網(wǎng)上搜的,自己做了個(gè)板,可程序?qū)懭耄?1,12腳接的輕觸開關(guān)沒有反應(yīng),大佬們給看看,指教一下。
#include<reg51.h>
sbit key1 = P3^0 ;
sbit key0 = P3^1 ;
sbit key2 = P3^2 ;
sbit key3 = P3^3 ;
uchar s[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F}; //共陰數(shù)碼管0~9
uchar hour = 10 , min = 10 , sec = 0 ,day = 25 , month = 1 , year = 20 ;
uchar a = 0 ,b = 0 , c = 0 , d = 0 , e = 0 ,f = 0 ;
uchar b_1 = 0 ,c_1 = 0 ;
void time0_server_() interrupt 1
TH0 = 0x4c ;
TL0 = 0x00 ;
a++;
e = 2000 + year ;
if(a == 20)
a = 0 ;
sec = sec + 1 ;
if(sec == 60)
min = min + 1 ;
sec = 0 ;
if(min == 60)
hour = hour + 1 ;
min = 0 ;
if(hour == 24)
day = day + 1 ;
hour = 0 ;
switch(month) //根據(jù)月份來控制天數(shù)
case 1:
case 3:
case 5:
case 7:
case 8:
case 10:
case 12:if(day == 32)
month = month + 1 ;
day = 1 ;
break ;
case 4:
case 6:
case 9:
case 11:if(day == 31)
month =month + 1;
day = 1 ;
break ;
case 2:if(e%400==0||e%4==0&&e%100!=0)
if(day == 30)
month = month + 1 ;
day = 1 ;
else if(day == 29)
month = month + 1 ;
day = 1 ;
break ;
if(month == 13)
year = year + 1 ;
month = 1 ;
void init_t0()
TMOD = 0x01 ;
TH0 = 0x4C ;
TL0 = 0x00 ;
EA = 1 ;
ET0 = 1 ;
TR0 = 1 ;
void delay(uint n) //延時(shí)函數(shù) 大約1ms
uint i,j;
for(i = 0 ; i < n ; i ++)
for(j = 0 ; j < 120 ; j ++);
void display1() //顯示 “時(shí)、分、秒”
uchar t0 = 0 ,t1 = 0 , t2 = 0 , t3 = 0 , t4 = 0 , t5 = 0 ;
t0 = hour / 10 ;
t1 = hour % 10 ;
t2 = min / 10 ;
t3 = min % 10 ;
t4 = sec / 10 ;
t5 = sec % 10 ;
/************* 74HC138譯碼器 輔助控制數(shù)碼管 ******/
// P2 = 0x1c ;
// P0 = s[t0] ;
// delay(2) ;
// P2 = 0x18 ;
// P0 = s[t1] ;
// delay(2) ;
// P2 = 0x14 ;
// P0 = 0x40 ;
// delay(2) ;
// P2 = 0x10 ;
// P0 = s[t2] ;
// delay(2) ;
// P2 = 0x0c ;
// P0 = s[t3] ;
// delay(2) ;
// P2 = 0x08 ;
// P0 = 0x40 ;
// delay(2) ;
// P2 = 0x04 ;
// P0 = s[t4] ;
// delay(2) ;
// P2 = 0x00 ;
// P0 = s[t5] ;
delay(2) ;
/*********** P2直接控制數(shù)碼管 *********/
P2 = 0x7f ;
P0 = s[t0] ;
delay(1) ;
P2 = 0xbf ;
P0 = s[t1] ;
delay(1) ;
P2 = 0xdf ;
P0 = 0x40 ;
delay(1) ;
P2 = 0xef ;
P0 = s[t2] ;
delay(1) ;
P2 = 0xf7 ;
P0 = s[t3] ;
delay(1) ;
P2 = 0xfb ;
P0 = 0x40 ;
delay(1) ;
P2 = 0xfd ;
P0 = s[t4] ;
delay(1) ;
P2 = 0xfe ;
P0 = s[t5] ;
delay(1) ;
void display2() //顯示 “年、月、日”
t0 = year / 10 ;
t1 = year % 10 ;
t2 = month / 10 ;
t3 = month % 10 ;
t4 = day / 10 ;
t5 = day % 10 ;
// P2 = 0x1c ;
// P0 = s[t0] ;
// delay(2) ;
// P2 = 0x18 ;
// P0 = s[t1] ;
// delay(2) ;
// P2 = 0x14 ;
// P0 = 0x40 ;
// delay(2) ;
// P2 = 0x10 ;
// P0 = s[t2] ;
// delay(2) ;
// P2 = 0x0c ;
// P0 = s[t3] ;
// delay(5) ;
// P2 = 0x08 ;
// P0 = 0x40 ;
// delay(2) ;
// P2 = 0x04 ;
// P0 = s[t4] ;
// delay(2) ;
// P2 = 0x00 ;
// P0 = s[t5] ;
// delay(2) ;
P2 = 0x7f ;
P0 = s[t0] ;
delay(1) ;
P2 = 0xbf ;
P0 = s[t1] ;
delay(1) ;
P2 = 0xdf ;
P0 = 0x40 ;
delay(1) ;
P2 = 0xef ;
P0 = s[t2] ;
delay(1) ;
P2 = 0xf7 ;
P0 = s[t3] ;
delay(1) ;
P2 = 0xfb ;
P0 = 0x40 ;
delay(1) ;
P2 = 0xfd ;
P0 = s[t4] ;
delay(1) ;
P2 = 0xfe ;
P0 = s[t5] ;
delay(1) ;
void KEY0() //控制按鈕2的位移
if(key0 == 0 && c == 0)
c = 1 ;
if(key0 == 1 && c == 1)
c = 0 ;
c_1 = c_1 + 1 ;
if(c_1 == 4)
c_1 = 0 ;
void KEY1() //控制 "秒"、“分”、“時(shí)”、“天”、“月”、“年” 的加1
switch(c_1)
case 1: if(b_1 == 0)
if(key1 == 0 && d == 0)
d = 1 ;
if(key1 == 1 && d == 1)
d = 0 ;
sec = sec + 1 ;
else if(b_1 == 1)
d = 1 ;
d = 0 ;
day = day + 1 ;
break ;
case 2: if(b_1 == 0)
d = 1 ;
d = 0 ;
min = min + 1 ;
else if(b_1 == 1)
d = 1 ;
d = 0 ;
month = month + 1 ;
break ;
case 3: if(b_1 == 0)
d = 1 ;
d = 0 ;
hour = hour + 1 ;
else if(b_1 == 1)
d = 1 ;
d = 0 ;
year = year + 1 ;
break ;
void KEY2() //控制 "秒"、“分”、“時(shí)”、“天”、“月”、“年” 的減1
switch(c_1)
if(key2 == 0 && f == 0)
f = 1 ;
if(key2 == 1 && f == 1)
f = 0 ;
sec = sec - 1 ;
if(sec == 255)
sec = 59 ;
else if(b_1 == 1)
f = 1 ;
f = 0 ;
day = day - 1 ;
if(day <= 1)
day = 1 ;
break ;
f = 1 ;
f = 0 ;
min = min - 1 ;
if(min == 255)
min = 0 ;
else if(b_1 == 1)
f = 1 ;
f = 0 ;
month = month - 1 ;
if(month <= 1)
month = 1 ;
break ;
f = 1 ;
f = 0 ;
hour = hour - 1 ;
if(hour == 255)
hour = 0 ;
else if(b_1 == 1)
f = 1 ;
f = 0 ;
year = year - 1 ;
if(year == 255)
year = 0 ;
break ;
void KEY3() //控制“時(shí)、分、秒”與“年、月、日”的轉(zhuǎn)換
if(key3 == 0 && b == 0)
b = 1 ;
if(key3 == 1 && b == 1)
b = 0 ;
b_1 = b_1 + 1;
if(b_1 == 2)
b_1 = 0 ;
switch(b_1)
case 0: display1() ;
break ;
case 1: display2() ;
break ;
init_t0();
KEY0();
KEY1();
KEY2();
KEY3();
