void Time_Init(unsigned char register_Position,unsigned char register_Mode,unsigned char use_Mode,
unsigned char THx,unsigned char TLx,
unsigned char interrupt_Enable,unsigned char interrupt_Grade)
TMOD=0x00;
TCON=0x00;
if(register_Position==1) //Time1
if(register_Mode==0){TMOD = TMOD||0x00;}
else if(register_Mode==1){TMOD = TMOD||0x04;}
if(use_Mode==0){TMOD = TMOD||0x00;TH0=THx;TL0=TLx;}
else if(use_Mode==1){TMOD = TMOD||0x01;TH0=THx;TL0=TLx;}
else if(use_Mode==2){TMOD = TMOD||0x02;TH0=THx;TL0=TLx;}
else if(use_Mode==3){TMOD = TMOD||0x03;TH0=THx;TL0=TLx;}
if(interrupt_Enable==0){ET1==0;}
else if(interrupt_Enable==1){ET1==1;}
TR1=1;
else if(register_Position==0) //Time0
else if(register_Mode==1){TMOD = TMOD||0x40;}
if(use_Mode==0){TMOD = TMOD||0x00;0x01;TH1=THx;TL1=TLx;}
else if(use_Mode==1){TMOD = TMOD||0x01;TH1=THx;TL1=TLx;}
else if(use_Mode==2){TMOD = TMOD||0x02;TH1=THx;TL1=TLx;}
else if(use_Mode==3){TMOD = TMOD||0x03;TH1=THx;TL1=TLx;}
if(interrupt_Enable==0){ET0==0;}
else if(interrupt_Enable==1){ET0==1;}
TR0=1;
TMOD=0x00;
EA=1;
外部中斷0:中斷號為0;
定時器0:中斷號為1;
外部中斷1:中斷號為2;
定時器1:中斷號為3;
void Timex_Suspend() interrupt 3
Time_Init(0,0,1,(65535-1000)/256,(65535-1000)%256,1,0);
//此函數(shù)結(jié)果TMOD=00000001 TCON=00110000
P2=TMOD;
P1=TCON;
void Timex_Suspend() interrupt 1
P0=~P0;
P3=0x00;
TH0=(65535-1000)/256;
TL0=(65535-1000)%256;
