查看: 1021|回復(fù): 1
賽元微單片機(jī)ADC初始化問(wèn)題
ID:1041297 發(fā)表于 2024-8-29 16:17 | 顯示全部樓層 |閱讀模式
在NTC那里我接了4.7K的電阻,也就是下圖CN3的位置,理應(yīng)ADC得返回2048左右的ADC值,但是返回出來(lái)只有200多,我的單片機(jī)芯片SC92F7411,用過(guò)他們賽元微里面的例程代碼,返回出來(lái)的值也是一樣,請(qǐng)問(wèn)我應(yīng)該怎么改,請(qǐng)大伙指點(diǎn)迷津,謝謝。。。
void ADC_Init(uint Channel);
unsigned int ADC_GetAverageValue(void);
//unsigned int ADCValue = 0x0000;
uint8_t  tmpValue;
bit AdcFlag = 0;
float  ADC_Voltage;                                     //ADC電壓
float NTC_Temperature;     //NTC溫度值
uint32_t xdata ADC_Value;           //ADC值
/***********ADC采樣頻率選擇*************/
enum ADCFreq {F32=0,F24,F16,F12,F8,F6,F4,F3};
*函數(shù)名稱:void ADC_Init(uint Channel,uchar ADCFreq)
*函數(shù)功能:ADC初始化
*入口參數(shù):void
*出口參數(shù):void
        ADCCON = 0X80|Channel;                //開啟ADC,ADC采樣頻率為3M ,選擇Channel位ADC采樣口
        if(Channel<8)
                ADCCFG0 = 1<<Channel;   //設(shè)置Channel作為采樣口
                ADCCFG1 = 1<<(Channel-8);   //設(shè)置Channel作為采樣口
        //ADCCFG2 = F8;
        IE |= 0X40;        //開啟ADC中斷
*函數(shù)名稱:uint ADC_GetAverageValue(uint Channel,ADC_SamplesNum_TypeDef ADC_SamplesNum)
*函數(shù)功能:ADC采樣取平均值
*入口參數(shù):
ADC_SamplesNum_TypeDef ADC_SamplesNum:采樣次數(shù)
*出口參數(shù):
uint:多次采樣平均值
uint32_t ADC_GetAverageValue(void)
        ADCCON |= 0X40;             //開始一次ADC轉(zhuǎn)換
        while(!AdcFlag);          //等待ADC轉(zhuǎn)換完成
        AdcFlag = 0;
        tmpValue=(ADCVH<<4)+(ADCVL>>4);     //獲取單次轉(zhuǎn)換值
        return tmpValue;                        //返回平均值
void ADC_Interrupt(void) interrupt 6
        ADCCON&=~(0X20);  //清中斷標(biāo)志位
        AdcFlag = 1;
//NTC電阻值
uint32_t code ntc_r[100]=
        //180°~ 189°
        1548,1514,1480,1447,1414,1383,1353,1323,1294,1266,
        //190°~199°
        1239,1212,1186,1160,1136,1112,1088,1065,1043,1021,
        //200°~209°
        1000,978,957,937,917,897,878,860,841,824,
        //210~219°
        807,790,773,758,742,727,712,698,683,670,
        //220°~229°
        656,643,630,618,606,594,582,571,560,549,
// 定義常量
#define R_FIXED 4700.0 // 固定電阻值4.7kΩ
#define B_CONST 4537.0 // NTC的B常數(shù)
#define T0 473.15 // 200℃轉(zhuǎn)換為開爾文
#define R0 1000.0 // NTC在200℃時(shí)的電阻值1kΩ
函數(shù)功能:計(jì)算溫度的值
參數(shù):無(wú)
返回值:無(wú)
備注:無(wú)
float calculate_temperature(float voltage)
    float R_ntc;
    float V_supply = 5.0; // 電源電壓5.0V
          float tmp1 = 0.0;
                float tmp2 = 0.0;
    // 計(jì)算NTC電阻值
    R_ntc = R_FIXED * (V_supply / voltage - 1);   //voltage是ADC值換算過(guò)來(lái)的電壓
    // 計(jì)算溫度(開爾文)
                tmp1 = R_ntc/R0;
                tmp2 = log(tmp1);
                tmp1 = tmp2/B_CONST;
                tmp2 = 1/T0;
                tmp1 = (tmp1+tmp2);
                tmp2 = 1.0/tmp1;
                if(tmp2 <= 274)tmp2 = 274;
                // 轉(zhuǎn)換為攝氏度
                tmp2 -= 273.15;
                //tmp1 = tmp2+0.05;   //溫度補(bǔ)償
                //返回溫度
    return tmp2;
ID:404160 發(fā)表于 2024-9-2 14:13 | 顯示全部樓層
試試這段程序,如果還是一樣,可能是硬件問(wèn)題
#include "sc92f7411.h"
// 假設(shè)ADC模塊的基地址為0x50000000
#define ADC_BASE 0x50000000
// ADC控制寄存器定義
#define ADC_CR1 *(volatile unsigned int *)(ADC_BASE)
#define ADC_CR2 *(volatile unsigned int *)(ADC_BASE + 4)
#define ADC_DR  *(volatile unsigned short *)(ADC_BASE + 8)
// ADC時(shí)鐘使能(請(qǐng)根據(jù)實(shí)際情況修改)
void ADC_ClockInit() {
// ADC初始化
void ADC_Init() {
    ADC_ClockInit();
    // 配置ADC控制寄存器
    ADC_CR1 = 0x00; // 清除控制寄存器
    ADC_CR2 = 0x00; // 清除控制寄存器
    // 設(shè)置采樣時(shí)間、通道等(根據(jù)數(shù)據(jù)手冊(cè)配置)
    ADC_CR1 |= (1 << 12); // 設(shè)置采樣時(shí)間
    ADC_CR2 |= (3 << 0);  // 選擇通道3
    // 使能ADC
    ADC_CR2 |= (1 << 0);
// 啟動(dòng)ADC轉(zhuǎn)換
void ADC_StartConvert() {
    ADC_CR2 |= (1 << 3);
// 讀取ADC轉(zhuǎn)換結(jié)果
uint16_t ADC_ReadValue() {
    // 等待轉(zhuǎn)換完成(可通過(guò)中斷方式)
    return ADC_DR;
