查看: 889|回復(fù): 9
PY32F030單片機(jī)串口中斷標(biāo)志在哪里設(shè)置一個(gè),謝謝支持
ID:302293 發(fā)表于 2024-10-23 08:59 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include "main.h"
#define LED_OFF HAL_GPIO_WritePin(GPIOB, GPIO_PIN_5, GPIO_PIN_SET);
UART_HandleTypeDef UartHandle;
uint8_t aTxBuffer[12] = {1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12};
uint8_t aRxBuffer[12] = {0xfc, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff};
void APP_ErrorHandler(void);
void APP_GpioConfig_LED(void);
void APP_USARTConfig(void);
uint8_t cont;
  * @brief  應(yīng)用程序入口函數(shù).
  * @retval int
int main(void)
  /* 初始化所有外設(shè),F(xiàn)lash接口,SysTick */
  HAL_Init();
  /* 初始化LED */
  APP_GpioConfig_LED();
  /* 系統(tǒng)時(shí)鐘配置 */
  APP_USARTConfig();
        /*通過(guò)中斷方式接收數(shù)據(jù)*/
if (HAL_UART_Transmit_IT(&UartHandle, (uint8_t *)aRxBuffer, 12) != HAL_OK)
//   APP_ErrorHandler();
        while (1)
    /* 延時(shí)250ms */
    HAL_Delay(250);
    /* LED翻轉(zhuǎn) */
//    HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_5);
  * @brief  GPIO配置
  * @param  無(wú)
  * @retval 無(wú)
static void APP_GpioConfig_LED(void)
  GPIO_InitTypeDef  GPIO_InitStruct;
  __HAL_RCC_GPIOB_CLK_ENABLE();                          /* 使能GPIOA時(shí)鐘 */
  GPIO_InitStruct.Pin = GPIO_PIN_5;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;            /* 推挽輸出 */
  GPIO_InitStruct.Pull = GPIO_PULLUP;                    /* 使能上拉 */
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;          /* GPIO速度 */
  /* GPIO初始化 */
  HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  * @brief  USART配置函數(shù)
  * @param  無(wú)
  * @retval 無(wú)
  /* USART1初始化 */
  __HAL_RCC_USART1_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  UartHandle.Instance          = USART1;
  UartHandle.Init.BaudRate     = 115200;
  UartHandle.Init.WordLength   = UART_WORDLENGTH_8B;
  UartHandle.Init.StopBits     = UART_STOPBITS_1;
  UartHandle.Init.Parity       = UART_PARITY_NONE;
  UartHandle.Init.HwFlowCtl    = UART_HWCONTROL_NONE;
  UartHandle.Init.Mode         = UART_MODE_TX_RX;
  if (HAL_UART_DeInit(&UartHandle) != HAL_OK)
    APP_ErrorHandler();
  if (HAL_UART_Init(&UartHandle) != HAL_OK)
    APP_ErrorHandler();
  * @brief  USART錯(cuò)誤回調(diào)執(zhí)行函數(shù),輸出錯(cuò)誤代碼
  * @param  無(wú)
  * @retval 無(wú)
void HAL_UART_ErrorCallback(UART_HandleTypeDef *huart)
  printf("Uart Error, ErrorCode = %d\r\n", huart->ErrorCode);
  * @brief  USART發(fā)送回調(diào)執(zhí)行函數(shù)
  * @param  無(wú)
  * @retval 無(wú)
void HAL_UART_TxCpltCallback(UART_HandleTypeDef *UartHandle)
  if (HAL_UART_Receive_IT(UartHandle, (uint8_t *)aRxBuffer, 12) != HAL_OK)
      APP_ErrorHandler();
  * @brief  USART接收回調(diào)執(zhí)行函數(shù)
  * @param  無(wú)
  * @retval 無(wú)
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *UartHandle)
  if (HAL_UART_Transmit_IT(UartHandle, (uint8_t *)aRxBuffer, 12) != HAL_OK)
    APP_ErrorHandler();
//cont=1;
  * @brief  錯(cuò)誤執(zhí)行函數(shù)
  * @param  無(wú)
  * @retval 無(wú)
  while (1)
#ifdef  USE_FULL_ASSERT
  * @brief  輸出產(chǎn)生斷言錯(cuò)誤的源文件名及行號(hào)
  * @param  file:源文件名指針
  * @param  line:發(fā)生斷言錯(cuò)誤的行號(hào)
  * @retval 無(wú)
void assert_failed(uint8_t *file, uint32_t line)
  /* 用戶可以根據(jù)需要添加自己的打印信息,
     例如: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* 無(wú)限循環(huán) */
  while (1)
#endif /* USE_FULL_ASSERT */
/************************ (C) COPYRIGHT Puya *****END OF FILE******************/
void USART1_IRQHandler(void)
  HAL_UART_IRQHandler(&UartHandle);
ID:161164 發(fā)表于 2024-10-23 11:17 | 只看該作者
先說(shuō)說(shuō)你想干啥
ID:302293 發(fā)表于 2024-10-23 17:43 | 只看該作者
lkc8210 發(fā)表于 2024-10-23 11:17
先說(shuō)說(shuō)你想干啥
串口接收數(shù)據(jù)點(diǎn)亮LED
ID:161164 發(fā)表于 2024-10-24 11:51 | 只看該作者
sr861126 發(fā)表于 2024-10-23 17:43
在HAL_UART_TxCpltCallback里處理就可以啦
ID:302293 發(fā)表于 2024-10-30 15:39 | 只看該作者
lkc8210 發(fā)表于 2024-10-24 11:51
我試了不行啊
ID:302293 發(fā)表于 2024-10-30 15:41 | 只看該作者
  試了好幾次都不執(zhí)行這個(gè)標(biāo)志位
ID:917614 發(fā)表于 2024-10-30 15:56 | 只看該作者
sr861126 發(fā)表于 2024-10-30 15:41
是沒進(jìn)這個(gè)HAL_UART_TxCpltCallback函數(shù)呢?還是這個(gè)標(biāo)志位一直不變呢?
ID:302293 發(fā)表于 2024-10-30 17:13 | 只看該作者
wfl1314520 發(fā)表于 2024-10-30 15:56
這個(gè)函數(shù)是進(jìn)了,單步執(zhí)行會(huì)跳過(guò)這個(gè)標(biāo)志位
ID:302293 發(fā)表于 2024-10-31 07:52 | 只看該作者
標(biāo)志位不變,直接跳過(guò)
