查看: 666|回復(fù): 0
51單片機(jī)倒計(jì)時(shí)程序
ID:1131470 發(fā)表于 2024-9-6 22:56 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg52.h>
#define uint  unsignede int
sbit dula=P2^6;
sbit wela=P2^7;
char code tabl[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,
0x76,0x79,0x38,0x3f,0};
uchar temp,b,s,g,tab;
void delay(uchar x)
  {uchar i,j;
  for(i=0;i<x;i++)
     for(j=0;j<110;j++);}
void int0()interrupt 0
    {TR0=1;
    //tab=100;
void initil()
  {dula=0;
      wela=0;
     tab=101;
    TMOD=0X01;
    TH0=(65535-50000)/256;
    TL0=(65535-50000)%256;
     EA=1;
     ET0=1;
     EX0=1;
    //TR0=1;
void display(uchar b,uchar s,uchar g)
  {    dula=1;
        P0=tabl[b];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfe;
        wela=0;
        delay(1);
        dula=1;
        P0=tabl[s];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfd;
        wela=0;
        delay(1);
        dula=1;
        P0=tabl[g];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfb;
        wela=0;
        delay(1);
void timer0()interrupt 1
   {TH0=(65535-50000)/256;
  temp++;
   void  main()
    initil();
       if (temp==8)
       {  temp=0;
         tab--;
        if (tab==-1)
            tab=0;
             TR0=0;
        b=tab/100;
        s=tab%100/10;
        g=tab%10;}
        display(b,s,g);
