查看: 1533|回復(fù): 5
使用AT89C4051單片機(jī)+CD4069的簡易LC測試儀源程序電路原理圖
ID:1136941 發(fā)表于 2024-11-20 14:32 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
電路原理圖如下:
#include <reg51.h>
#include <intrins.h>
#define ulong unsigned long
/**********1602************/
sbit RS=P1^7;
sbit EN=P1^6;
sbit LCD_D4=P1^3;
sbit LCD_D5=P1^2;
sbit LCD_D6=P1^1;
sbit LCD_D7=P1^0;
sbit L_C=P3^0;
bit Lc=1;
uchar cnt=0;
float counter=0;
float F1=0;
float F2=0;
float C1=0;
float L1=0;
ulong temp1=0;
ulong temp2=0;
unsigned char Data[8];
unsigned char Table[]="0123456789";
/********以下是函數(shù)聲明********/
void LCD_en_write(void);//液晶使能
void LCD_by(uchar abc);//寫字節(jié)
void LCD_set_xy(uchar x, uchar y);//寫地址
void LCD_write_str(uchar X,uchar Y,uchar *s);//寫字符串
void LCD_init(void);//液晶初始化
void del_ms(uint n);//ms延時函數(shù)
void delay_5us(void);//5us延時函數(shù)
void delay_nus(uint n);//N us延時函數(shù)
void T0_T1_ini(void);//定時器初始化
void process_8(unsigned long i,unsigned char *p) ;
void display_8C(unsigned char x, unsigned char y, unsigned char *p);
ulong calc_Cx(float cl);//計算被測電容Cx
float calc_Lx(float cl);//計算被測電感Lx
void display_8L(unsigned char x, unsigned char y, uchar *p);
void process_8(unsigned long i,uchar *p)
  p[0]=i/10000000%10;
  p[1]=i/1000000%10;
  p[2]=i/100000%10;
  p[3]=i/10000%10;
  p[4]=i/1000%10;
  p[5]=i/100%10;
  p[6]=i/10%10;
  p[7]=i%10;
void display_8C(unsigned char x, unsigned char y, uchar *p)
  unsigned char i;
  LCD_set_xy( x, y );
  RS=1;
  for(i=0;i<8;i++)
    LCD_by(Table[p[ i]]);
  unsigned char i;
  LCD_set_xy( x, y );
  RS=1;
  for(i=0;i<8;i++)
    if(i==6)
      LCD_write_str(10,1,".");
     delay_5us();
     EN=1;
     delay_5us();
     EN=0;
    delay_nus(500);
    if(((abc<<0)&0x80)==0)
     LCD_D7=0;
     else LCD_D7=1;
    if(((abc<<1)&0x80)==0)
     LCD_D6=0;
     else LCD_D6=1;
    if(((abc<<2)&0x80)==0)
     LCD_D5=0;
     else LCD_D5=1;
    if(((abc<<3)&0x80)==0)
     LCD_D4=0;
     else LCD_D4=1;
    LCD_en_write();
    if(((abc<<4)&0x80)==0)
     LCD_D7=0;
     else LCD_D7=1;
    if(((abc<<5)&0x80)==0)
     LCD_D6=0;
     else LCD_D6=1;
    if(((abc<<6)&0x80)==0)
     LCD_D5=0;
     else LCD_D5=1;
    if(((abc<<7)&0x80)==0)
     LCD_D4=0;
     else LCD_D4=1;
    LCD_en_write();
void LCD_set_xy( uchar x, uchar y )
    uchar address;
    if (y == 0) address = 0x80 + x;
    address = 0xc0 + x;
    RS=0;
    LCD_by(address);
    LCD_set_xy(X,Y);
    RS=1;
    while(*s)
       LCD_by(*s);
       s++;
void LCD_init(void)
    RS=0;
    del_ms(500);
    LCD_by(0x30);
    del_ms(60);
    LCD_by(0x30);
    del_ms(10);
    LCD_by(0x30);
    del_ms(10);
    LCD_by(0x02);
    del_ms(10);
    LCD_by(0x28);
    del_ms(10);
    LCD_by(0x08);
    del_ms(10);
    LCD_by(0x01);
    del_ms(10);
    LCD_by(0x06);
    del_ms(10);
    LCD_by(0x0C);
    del_ms(100);
void delay_nus(uint n)//N us延時函數(shù)
   uint i=0;
   for (i=0;i<n;i++){;}
void delay_5us(void)//@12.000MHz//5us延時函數(shù)
   unsigned char data i;
   _nop_();
   _nop_();
   i = 12;
   while (--i);
void del_ms(uint n)//ms延時函數(shù)
   uchar j;
   while(n--)
  {for(j=0;j<125;j++);}
   TMOD=0x15;//T1方式1定時,T0方式1計數(shù)
   TH1=(65536-50000)/256;//50ms
   TL1=(65536-50000)%256;
   TH0=0x00;
   TL0=0x00;
   TR0=1;
   TR1=1;
   EA=1;
   ET1=1;
void timer1(void) interrupt 3 using 2//測頻率
   TF1=0;
   cnt++;
   if(cnt==2)//0.1秒閘門
     cnt=0;
     temp1=TL0;
     temp2=TH0;
     TR0=0;
     TL0=0;
     TH0=0;
     TR0=1;
     counter=((temp2*256)+temp1)*10;
     if(Lc==1)//先測出頻率值F1
       Lc=0;
       F1=counter;
ulong calc_Cx(float cx)//計算C
  float x;
  float temp1;
  temp1=(float)F1/(float)F2;
  x=(float)(((temp1*temp1)-1)*cx);
  return x;
float calc_Lx(float lx)//計算L
  float x;
  float temp1;
  x=(float)(((temp1*temp1)-1)*lx);
  x=x*100;
  return x;
void main(void)
  float L2,C2;
  del_ms(1000);//等待震蕩穩(wěn)定
  T0_T1_ini();
  LCD_init();
  del_ms(100);
  if(L_C==0)//檔位錯誤
      LCD_write_str(4,0,"Error !!!");
    F2=counter;//測頻率值F2
    LCD_write_str(0,0,"fq=");
    process_8(counter,Data);
    display_8C(4,0,Data);
    LCD_write_str(14,0,"Hz");
     if(L_C==0)//測電感
        L1=76.95;//uH
        L2=calc_Lx(L1);
        LCD_write_str(0,1,"Lx=");
        process_8(L2,Data);
        display_8L(4,1,Data);
        LCD_write_str(14,1,"uH");
     if(L_C==1)//測電容
        LCD_write_str(12,1," ");
        C1=2408;//pF
        C2=calc_Cx(C1);
        LCD_write_str(0,1,"Cx=");
        process_8(C2,Data);
        display_8C(4,1,Data);
        LCD_write_str(14,1,"pF");
admin + 50 共享資料的黑幣獎勵!
收藏收藏6 分享淘帖 頂 踩
ID:1136941 發(fā)表于 2024-11-22 11:19 | 只看該作者
電路圖中的電容C8容量應(yīng)該是2200PF
ID:1136941 發(fā)表于 2024-11-22 11:21 | 只看該作者
電路圖中的電容C8改為2200PF
ID:71955 發(fā)表于 2024-11-24 16:38 來自觸屏版 | 只看該作者
問一下使用cd4069對比lm393哪一個頻率穩(wěn),我用lm393做的頻率很不穩(wěn)導(dǎo)致數(shù)字亂跳
ID:1136941 發(fā)表于 2024-11-24 17:37 | 只看該作者
用CD4069的震蕩頻率在10HZ位跳動,測試值還比較穩(wěn)定。C8用的是2200PF滌綸電容,其它的是獨(dú)石電容。
ID:1136941 發(fā)表于 2024-11-25 16:49 | 只看該作者
精度還是可以滿足一般應(yīng)用的
