如題,大家拿去稍微改下就可以做相冊和惡搞類的程序了,不多說上代碼
#include "stdafx.h"
#include "West.h"
#include "TransparentWnd.h"
#include "BCMenu.h" //添加位圖菜單
#include "WestDlg.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
BCMenu popmenu; //定義位圖菜單變量
// TransparentWnd
TransparentWnd::TransparentWnd()
m_iAniSeq=0; //圖像變化初始值
TransparentWnd::~TransparentWnd()
BEGIN_MESSAGE_MAP(TransparentWnd, CWnd)
//{{AFX_MSG_MAP(TransparentWnd)
ON_WM_LBUTTONDOWN()
ON_WM_CREATE()
ON_WM_ERASEBKGND()
ON_WM_TIMER()
ON_WM_RBUTTONDOWN()
ON_COMMAND(IDR_HELP, OnHelp)
ON_COMMAND(IDR_EXIT, OnExit)
//}}AFX_MSG_MAP
END_MESSAGE_MAP()
//* CreateTransparent()
//* Creates the main application window transparent
void TransparentWnd::CreateTransparent(LPCTSTR pTitle, RECT &rect)
// 創(chuàng)建一個隱藏窗口
CreateEx( 0,
AfxRegisterWndClass(0,AfxGetApp()->LoadStandardCursor(IDC_ARROW)),
pTitle,
WS_POPUP ,
rect,
NULL,
NULL,
NULL);
DoChange();
//* SetupRegion()
//* Set the Window Region for transparancy outside the mask region
void TransparentWnd::SetupRegion(CDC *pDC)
CDCmemDC;
CBitmap&cBitmap=m_bmpDraw;
CBitmap*pOldMemBmp = NULL;
COLORREFcol,colMask;
CRectcRect;
intx, y;
CRgnwndRgn, rgnTemp;
GetWindowRect(&cRect);
CPoint ptOrg=cRect.TopLeft();
BITMAP bmInfo;
cBitmap.GetObject(sizeof(bmInfo),&bmInfo);
CRect rcNewWnd=CRect(ptOrg,CSize(bmInfo.bmWidth,bmInfo.bmHeight));
memDC.CreateCompatibleDC(pDC);
pOldMemBmp = memDC.SelectObject(&cBitmap);
colMask=memDC.GetPixel(0,0);
wndRgn.CreateRectRgn(0, 0, rcNewWnd.Width(), rcNewWnd.Height());
for(x=0; x<=rcNewWnd.Width(); x++)
for(y=0; y<=rcNewWnd.Height(); y++)
col = memDC.GetPixel(x, y);
if(col == colMask)
rgnTemp.CreateRectRgn(x, y, x+1, y+1);
wndRgn.CombineRgn(&wndRgn, &rgnTemp, RGN_XOR);
rgnTemp.DeleteObject();
if (pOldMemBmp) memDC.SelectObject(pOldMemBmp);
SetWindowRgn((HRGN)wndRgn, TRUE);
MoveWindow(rcNewWnd);
void TransparentWnd::DoChange(void)
char szBmp[20];
//不斷替換圖像
sprintf(szBmp,"WEST%d",m_iAniSeq); //合成圖像名
m_bmpDraw.DeleteObject();
m_bmpDraw.LoadBitmap(szBmp);
CWindowDC dc(this);
//SetupRegion(&dc); //顯示一幅位圖,能顯示透明背景的圖片適合做動態(tài)圖
OnEraseBkgnd(&dc); //顯示一幅居中的位圖適合做相冊
Invalidate();
void TransparentWnd::SoundPlay(void)
//先關(guān)閉原聲音播放
PlaySound("WEST",AfxGetResourceHandle(),SND_RESOURCE|SND_PURGE|SND_NODEFAULT|SND_ASYNC );
SetTimer(2,238060,NULL); //設(shè)置播放聲音時間61.08秒
//資源WAV文件的ID須加雙引號,用下API函數(shù)播放
//PlaySound("WEST",AfxGetResourceHandle(),SND_RESOURCE|SND_PURGE|SND_ASYNC|SND_NODEFAULT );
void TransparentWnd::OnLButtonDown(UINT nFlags, CPoint point)
CWnd::OnLButtonDown(nFlags, point);
//實現(xiàn)無標(biāo)題拖動
PostMessage(WM_NCLBUTTONDOWN, HTCAPTION, MAKELPARAM(point.x,point.y));
int TransparentWnd::OnCreate(LPCREATESTRUCT lpCreateStruct)
if (CWnd::OnCreate(lpCreateStruct) == -1)
return -1;
SetTimer(1,5000,NULL); //開始時的圖像顯示時間
SetTimer(2,500,NULL); //啟動聲音播放計時器
SetWindowPos(&wndTopMost,0,0,0,0,SWP_NOSIZE|SWP_NOMOVE); //窗體總在總前面
return 0;
BOOL TransparentWnd::OnEraseBkgnd(CDC* pDC)
CRectrect;
GetWindowRect(&rect);
CDC memDC;
CBitmap&cBitmap=m_bmpDraw;;
CFont* pOldMemFont=NULL;
pDC->BitBlt(0, 0, rect.Width(), rect.Height(), &memDC, 0, 0, SRCCOPY);
if (pOldMemBmp) memDC.SelectObject( pOldMemBmp );
return TRUE;
//return CWnd::OnEraseBkgnd(pDC);
void TransparentWnd::OnTimer(UINT nIDEvent)
switch(nIDEvent)
case(1)://變換圖像
DoChange();
break;
case(2): //播放聲音
SoundPlay();
break;
default:
break;
if(m_iAniSeq==9)
m_iAniSeq=0;
else m_iAniSeq++;
CWnd::OnTimer(nIDEvent);
void TransparentWnd::OnRButtonDown(UINT nFlags, CPoint point)
CWnd::OnRButtonDown(nFlags, point);
//添加右鍵快捷圖標(biāo)菜單(用于下拉式菜單)
popmenu.LoadMenu(IDR_MENU);
popmenu.ModifyODMenu(NULL, IDR_HELP,IDB_HELP);
popmenu.ModifyODMenu(NULL,IDR_EXIT,IDB_EXIT);
ClientToScreen(&point);
BCMenu *psub = (BCMenu *)popmenu.GetSubMenu(0);
psub->TrackPopupMenu(TPM_LEFTALIGN|TPM_RIGHTBUTTON,point.x,point.y,this);
popmenu.DestroyMenu();
void TransparentWnd::OnHelp()
CWestDlg dlg;
//此對話框只顯示一次
if( !FindWindow(NULL,"關(guān)于"))
dlg.DoModal();
void TransparentWnd::OnExit()
DestroyWindow();
