查看: 1719|回復: 0
GD60933數(shù)字紅外溫度儀程序
ID:830387 發(fā)表于 2024-8-29 08:54 | 顯示全部樓層 |閱讀模式
GD60933數(shù)字紅外溫度儀使用說明,這是谷德科技出品的器件以下是驅(qū)動代碼,供參考。
#define speedcommu                        300
uint16_t m,Command[4],tempReadv[4] ;
void I2cA_start()
    for(m=0;m<speedcommu;m++)HAL_GPIO_WritePin(A_SDA_GPIO_Port,A_SDA_Pin,GPIO_PIN_SET);
    for(m=0;m<speedcommu;m++)HAL_GPIO_WritePin(A_SCL_GPIO_Port,A_SCL_Pin,GPIO_PIN_SET);
    for(m=0;m<speedcommu;m++)HAL_GPIO_WritePin(A_SDA_GPIO_Port,A_SDA_Pin,GPIO_PIN_RESET);
    for(m=0;m<speedcommu;m++)HAL_GPIO_WritePin(A_SCL_GPIO_Port,A_SCL_Pin,GPIO_PIN_RESET);
void I2cA_stop()
void I2cA_sendAck(uint8_t ack)
    if(ack==0)
uint8_t I2cA_getAck(void)
  uint8_t ack;
    if(HAL_GPIO_ReadPin(A_SDA_GPIO_Port,A_SDA_Pin)==GPIO_PIN_SET)ack=1;else ack=0;
  return ack;
uint8_t I2cA_read()
  uint8_t i,dat=0;
  for(i=0;i<8;i++)
        dat<<=1;
        if(HAL_GPIO_ReadPin(A_SDA_GPIO_Port,A_SDA_Pin)==GPIO_PIN_SET)dat|=0x01;else dat&=0xFE;
    return dat;
void I2cA_write(uint8_t dat)
  uint8_t i;
  for(i=0;i<8;i++)
        if((dat&0x80)==0x80)
        dat<<=1;
  I2cA_getAck();
uint16_t I2cA_fromDevice(uint8_t deviceAdd,uint8_t datAdd)
    uint8_t dat;uint16_t temp;
    I2cA_start();
    I2cA_write(deviceAdd);
    I2cA_write(datAdd);
    I2cA_start();
    I2cA_write(deviceAdd+1);
    dat=I2cA_read();
    I2cA_sendAck(0);//1
    temp=I2cA_read();
    I2cA_sendAck(1);//0
    temp<<=8;
    temp+=dat;
    I2cA_stop();
    return temp;
uint16_t CollectionTempA(void)
    if(Command[0]==0x55AA)tempReadv[0]=I2cA_fromDevice(0x30,0x1C);        //Read temperature
    Command[0]=I2cA_fromDevice(0x30,0x1F);//0x1F);                //0x55AA
    return tempReadv[0];
admin + 50 共享資料的黑幣獎勵!
