PID控制溫度目前是可以加熱,但是到達(dá)設(shè)定溫度沒(méi)法關(guān)閉加熱,示波器里顯示時(shí)有關(guān)閉加熱的部分,不過(guò)一下又恢復(fù)成加熱了。大部分時(shí)間都是加熱。大佬們幫忙分析下是哪里的問(wèn)題?
#include "include/ca51m020_config.h"
#include "include/ca51m020sfr.h"
#include "include/ca51m020xsfr.h"
#include "include/gpiodef_m020.h"
#include "include/system_clock.h"
#include "include/uart.h"
#include "include/adc.h"
#include "include/delay.h"
unsigned int count=0;
unsigned int temp_adc=0,cnt=0;
unsigned int PWM_OUT=0;
unsigned int get_ntc=0;
unsigned int AD_Value;
void Timer0_Init(void);
void ADC_Init(void);
unsigned int Get_AdcValue(unsigned char channel);
ADC控制例程
#define INT_TIME 1000 //定時(shí)時(shí)間,單位為us
#define TH_VAL (unsigned char)((0x10000 - (INT_TIME*(FOSC/1000))/12000)>>8)
#define TL_VAL (unsigned char)((0x10000 - (INT_TIME*(FOSC/1000))/12000))
void TIMER0_ISR (void) interrupt 1 //每1ms產(chǎn)生中斷
TH0 = TH_VAL;
TL0 = TL_VAL;
count++;
if(count>=10) //10ms
cnt++; //計(jì)數(shù)
count=0;
// P03 = ~P03;
TMOD = (TMOD&0xFC)|0x01; //模式選擇: 定時(shí)器0,模式1。
TH0 = TH_VAL; //高8位裝初值
TL0 = TL_VAL; //低8位裝初值
TR0 = 1; //定時(shí)器0使能
ET0 = 1; //定時(shí)器0中斷使能
EA = 1;
// PT0 = 1; //設(shè)置定時(shí)器0中斷優(yōu)先級(jí)為高優(yōu)先級(jí)
函數(shù)名稱: ADC_Init
功能描述: 初始化ADC寄存器(設(shè)置ADC時(shí)鐘、設(shè)置采樣時(shí)間、選擇ADC參考電壓)
輸入?yún)?shù): 無(wú)
返 回 值: 無(wú)
void ADC_Init(void)
// ADCON = AST(0) | ADIE(0) | HTME(7) | ADCALE(1) | VSEL(ADC_REF_INNER); //設(shè)置ADC參考電壓為內(nèi)部1.5V
ADCON = AST(0) | ADIE(0) | HTME(7) | ADCALE(0) | VSEL(ADC_REF_VDD); //設(shè)置ADC參考電壓為VDD
ADCFGL = ACKD(7);
P06F = P06_ADC8_SETTING; //設(shè)置P0.6為ADC引腳功能
函數(shù)名稱: Get_AdcValue
功能描述: 獲取ADC轉(zhuǎn)換數(shù)值
輸入?yún)?shù): channel ADC通道號(hào)
返 回 值: ADC值
ADCFGL = (ADCFGL&0xE0) | ADCHS(channel); //選擇ADC通道
ADCON |= AST(1); //啟動(dòng)ADC轉(zhuǎn)換
while(!(ADCON & ADIF)); //等待ADC轉(zhuǎn)換完成
ADCON |= ADIF; //清除ADC中斷標(biāo)志
AD_Value = ADCDH*256 + ADCDL; //讀取AD值
AD_Value >>= 4;
return AD_Value;
struct _pid{
float Set_WD; //設(shè)定值
float Actual_WD; //實(shí)際值
float err; //偏差
float err_last; //上一次偏差
float err_next;
float Kp,Ki,Kd;
float voltage; //電壓值
float integral; //積分值
}pid;
void PID_INIT()
pid.Set_WD=0.0;
pid.Actual_WD=0.0;
pid.err=0.0;
pid.err_last=0.0;
pid.err_next=0.0;
pid.voltage=0.0;
pid.integral=0.0;
pid.Kp=0.3;
pid.Ki=0.05;
pid.Kd=0.3;
unsigned int temp=40;
void PID_Realize(){
unsigned int index;
if(temp==40){temp_adc=1419;} //設(shè)定溫度,對(duì)應(yīng)100K熱敏電阻40攝氏度下的ADC值
pid.Actual_WD=AD_Value; //獲取ADC值
pid.Set_WD=temp_adc; //設(shè)定溫度
pid.err=pid.Set_WD-pid.Actual_WD;
if(pid.err>200 || pid.err<-200)
index=0;
else if((pid.err<100 && pid.err>0)|| (pid.err<0 && pid.err>-100))
index=1;
pid.integral+=pid.err;
if(pid.err>0)
index=(200-pid.err)/100;
index=(200+pid.err)/100;
pid.voltage=pid.Kp*pid.err + pid.Ki*pid.integral + pid.Kd*(pid.err-pid.err_last);
pid.err_last=pid.err;
PWM_OUT=pid.voltage*1.0;
if(PWM_OUT>100){PWM_OUT=100;}
void hot(unsigned int PWM)
if(cnt<PWM){P07=1;}
if(cnt>PWM){P07=0;}
if(cnt>100){cnt=0;}
void System_Init(void)
LVDCON = 0xE0; //開(kāi)啟LVD,設(shè)置為低電壓復(fù)位模式,檢測(cè)電壓為2.7V
#ifdef SYSCLK_8MHZ
CKDIV = 0; //系統(tǒng)時(shí)鐘上電默認(rèn)為IRCH的二分頻(4MHz),運(yùn)行8MHz,則CKDIV設(shè)置為0
#endif
#ifdef UART1_EN
Uart1_Initial(UART1_BAUTRATE);
#endif
void main(void)
P06F = INPUT | PU_EN; //ADC
P07F = OUTPUT | PU_EN; //加熱
P17F = OUTPUT | PU_EN;
P17=1;
P06=1;
P07=0;
System_Init();
EA = 1; //開(kāi)全局中斷
Timer0_Init();
ADC_Init(); //初始化ADC
PID_INIT();
AD_Value = Get_AdcValue(ADC_CH8); //獲取溫度值
PID_Realize(); //PID控制
hot(PWM_OUT); //加熱控制
// Uart1_PutChar(AD_Value>>8);
// Uart1_PutChar(AD_Value);
