查看: 1769|回復(fù): 7
使用單片機(jī)定時(shí)器中斷控制LED閃爍
想實(shí)現(xiàn)的功能是按鍵第一次按下LED常亮(狀態(tài)1),第二次按下LED發(fā)出SOS信號(hào)(狀態(tài)2)(使用定時(shí)器中斷控制LED先200ms閃爍三次,再500ms閃爍三次,再200ms閃爍三次,測(cè)試過(guò)SOS信號(hào)是正常的),第三次按下LED常滅(狀態(tài)3),以此往復(fù),F(xiàn)在出現(xiàn)了三個(gè)狀態(tài)不穩(wěn)定的情況(有時(shí)會(huì)直接跳過(guò)某個(gè)狀態(tài)而進(jìn)入下一個(gè)狀態(tài)),請(qǐng)問(wèn)是什么原因呢?以下是我的單片機(jī)代碼
# include <STC8.h>
# include <intrins.h>
sbit KEY = P3 ^ 5;
sbit LED = P3 ^ 4;
unsigned int num = 0;
unsigned int LED_flag = 0;
unsigned int SOS_flag = 0;
void Init_IO()
    P0M1 = 0x00;
    P0M0 = 0x00;
    P1M1 = 0x00;
    P1M0 = 0x00;
    P2M1 = 0x00;
    P2M0 = 0x00;
    P3M1 = 0x00;
    P3M0 = 0x00;
    P4M1 = 0x00;
    P4M0 = 0x00;
    P5M1 = 0x00;
    P5M0 = 0x00;
    P6M1 = 0x00;
    P6M0 = 0x00;
    P7M1 = 0x00;
    P7M0 = 0x00;
void Timer0_Init(void)                //20ms@24.000MHz
        AUXR &= 0x7F;                        //12T
        TMOD &= 0xF0;
        TL0 = 0xC0;
        TH0 = 0x63;
        EA=1;
        TF0 = 0;
        TR0 = 0;
        ET0 = 1;
void Timer0_Isr(void) interrupt 1  //SOS信號(hào)
        TL0 = 0xC0;
        TH0 = 0x63;
        num++;
  SOS_flag = 1;
void display_sos(unsigned char state)
  static unsigned char st = 0;
  static unsigned char cnt1 = 0;
        if(state==0)
                 cnt1 = 0;
                 st = 0;
                 num =0;
                  TL0 = 0xC0;
                 TH0 = 0x63;
                 TR0 = 1;//計(jì)時(shí)開(kāi)始
        if(SOS_flag==1)
                SOS_flag = 0;
                if( st == 0)//三短
                        if(num == 10)//200ms
                                 num =0;
                                 cnt1++;
                                 if(cnt1==1)
                                         LED = 0;
                                 else if(cnt1<=7)
                                         LED = ~LED;
                                 else if(cnt1>7)
                                         st = 1;//三短結(jié)束,進(jìn)入下一個(gè)狀態(tài)————三長(zhǎng)
                if( st == 1)//三長(zhǎng)
                         if(num == 25 )//500ms
                                 num =0;
                                 cnt1++;
                                 if(cnt1<=13)
                                         LED = ~LED;
                                         st = 2;//三長(zhǎng)結(jié)束,進(jìn)入下一個(gè)狀態(tài)————三短
                if( st == 2)//三短
                                 num =0;
                                 cnt1++;
                                 if(cnt1<=21)
                                         LED = ~LED;
                                         st = 3;//三短結(jié)束,進(jìn)入間隔等待
                if( st == 3)//每次sos信號(hào)間隔一秒
                         if(num == 50)//1s
                                 cnt1++;
                                 num =0;
                                 if(cnt1>21)
                                         LED =0;
                                         st = 0;
                                         cnt1=0;
void display()
          static unsigned char state = 0;
    if (LED_flag == 0)
        LED = 0;
        state = 0;
    else if (LED_flag == 1)//常亮狀態(tài)
        LED = 1;
                          state = 0;
    else if (LED_flag == 2)//SOS狀態(tài)
        display_sos(state);
        state = 1;
    else if (LED_flag == 3)//常滅狀態(tài)
        LED = 0;
                          state = 0;
void KeyScan()
    static unsigned char last_key_state = 1;
    static unsigned char cnt = 0;
    if (KEY != last_key_state)
        if (++cnt >= 3)
            if (last_key_state == 0)
                if (++LED_flag >= 3)
                    LED_flag = 0;
            cnt = 0;
            last_key_state = KEY;
        cnt = 0;
    LED = 0;
    Init_IO();
    Timer0_Init();
    while (1)
        KeyScan();
        display();
來(lái)自 3#
ID:161164 發(fā)表于 2024-8-13 17:13 | 只看該作者
什么叫三個(gè)狀態(tài)不穩(wěn)定?
描述不清楚,
根據(jù)代碼推斷
是按鍵時(shí)不穩(wěn)定消抖時(shí)間不夠
ID:1130312 發(fā)表于 2024-8-13 17:00 | 只看該作者
SOS信號(hào)的生成函數(shù)要求不能放在Timer0_Isr函數(shù)里,因?yàn)槌绦蜻^(guò)多了
ID:86926 發(fā)表于 2024-8-13 18:07 | 只看該作者
你的按鍵消抖不行,循環(huán)檢測(cè)3次太快了,可以中斷時(shí)間設(shè)置小一點(diǎn)幾百us中斷,按鍵連續(xù)檢測(cè)幾十次都是有效電平判斷按鍵按下;中斷中時(shí)間較長(zhǎng)的處理用個(gè)變量計(jì)數(shù)去處理
ID:123917 發(fā)表于 2024-8-13 19:21 | 只看該作者
每執(zhí)行完一次狀態(tài),都要關(guān)一次IE
ID:1130312 發(fā)表于 2024-8-14 08:01 | 只看該作者
lkc8210 發(fā)表于 2024-8-13 17:13
描述不清楚,
根據(jù)代碼推斷
是的,的確是按鍵消抖時(shí)間不夠,感謝感謝
ID:1129414 發(fā)表于 2024-8-15 10:36 | 只看該作者
按鍵消抖時(shí)間不夠
