查看: 1333|回復(fù): 5
PID恒溫控制程序出現(xiàn)如下問題
ID:1125252 發(fā)表于 2024-10-12 18:03 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
PID恒溫控制出現(xiàn)可以加熱,但是不能關(guān)閉加熱,大佬們幫忙看下是啥問題?設(shè)置溫度為40度。
#define INT_TIME                        1000        //定時(shí)時(shí)間,單位為us
#define        TH_VAL                                (unsigned char)((0x10000 - (INT_TIME*(FOSC/1000))/12000)>>8)
#define        TL_VAL                                (unsigned char)((0x10000 - (INT_TIME*(FOSC/1000))/12000))
void TIMER0_ISR (void) interrupt 1         //每1ms產(chǎn)生中斷
        TH0 = TH_VAL;
        TL0 = TL_VAL;
        count++;
        if(count>=10)                                //10ms
                cnt++;                                //計(jì)數(shù)
                count=0;
//        P03 = ~P03;
void Timer0_Init(void)
        TMOD = (TMOD&0xFC)|0x01;                 //模式選擇: 定時(shí)器0,模式1。
        TH0 = TH_VAL;                                    //高8位裝初值
        TL0 = TL_VAL;                                    //低8位裝初值
        TR0 = 1;                                               //定時(shí)器0使能
        ET0 = 1;                                               //定時(shí)器0中斷使能
        EA = 1;
//        PT0 = 1;                                               //設(shè)置定時(shí)器0中斷優(yōu)先級(jí)為高優(yōu)先級(jí)
函數(shù)名稱: ADC_Init
功能描述: 初始化ADC寄存器(設(shè)置ADC時(shí)鐘、設(shè)置采樣時(shí)間、選擇ADC參考電壓)
輸入?yún)?shù): 無
返 回 值: 無
void ADC_Init(void)
//         ADCON = AST(0) | ADIE(0) | HTME(7) | ADCALE(1) | VSEL(ADC_REF_INNER);        //設(shè)置ADC參考電壓為內(nèi)部1.5V
        ADCON = AST(0) | ADIE(0) | HTME(7) | ADCALE(0) | VSEL(ADC_REF_VDD);                //設(shè)置ADC參考電壓為VDD
         ADCFGL = ACKD(7);
        P06F = P06_ADC8_SETTING;        //設(shè)置P0.6為ADC引腳功能
函數(shù)名稱: Get_AdcValue
功能描述: 獲取ADC轉(zhuǎn)換數(shù)值
輸入?yún)?shù): channel ADC通道號(hào)
返 回 值: ADC值
unsigned int Get_AdcValue(unsigned char channel)
        unsigned int AD_Value;
        ADCFGL = (ADCFGL&0xE0) | ADCHS(channel);                //選擇ADC通道
        ADCON |= AST(1);        //啟動(dòng)ADC轉(zhuǎn)換
        while(!(ADCON & ADIF));                                                        //等待ADC轉(zhuǎn)換完成
        ADCON |= ADIF;        //清除ADC中斷標(biāo)志
        AD_Value = ADCDH*256 + ADCDL;                                        //讀取AD值
        AD_Value >>= 4;
        return AD_Value;
struct _pid{
        float Set_WD;                        //設(shè)定值
        float Actual_WD;                //實(shí)際值
        float err;                                //偏差
        float err_last;                        //上一次偏差
        float err_next;
        float Kp,Ki,Kd;
        float voltage;                        //電壓值
        float integral;                        //積分值
}pid;
void PID_INIT()
        pid.Set_WD=0.0;
        pid.Actual_WD=0.0;
        pid.err=0.0;
        pid.err_last=0.0;
        pid.err_next=0.0;
        pid.voltage=0.0;
        pid.integral=0.0;
        pid.Kp=0.4;
        pid.Ki=0.5;
        pid.Kd=0.4;
unsigned int temp=40;                             //設(shè)置溫度值
void PID_Realize(){                                   //PID控制
        unsigned int index;
        if(temp==40){temp_adc=1419;}        //100K熱敏電阻40度溫度值時(shí)對(duì)應(yīng)的ADC值
        pid.Set_WD=temp_adc;
        pid.err=pid.Set_WD-AD_Value;
        if(pid.err>200 || pid.err<-200)
                index=0;
        else if(pid.err<100 || pid.err>-100)
                index=1;
                pid.integral+=pid.err;
                if(pid.err>0)
                        index=(200-pid.err)/100;
                        index=(200+pid.err)/100;
        pid.voltage=pid.Kp*pid.err + pid.Ki*pid.integral + pid.Kd*(pid.err-pid.err_last);
        pid.err_last=pid.err;
        PWM_OUT=pid.voltage*1.0;      //賦值給PWM_OUT
        if(PWM_OUT>100){PWM_OUT=100;}
void hot(unsigned int PWM)          //加熱函數(shù)
        if(cnt<PWM){P07=1;}     //加熱,
        if(cnt>PWM){P07=0;}    //關(guān)閉加熱
        if(cnt>100){cnt=0;}
void System_Init(void)
        LVDCON = 0xE0;                                        //開啟LVD,設(shè)置為低電壓復(fù)位模式,檢測(cè)電壓為2.7V
#ifdef SYSCLK_8MHZ
        CKDIV = 0;                                                //系統(tǒng)時(shí)鐘上電默認(rèn)為IRCH的二分頻(4MHz),運(yùn)行8MHz,則CKDIV設(shè)置為0
#endif
#ifdef UART1_EN
        Uart1_Initial(UART1_BAUTRATE);
#endif
void main(void)
        P06F = INPUT | PU_EN;                //ADC腳
        P07F = OUTPUT | PU_EN;                //加熱腳
        P06=1;
        P07=0;
        System_Init();
        EA = 1;                                //開全局中斷
        Timer0_Init();                    //定時(shí)器初始化
        ADC_Init();                        //初始化ADC
        PID_INIT();                      //PID初始化
                AD_Value = Get_AdcValue(ADC_CH8);        //獲取溫度值
                PID_Realize();   //PID運(yùn)算
                hot(PWM_OUT);//控制加熱
ID:484491 發(fā)表于 2024-10-13 01:04 | 只看該作者
你控制加熱的條件就這兩個(gè),你要看你控制環(huán)路實(shí)際跑出來的PWM的值是不是一直大于cnt,
ID:96072 發(fā)表于 2024-10-13 10:30 | 只看該作者
完整程序貼出來編譯看看
ID:1125252 發(fā)表于 2024-10-14 08:44 | 只看該作者
liang45 發(fā)表于 2024-10-13 01:04
if(cntPWM){P07=0 ...
示波器顯示加熱引腳大部分都是高電平加熱,只有一小會(huì)有低電平
ID:1125252 發(fā)表于 2024-10-14 09:53 | 只看該作者
HEIZI555 發(fā)表于 2024-10-13 10:30
完整程序貼出來編譯看看
這個(gè)就是完整的
ID:111490 發(fā)表于 2024-10-18 09:21 | 只看該作者
先分段檢查,設(shè)置不同的數(shù)值,看看是那里出問題了,是溫度采樣還是PID出了問題
