetKeepReg(int iDevAdd, int iAddress, int SetValue)
- byte[] ResByte;
- //第一步:拼接報文
- SendCommand[1] = 0x06;
- SendCommand[4] = (byte)((SetValue - SetValue % 256) / 256);
- SendCommand[5] = (byte)(SetValue % 256);
- try
- //第二步:發(fā)送報文
- MyCom.Write(SendCommand, 0, 8);
- catch (Exception)
- return false;
- //第三步:解析報文
- ResByte = HexStringToByteArray(this.strUpData, 0, 0);
- return ByteArrayEquals(SendCommand, ResByte);
- #endregion
- #region 預(yù)置雙字保持型寄存器 功能碼0x10
- /// <summary>
- /// 預(yù)置雙字保持型寄存器 功能碼0x10
- /// </summary>
- public bool PreSetFloatKeepReg(int iDevAdd, int iAddress, float SetValue)
- byte[] ResByte;
- byte[] SendCommand = new byte[13];
- SendCommand[1] = 0x10;
- SendCommand[4] = 0x00;
- SendCommand[5] = 0x02;
- SendCommand[6] = 0x04;
- byte[] bSetValue = BitConverter.GetBytes(SetValue);
- SendCommand[7] = bSetValue[3];
- SendCommand[8] = bSetValue[2];
- SendCommand[9] = bSetValue[1];
- SendCommand[10] = bSetValue[0];
- Crc16(SendCommand, 11);
- SendCommand[11] = ucCRCLo;
- SendCommand[12] = ucCRCHi;
- try
- MyCom.Write(SendCommand, 0, 13);
- catch (Exception)
- return false;
- byte[] byteTemp = GetByteArray(ResByte, 0, 6);
- Crc16(byteTemp, 6);
- byte[] bytecrc = GetByteArray(ResByte, 6, 2);
- if (ByteArrayEquals(GetByteArray(SendCommand, 0, 6), byteTemp) && bytecrc[0] == ucCRCLo && bytecrc[1] == ucCRCHi)
- return true;
- else
- return false;
- #endregion
- #region 讀取輸出線圈 功能碼0x01
- /// <summary>
- /// 讀取輸出線圈 功能碼0x01
- /// </summary>
- /// <param name="iLength"></param>
- public byte[] ReadOutputStatus(int iDevAdd, int iAddress, int iLength)
- if (iLength % 8 == 0)
- iMBitLen = iLength / 8;
- else
- iMBitLen = iLength / 8 + 1;
- //第一步:拼接報文
- SendCommand[1] = 0x01;
- try
- return MyCom.QueryBytes(SendCommand, 7, 2000);
- catch (Exception)
- return null;
- //Thread.Sleep(100);
- //return HexStringToByteArray(this.strUpData, 3, 2);
- #endregion
- #region 讀取輸入線圈 功能碼0x02
- /// <summary>
- /// 讀取輸入線圈 功能碼0x02
- /// </summary>
- public byte[] ReadInputStatus(int iDevAdd, int iAddress, int iLength)
- else
- //第一步:拼接報文
- SendCommand[1] = 0x02;
- try
- return MyCom.QueryBytes(SendCommand, 6, 2000);
- catch (Exception)
- return null;
- //return MyCom.QueryBytes(SendCommand, 8, 2000);
- #endregion
- #region 強(qiáng)制單線圈 功能碼0x05
- /// <summary>
- /// 強(qiáng)制單線圈 功能碼0x05
- /// </summary>
- public bool ForceCoil(int iDevAdd,int iAddress,bool SetValue)
- //byte[] ResByte;
- SendCommand[1] = 0x05;
- if (SetValue)
- SendCommand[4] = 0xFF;
- else
- SendCommand[5] = 0x00;
- try
- catch (Exception)
- return false;
- // ResByte = HexStringToByteArray(this.strUpData,0,0); //接收的數(shù)組數(shù)據(jù)
- // return ByteArrayEquals(SendCommand, ResByte);
- return true;
- #endregion
- #region 自定義方法
- /// <summary>
- /// 報文轉(zhuǎn)換字節(jié)數(shù)組(自定義截取)
- /// </summary>
- /// <param name="S"></param>
- /// <param name="start"></param>
- /// <param name="end"></param>
- private byte[] HexStringToByteArray(string S, int start, int end)
- byte[] Res = null;
- if (S != null && S.Length > start + end)
- string[] str = S.Trim().Split(' ');
- string[] Result = new string[str.Length - start - end];
- for (int i = 0; i < Result.Length; i++)
- Result[i] = str[i + start];
- Res = new byte[Result.Length];
- Res[i] = Convert.ToByte(Result[i], 16);
- return Res;
- /// <summary>
- /// 判斷兩個字節(jié)數(shù)組是否完全一致
- /// </summary>
- /// <param name="b1"></param>
- /// <param name="b2"></param>
- private bool ByteArrayEquals(byte[] b1, byte[] b2)
- if (b1.Length != b2.Length) return false;
- if (b1 == null || b2 == null) return false;
- for (int i = 0; i < b1.Length; i++)
- if (b1[i] != b2[i])
- return false;
- return true;
- /// <summary>
- /// 自定義截取字節(jié)數(shù)組
- /// </summary>
- /// <param name="byteArr"></param>
- /// <param name="length"></param>
- private byte[] GetByteArray(byte[] byteArr, int start, int length)
- byte[] Res = new byte[length];
- if (byteArr != null && byteArr.Length > length)
- for (int i = 0; i < length; i++)
- Res[i] = byteArr[i + start];
- return Res;
- #endregion
- #region CRC校驗
- private static readonly byte[] aucCRCHi = {
- 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
- 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
- 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
- 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
- 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
- private static readonly byte[] aucCRCLo = {
- 0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06, 0x07, 0xC7,
- 0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD, 0x0F, 0xCF, 0xCE, 0x0E,
- 0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09, 0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9,
- 0x1B, 0xDB, 0xDA, 0x1A, 0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC,
- 0x14, 0xD4, 0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
- 0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3, 0xF2, 0x32,
- 0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4, 0x3C, 0xFC, 0xFD, 0x3D,
- 0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A, 0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38,
- 0x28, 0xE8, 0xE9, 0x29, 0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF,
- 0x2D, 0xED, 0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
- 0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60, 0x61, 0xA1,
- 0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67, 0xA5, 0x65, 0x64, 0xA4,
- 0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F, 0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB,
- 0x69, 0xA9, 0xA8, 0x68, 0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA,
- 0xBE, 0x7E, 0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
- 0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71, 0x70, 0xB0,
- 0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92, 0x96, 0x56, 0x57, 0x97,
- 0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C, 0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E,
- 0x5A, 0x9A, 0x9B, 0x5B, 0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89,
- 0x4B, 0x8B, 0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
- 0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42, 0x43, 0x83,
- 0x41, 0x81, 0x80, 0x40
- private void Crc16(byte[] pucFrame, int usLen)
- int i = 0;
- ucCRCHi = 0xFF;
- ucCRCLo = 0xFF;
- UInt16 iIndex = 0x0000;
- while (usLen-- > 0)
- iIndex = (UInt16)(ucCRCLo ^ pucFrame[i++]);
- ucCRCLo = (byte)(ucCRCHi ^ aucCRCHi[iIndex]);
- ucCRCHi = aucCRCLo[iIndex];
- #endregion
復(fù)制代碼 |
