AD9834頻率發(fā)生器是AD公司生產(chǎn)的芯片,以下是驅(qū)動(dòng)代碼,供參考。
***********************AD9834驅(qū)動(dòng)程序********************************
***********************STM32固件函數(shù)庫(kù)V2.0*************************
***********************2011.3.29****************************************
#ifndef __AD9834_H
#define __AD9834_H
#include "stm32f4xx.h"
#include "main.h"
#define Triangle_Wave 0x2002
#define Sine_Wave 0x2028
/* AD9834晶振頻率 */
#define AD9834_SYSTEM_COLCK 250000000UL //250M
#define AD9834_FSYNC_SET HAL_GPIO_WritePin(AD9834_FSYNC_GPIO_Port,AD9834_FSYNC_Pin,GPIO_PIN_SET)//GPIO_SetBits(AD9834_Control_Port ,AD9834_FSYNC)
#define AD9834_FSYNC_CLR HAL_GPIO_WritePin(AD9834_FSYNC_GPIO_Port,AD9834_FSYNC_Pin,GPIO_PIN_RESET)//GPIO_ResetBits(AD9834_Control_Port ,AD9834_FSYNC)
#define AD9834_SCLK_SET HAL_GPIO_WritePin(AD9834_SCLK_GPIO_Port,AD9834_SCLK_Pin,GPIO_PIN_SET)//GPIO_SetBits(AD9834_Control_Port ,AD9834_SCLK)
#define AD9834_SCLK_CLR HAL_GPIO_WritePin(AD9834_SCLK_GPIO_Port,AD9834_SCLK_Pin,GPIO_PIN_RESET)//GPIO_ResetBits(AD9834_Control_Port ,AD9834_SCLK)
#define AD9834_SDATA_SET HAL_GPIO_WritePin(AD9834_SDATA_GPIO_Port,AD9834_SDATA_Pin,GPIO_PIN_SET)//GPIO_SetBits(AD9834_Control_Port ,AD9834_SDATA)
#define AD9834_SDATA_CLR HAL_GPIO_WritePin(AD9834_SDATA_GPIO_Port,AD9834_SDATA_Pin,GPIO_PIN_RESET)//GPIO_ResetBits(AD9834_Control_Port ,AD9834_SDATA)
#define AD9834_RESET_SET HAL_GPIO_WritePin(AD9834_RESET_GPIO_Port,AD9834_RESET_Pin,GPIO_PIN_SET)//GPIO_SetBits(AD9834_Control_Port ,AD9834_RESET)
#define AD9834_RESET_CLR HAL_GPIO_WritePin(AD9834_RESET_GPIO_Port,AD9834_RESET_Pin,GPIO_PIN_RESET)//GPIO_ResetBits(AD9834_Control_Port ,AD9834_RESET)
#define FREQ_0 0
#define FREQ_1 1
#define DB15 0
#define DB14 0
#define DB13 B28
#define DB12 HLB
#define DB11 FSEL
#define DB10 PSEL
#define DB9 PIN_SW
#define DB8 RESET
#define DB7 SLEEP1
#define DB6 SLEEP12
#define DB5 OPBITEN
#define DB4 SIGN_PIB
#define DB3 DIV2
#define DB2 0
#define DB1 MODE
#define DB0 0
#define CONTROL_REGISTER (DB15<<15)|(DB14<<14)|(DB13<<13)|(DB12<<12)|(DB11<<11)|(DB10<<10)\
|(DB9<<9)|(DB8<<8)|(DB7<<7)|(DB6<<6)|(DB5<<5)|(DB4<<4)|(DB3<<3)|(DB2<<2)|(DB1<<1)|(DB0<<0)
/* AD9834函數(shù)聲明 */
void AD9834_Write_16Bits(unsigned short data) ; //寫一個(gè)字到AD9834
void AD9834_Select_Wave(unsigned short initdata) ; //選擇輸出波形
void Init_AD9834(void);//初始化配置
void AD9834_Set_Freq(unsigned char freq_number,unsigned int freq) ;//選擇輸出寄存器和輸出頻率值
#endif /* AD9834_H */
//====================AD9834.c======================//
#include "AD9834.h"
#include "delay.h"
unsigned short BackUpFreqValue;
void DelayUs(unsigned int time)
while(time>0)time-=1;
函數(shù)名稱: AD9834_Write_16Bits
功 能: 向AD9834寫入16為數(shù)據(jù)
參 數(shù): data -- 要寫入的16位數(shù)據(jù)
返回值 : 無(wú)
unsigned char i=0;
AD9834_SCLK_SET;
AD9834_FSYNC_CLR;
for(i=0 ;i<16 ;i++)
if(data & 0x8000)
AD9834_SDATA_SET;
AD9834_SDATA_CLR;
data <<= 1;
AD9834_SCLK_CLR;
AD9834_SCLK_CLR;
AD9834_SCLK_SET;
AD9834_SCLK_SET;
AD9834_FSYNC_SET;
函數(shù)名稱:AD9834_Select_Wave
功 能:軟件為控制,
IOUT正弦波 ,SIGNBITOUT方波 ,寫FREQREG0 ,寫PHASE0
ad9834_write_16bit(0x2028) 一次性寫FREQREG0
ad9834_write_16bit(0x0038) 單獨(dú)改寫FREQREG0的LSB
ad9834_write_16bit(0x1038) 單獨(dú)改寫FREQREG0的MSB
IOUT三角波 ,寫PHASE0
ad9834_write_16bit(0x2002) 一次性寫FREQREG0
ad9834_write_16bit(0x0002) 單獨(dú)改寫FREQREG0的LSB
ad9834_write_16bit(0x1008) 單獨(dú)改寫FREQREG0的MSB
參 數(shù):initdata -- 要輸入的命令
返回值 :無(wú)
AD9834_FSYNC_SET;
AD9834_SCLK_SET;
AD9834_RESET_SET;
AD9834_RESET_SET;
AD9834_RESET_CLR;
AD9834_Write_16Bits(initdata);
void DDSInit()
AD9834_Write_16Bits(0x2100);DelayUs(10);
AD9834_Write_16Bits(0x4000);DelayUs(10);
AD9834_Write_16Bits(0xC000);DelayUs(10);//FreqREG0、PhaseREG賦初值0
AD9834_Write_16Bits(0x2D00);DelayUs(10);
AD9834_Write_16Bits(0x8000);DelayUs(10);
AD9834_Write_16Bits(0xE000);DelayUs(10);//FreqREG1、PhaseREG1賦初值0
函數(shù)名稱: Init_AD9834
功 能: 初始化AD9834控制引腳
參 數(shù): 無(wú)
返回值 : 無(wú)
// GPIO_InitTypeDef GPIO_InitStructure ;
// GPIO_InitStructure.GPIO_Pin=AD9834_FSYNC | AD9834_SCLK | AD9834_SDATA | AD9834_RESET ;
// GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz ;
// GPIO_InitStructure.GPIO_Mode=GPIO_Mode_OUT ;
// GPIO_InitStructure.GPIO_OType=GPIO_OType_PP;
// GPIO_Init(AD9834_Control_Port ,&GPIO_InitStructure) ;
AD9834_FSYNC_SET;
AD9834_SCLK_SET;
AD9834_RESET_SET;DelayUs(10);
AD9834_Write_16Bits(0x2128);
DelayUs(10);DDSInit();
AD9834_FSYNC_SET;
AD9834_SCLK_SET;
AD9834_Write_16Bits(0x2028);//0x2008|正弦波 0x2002|三角波 0x2028|方波
DelayUs(10);
AD9834_Write_16Bits(0xCFFF);//0xC000
DelayUs(10);
函數(shù)名稱: AD9834_Set_Freq
功 能: 設(shè)置頻率值
參 數(shù): freq_number -- 要寫入的平率寄存器(FREQ_0或FREQ_1)
freq -- 頻率值 (Freq_value(value)=Freq_data(data)*FCLK/2^28)
返回值 : 無(wú)
unsigned int FREQREG;
unsigned short FREQREG_LSB_14BIT;
unsigned short FREQREG_MSB_14BIT;
//freq<<=1;
FREQREG=(unsigned int)(268435456.0/AD9834_SYSTEM_COLCK*freq);
//FREQREG=(u32)(1.073741824*freq);
FREQREG_LSB_14BIT=(unsigned short)FREQREG;
FREQREG_MSB_14BIT=(unsigned short)(FREQREG>>14);
if(freq_number == FREQ_0)
FREQREG_LSB_14BIT &= ~(1U<<15);
FREQREG_LSB_14BIT |= 1<<14;
FREQREG_MSB_14BIT &= ~(1U<<15);
FREQREG_MSB_14BIT |= 1<<14;
FREQREG_LSB_14BIT &= ~(1<<14);
FREQREG_LSB_14BIT |= 1U<<15;
FREQREG_MSB_14BIT &= ~(1<<14);
FREQREG_MSB_14BIT |= 1U<<15;
if(BackUpFreqValue!=FREQREG_MSB_14BIT)
AD9834_Write_16Bits(FREQREG_LSB_14BIT);
AD9834_Write_16Bits(FREQREG_MSB_14BIT);
AD9834_Write_16Bits(0x0028);//
BackUpFreqValue=FREQREG_MSB_14BIT;
