查看: 774|回復(fù): 1
求一份stm32f103c8t6控制LCD12864代碼
ID:1132135 發(fā)表于 2024-9-18 15:56 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
ID:404160 發(fā)表于 2024-9-23 10:14 | 只看該作者
STM32F103C8T6是一款常用的微控制器,而LCD12864是一種常見的圖形液晶顯示器。要控制LCD12864,你需要使用STM32的GPIO(通用輸入輸出)引腳來模擬SPI或并行接口,或者使用專用的LCD驅(qū)動(dòng)庫。下面是一個(gè)簡單的示例代碼,展示如何使用STM32F103C8T6來控制LCD12864。
### 硬件連接
1. LCD12864的控制線(如RS, RW, E)連接到STM32的GPIO。
2. 數(shù)據(jù)線(D0-D7)連接到STM32的GPIO。
### 軟件實(shí)現(xiàn)
以下是一個(gè)基于STM32 HAL庫的示例代碼,用于初始化LCD12864并顯示一些文本。
```c
#include "stm32f1xx_hal.h"
// 定義LCD12864的控制引腳
#define LCD_RST_PIN GPIO_PIN_0
#define LCD_RST_GPIO_PORT GPIOA
#define LCD_RW_PIN GPIO_PIN_1
#define LCD_RW_GPIO_PORT GPIOA
#define LCD_EN_PIN GPIO_PIN_2
#define LCD_EN_GPIO_PORT GPIOA
#define LCD_RS_PIN GPIO_PIN_3
#define LCD_RS_GPIO_PORT GPIOA
// 定義數(shù)據(jù)引腳
#define LCD_DATA_PORT GPIOB
#define LCD_DATA_PIN_START 4
#define LCD_DATA_PIN_END 11
// 初始化GPIO
void LCD_GPIO_Init(void) {
    GPIO_InitTypeDef GPIO_InitStruct = {0};
    // 使能GPIO時(shí)鐘
    __HAL_RCC_GPIOA_CLK_ENABLE();
    __HAL_RCC_GPIOB_CLK_ENABLE();
    // 配置控制引腳
    GPIO_InitStruct.Pin = LCD_RST_PIN | LCD_RW_PIN | LCD_EN_PIN | LCD_RS_PIN;
    GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
    // 配置數(shù)據(jù)線
    GPIO_InitStruct.Pin = GPIO_PIN_4 | GPIO_PIN_5 | GPIO_PIN_6 | GPIO_PIN_7 |
                          GPIO_PIN_8 | GPIO_PIN_9 | GPIO_PIN_10 | GPIO_PIN_11;
    HAL_GPIO_Init(LCD_DATA_PORT, &GPIO_InitStruct);
// 寫命令到LCD
void LCD_WriteCommand(uint8_t cmd) {
    HAL_GPIO_WritePin(LCD_RS_GPIO_PORT, LCD_RS_PIN, GPIO_PIN_RESET); // RS=0 for command
    HAL_GPIO_WritePin(LCD_RW_GPIO_PORT, LCD_RW_PIN, GPIO_PIN_RESET); // RW=0 for write
    HAL_GPIO_WritePin(LCD_EN_GPIO_PORT, LCD_EN_PIN, GPIO_PIN_RESET); // E=0
    // 寫入命令數(shù)據(jù)
    for (int i = 0; i < 8; i++) {
        if (cmd & 0x80) {
            HAL_GPIO_WritePin(LCD_DATA_PORT, (1 << i) << LCD_DATA_PIN_START, GPIO_PIN_SET);
        } else {
            HAL_GPIO_WritePin(LCD_DATA_PORT, (1 << i) << LCD_DATA_PIN_START, GPIO_PIN_RESET);
        cmd <<= 1;
    HAL_GPIO_WritePin(LCD_EN_GPIO_PORT, LCD_EN_PIN, GPIO_PIN_SET); // E=1
    HAL_Delay(1); // 等待命令處理
// 寫數(shù)據(jù)到LCD
void LCD_WriteData(uint8_t data) {
    HAL_GPIO_WritePin(LCD_RS_GPIO_PORT, LCD_RS_PIN, GPIO_PIN_SET); // RS=1 for data
    // 寫入數(shù)據(jù)
        if (data & 0x80) {
        } else {
        data <<= 1;
    HAL_Delay(1); // 等待數(shù)據(jù)處理
// 初始化LCD
void LCD_Init(void) {
    HAL_Delay(15); // 等待LCD電源穩(wěn)定
    LCD_WriteCommand(0x30); // 功能設(shè)定
    LCD_WriteCommand(0x0C); // 顯示開
    LCD_WriteCommand(0x06); // 顯示控制
    LCD_WriteCommand(0x01); // 顯示清屏
// 主函數(shù)
int main(void) {
    HAL_Init();
    LCD_GPIO_Init();
    LCD_Init();
    while (1) {
        LCD_WriteCommand(0x80); // 設(shè)置地址
        LCD_WriteData('H');
        LCD_WriteData('e');
        LCD_WriteData('l');
        LCD_WriteData('l');
        LCD_WriteData('o');
        HAL_Delay(1000);
### 說明
1. **GPIO初始化**:配置控制引腳和數(shù)據(jù)線。
2. **寫命令和數(shù)據(jù)**:通過GPIO操作來模擬SPI或并行接口。
3. **LCD初始化**:設(shè)置LCD的基本參數(shù)。
4. **主函數(shù)**:初始化并循環(huán)顯示文本。
你可以根據(jù)實(shí)際的硬件連接和需求調(diào)整引腳配置和功能。希望這個(gè)示例能幫助你開始使用STM32F103C8T6控制LCD12864。
