查看: 714|回復(fù): 1
51單片機(jī)點(diǎn)陣無法循環(huán)顯示
ID:842026 發(fā)表于 2024-9-27 15:36 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
仿真圖都正確,也能正常顯示,就是想弄成循環(huán)顯示的時候,OLED_ShowCHinese放if里面就無法正常顯示,放外面能顯示但是時間延遲較長,無法調(diào)整。有沒有大佬知道怎么回事的!
#include<reg51.h>
#include<intrins.h>
typedef unsigned int u16;        //對系統(tǒng)默認(rèn)數(shù)據(jù)類型進(jìn)行重定義
typedef unsigned char u8;
sbit  ds1 = P2^1;
sbit  sh_cp1 = P2^0;
sbit  st_cp1 = P2^2;
sbit  ds2 = P2^6;
sbit  sh_cp2 = P2^5;
sbit  st_cp2 = P2^7;
sbit  OE = P2^3;
sbit  e = P2^4;
void Delay_ms(u16 ms)
        u16 i,j;
        for(i=ms;i>0;i--)
                for(j=110;j>0;j--);
uchar code dat[][16] = {
{0x00,0x00,0x0F,0x08,0x08,0x08,0x08,0xFF,0x08,0x08,0x08,0x08,0x0F,0x00,0x00,0x00},
{0x00,0x00,0xF0,0x20,0x20,0x20,0x20,0xFF,0x20,0x20,0x20,0x20,0xF0,0x00,0x00,0x00},
{0x00,0x7F,0x40,0x48,0x49,0x49,0x49,0x4F,0x49,0x49,0x49,0x48,0x40,0x7F,0x00,0x00},
{0x00,0xFF,0x02,0x12,0x12,0x12,0x12,0xF2,0x12,0x52,0x32,0x12,0x02,0xFF,0x00,0x00},
{0x04,0x08,0x32,0xE2,0x2A,0x2A,0x2A,0x2A,0x2A,0x2A,0x2A,0x2B,0x20,0x20,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x0C,0x02,0x0F,0x00},
{0x08,0x10,0x3E,0x52,0xD2,0x53,0x57,0x5A,0x52,0x52,0x72,0x12,0x1E,0x00,0x00,0x00},
{0x02,0x52,0x52,0x94,0xA4,0x28,0x4A,0x91,0x7E,0x20,0x50,0x88,0x04,0x02,0x02,0x00},
{0x10,0x12,0x11,0x10,0x13,0x1C,0x00,0x7F,0x40,0x40,0x4F,0x40,0x40,0x7F,0x00,0x00},
{0x04,0x08,0x30,0xC0,0x20,0x19,0x02,0xC4,0x18,0x60,0x80,0x7E,0x01,0xC1,0x07,0x00},
{0x02,0x02,0x42,0x42,0x42,0x42,0x43,0x42,0x42,0x42,0x42,0x42,0x42,0x02,0x02,0x00},
{0x00,0x04,0x0E,0x14,0x24,0xC4,0x04,0x04,0x04,0x24,0x14,0x0C,0x07,0x00,0x00,0x00},
{0x08,0x06,0x40,0x31,0x00,0x7F,0x40,0x4F,0x40,0x7F,0x00,0x1F,0x00,0xFF,0x00,0x00},
{0x20,0x20,0x7E,0x80,0x01,0xE2,0x0C,0xF0,0x08,0xE4,0x00,0xE2,0x01,0xFE,0x00,0x00},
{0x02,0x02,0x42,0x42,0x42,0x42,0x42,0x7F,0x42,0x42,0x42,0x42,0x42,0x02,0x02,0x00},
{0x01,0x01,0x02,0x04,0x08,0x30,0xC0,0x00,0xC0,0x30,0x08,0x04,0x02,0x01,0x01,0x00},
void dat595(uchar as,uchar bs)        //向HC595傳入數(shù)據(jù)
        uchar i,b;
        e = 1;
        b = bs;        //先寫第二個參數(shù),即取模的時候漢字字模的第二排數(shù)據(jù)(共16個),寫到16*16點(diǎn)陣的下面2個8*8點(diǎn)陣
        for(i = 0; i < 8; i++)
                ds1 = b & 0x01;        //寫參數(shù)2的最低位
                sh_cp1 = 0;
                _nop_();_nop_();_nop_();        //空操作,
                sh_cp1 = 1;
                b >>= 1;        //右移一位
        b = as;
                ds1 = b&0x01;
                sh_cp1 = 0;
                sh_cp1 = 1;
                b >>= 1;
void shuchu()        //HC595輸出數(shù)據(jù)
        st_cp2 = 0;
        st_cp1 = 0;
        st_cp2 = 1;        //在時鐘上升沿輸出數(shù)據(jù)
        st_cp1 = 1;        //在時鐘上升沿輸出數(shù)據(jù)
void suocun()        //HC595鎖存數(shù)據(jù)
        sh_cp2 = 0;        //在時鐘上升沿寫入數(shù)據(jù)
        sh_cp2 = 1;
        ds2 = 1;
void OLED_ShowCHinese(uchar f)
        uchar j;
        OE = 0 ;
        ds2= 0 ;
        for(j  =0; j < 16; j++)
                dat595(dat[3*f+f][j],dat[3*f+f+1][j]);
                suocun();
                shuchu();
        for(j = 0; j < 16; j++)
                dat595(dat[3*f+f+2][j],dat[3*f+f+3][j]);
                suocun();
                shuchu();
void timer0_isr() interrupt 1
        static uchar index = 0;
        static uint cp2;
        TH0=0XFC;        //給定時器賦初值,定時1ms
        TL0=0X18;
        cp2++;
        if(cp2 == 100)
                cp2 =0;
                index++;
                if(index >=4)
                        index = 0;
        }OLED_ShowCHinese(index);
void init_timer0()
        TMOD|=0X01;//選擇為定時器0模式,工作方式1
        TL0=0X18;
        ET0=1;//打開定時器0中斷允許
        EA=1;//打開總中斷
        TR0=1;//打開定時器
void main(void)
        init_timer0();
ID:332444 發(fā)表于 2024-9-27 17:45 | 只看該作者
看我帖子有荔枝
