查看: 993|回復(fù): 0
py32f030k28單片機開發(fā)板RTC時鐘顯示代碼
ID:14088 發(fā)表于 2024-9-8 19:48 | 顯示全部樓層 |閱讀模式
演示PY32F030K28自帶RTC并驅(qū)動LED數(shù)碼顯示時鐘。
* 文件名程: main.c
* 作    者: 東莞鄧凱哥
* 功    能: 主函數(shù)
* 硬    件: PY32F030K28-StartKit-V0.1
* 說明:數(shù)碼管顯示RTC時鐘DEMO
* 軟件版本 V0.0.1(2024/4/16 16:02)
#include "main.h"
#include "rtc.h"
#include "rcc.h"
#include "led.h"
#include "usart.h"
#include "timepare.h"
/* Private variables ---------------------------------------------------------*/
const uint8_t dispArr[] = {LL_LED_DISP_0, LL_LED_DISP_1, LL_LED_DISP_2, LL_LED_DISP_3, LL_LED_DISP_4, \
                           LL_LED_DISP_5, LL_LED_DISP_6, LL_LED_DISP_7, LL_LED_DISP_8, LL_LED_DISP_9
static uint8_t dotdis = 0 ;
**函數(shù)信息 :System_Tick(uint32_t Ticks)
**功能描述 :系統(tǒng)嘀嗒時鐘配置
**輸入?yún)?shù) :Ticks 頻率
**輸出參數(shù) :無
**說    明 :
void System_Tick(uint32_t Ticks)
  SysTick->LOAD  = (uint32_t)((SystemCoreClock / Ticks) - 1UL);          /* set reload register */
  SysTick->VAL   = 0UL;                                                       /* Load the SysTick Counter Value */
  SysTick->CTRL  = SysTick_CTRL_CLKSOURCE_Msk |
                                   SysTick_CTRL_TICKINT_Msk   |
                   SysTick_CTRL_ENABLE_Msk;                                   /* Enable the Systick Timer */
**函數(shù)信息 :main()
**功能描述 :主函數(shù)
**輸入?yún)?shù) :無
**輸出參數(shù) :無
**說    明 :
int main(void)
        /* 配置系統(tǒng)時鐘 */
        APP_RCC_Config();
        /* 配置USART1相關(guān)參數(shù) */
        APP_USART1_Config();
        /* 配置LED相關(guān)參數(shù) */
        APP_LED_Config();
        /* 配置RTC相關(guān)參數(shù) */
        APP_RTC_Config();
        /* 設(shè)置RTC時間 */
        SET_RTC_Time(8,14,23);
        /* 開啟系統(tǒng)嘀嗒定時器 */
        System_Tick(1000);
        while (1)
                if( TimePare.Tim1ms_flag == 1 )                //1ms任務(wù)
                        TimePare.Tim1ms_flag = 0;
                        if( ++TimePare.Tim10ms_count >= 10 )
                                TimePare.Tim10ms_count = 0;
                                TimePare.Tim10ms_flag = 1;
                        if( ++TimePare.Tim50ms_count >= 50 )
                                TimePare.Tim50ms_count = 0;
                                TimePare.Tim50ms_flag = 1;
                if( TimePare.Tim10ms_flag == 1 )        //10ms 任務(wù)
                        TimePare.Tim10ms_flag = 0;
                        if( ++TimePare.Tim100ms_count >= 10 )
                                TimePare.Tim100ms_count = 0;
                                TimePare.Tim100ms_flag = 1;
                        if( ++TimePare.Tim200ms_count >= 20 )
                                TimePare.Tim200ms_count = 0;
                                TimePare.Tim200ms_flag = 1;
                if( TimePare.Tim50ms_flag == 1 )        //50ms 任務(wù)
                        TimePare.Tim50ms_flag = 0;
                if( TimePare.Tim100ms_flag == 1 )        //100ms 任務(wù)
                        TimePare.Tim100ms_flag = 0;
                        if( ++TimePare.Tim500ms_count >= 5 )
                                TimePare.Tim500ms_count = 0;
                                TimePare.Tim500ms_flag = 1;
                if( TimePare.Tim200ms_flag == 1 )        //200ms 任務(wù)
                        TimePare.Tim200ms_flag = 0;
                if( TimePare.Tim500ms_flag == 1 )        //500ms 任務(wù)
                        dotdis ++;
                        APP_UpadateRtcTimeStruct();
                        //顯示RTC時鐘
                        LL_LED_SetDisplayValue(LED, LL_LED_COM0, dispArr[ RTC_TimeStruct.hour /10]);
//                        if( dotdis / 2 )                //常規(guī)的方法,用除法
                        if( dotdis >> 1 )                //更高效的方法,用移位
                                dotdis = 0;
                                LL_LED_SetDisplayValue(LED, LL_LED_COM1, dispArr[ RTC_TimeStruct.hour %10] | LL_LED_DISP_DOT );                //時鐘點閃爍
                        }else{
                                LL_LED_SetDisplayValue(LED, LL_LED_COM1, dispArr[ RTC_TimeStruct.hour %10]  );
                        LL_LED_SetDisplayValue(LED, LL_LED_COM2, dispArr[ RTC_TimeStruct.min /10]);
                        LL_LED_SetDisplayValue(LED, LL_LED_COM3, dispArr[ RTC_TimeStruct.min %10]);
                        TimePare.Tim500ms_flag = 0;
                        if( ++TimePare.Tim1s_count >= 2 )
                                TimePare.Tim1s_count = 0;
                                TimePare.Tim1s_flag = 1;
                if( TimePare.Tim1s_flag == 1 )                //1000ms 任務(wù)
                        printf("Hours = %02d,   Min = %02d,   Sec = %02d\r\n",\
                                        RTC_TimeStruct.hour, RTC_TimeStruct.min, RTC_TimeStruct.sec);          //串口打印 時,分,秒
                        TimePare.Tim1s_flag = 0;
  * @brief  錯誤執(zhí)行函數(shù)
  * @param  無
  * @retval 無
void APP_ErrorHandler(void)
  /* 無限循環(huán) */
  while (1)
#ifdef  USE_FULL_ASSERT
  * @brief  輸出產(chǎn)生斷言錯誤的源文件名及行號
  * @param  file:源文件名指針
  * @param  line:發(fā)生斷言錯誤的行號
  * @retval 無
void assert_failed(uint8_t *file, uint32_t line)
  /* 用戶可以根據(jù)需要添加自己的打印信息,
     例如: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* 無限循環(huán) */
  while (1)
#endif /* USE_FULL_ASSERT */
程序和PDF格式的原理圖: 01.7z (1.07 MB, 下載次數(shù): 5)
