以下是一個完整的代碼示例,包括初始化以太網(wǎng)、配置GPIO、初始化ETH模塊等步驟:
#include "stm32f10x.h"
// 以太網(wǎng)初始化函數(shù)
void init_ethernet(void) {
NVIC_InitTypeDef NVIC_InitStructure;
ETH_InitTypeDef ETH_InitStructure;
uint32_t time = 0;
#define TIME_OUT 0x0003FFFFul
/* 使能時鐘 */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_ETH_MAC | RCC_AHBPeriph_ETH_MAC_Tx |
RCC_AHBPeriph_ETH_MAC_Rx, ENABLE);
/* 使能GPIO時鐘 */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC |
RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE | RCC_APB2Periph_AFIO,
ENABLE);
/* 選擇中斷向量表 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
/* 使能以太網(wǎng)全局中斷*/
NVIC_InitStructure.NVIC_IRQChannel = ETH_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
/* 以太網(wǎng)引腳配置 */
/* AF Output Push Pull: */
/* -ETH_RMII_MDIO: PA2 */
/* -ETH_RMII_MDC: PC1 */
/* -ETH_RMII_TX_EN: PB11 */
/* -ETH_RMII_TXD0: PB12 */
/* -ETH_RMII_TXD1: PB13 */
/* Configure PA2 as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* Configure PC1 as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
GPIO_Init(GPIOC, &GPIO_InitStructure);
/* Configure PB11, PB12 and PB13 as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13;
GPIO_Init(GPIOB, &GPIO_InitStructure);
/* Input: */
/* -ETH_RMII_REF_CLK: PA1 */
/* -ETH_RMII_CRS_DV: PA7 */
/* -ETH_RMII_RXD0: PC4 */
/* -ETH_RMII_RXD1: PC5 */
/* Configure PA1 and PA7 as input */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
/* Configure PC4 and PC5 as input */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
/* 選擇配置為MII或者RMII,當(dāng)前為RMII */
GPIO_ETH_MediaInterfaceConfig(GPIO_ETH_MediaInterface_RMII);
/* 重置以太網(wǎng) */
ETH_DeInit();
ETH_SoftwareReset();
/*等待重置完成*/
while (ETH_GetSoftwareResetStatus() == SET);
/* 以太網(wǎng)配置, 填充ETH_InitStructure結(jié)構(gòu)體,最后調(diào)用 ETH_Init()配置以太網(wǎng)*/
ETH_StructInit(Ð_InitStructure);
/*------------------------ MAC -----------------------------------*/
ETH_InitStructure.ETH_AutoNegotiation = ETH_AutoNegotiation_Enable;
ETH_InitStructure.ETH_LoopbackMode = ETH_LoopbackMode_Disable;
ETH_InitStructure.ETH_RetryTransmission = ETH_RetryTransmission_Disable;
ETH_InitStructure.ETH_AutomaticPadCRCStrip = ETH_AutomaticPadCRCStrip_Disable;
ETH_InitStructure.ETH_ReceiveAll = ETH_ReceiveAll_Disable;
ETH_InitStructure.ETH_BroadcastFramesReception = ETH_BroadcastFramesReception_Enable;
ETH_InitStructure.ETH_PromiscuousMode = ETH_PromiscuousMode_Disable;
ETH_InitStructure.ETH_MulticastFramesFilter = ETH_MulticastFramesFilter_Perfect;
ETH_InitStructure.ETH_UnicastFramesFilter = ETH_UnicastFramesFilter_Perfect;
#ifdef CHECKSUM_BY_HARDWARE
ETH_InitStructure.ETH_ChecksumOffload = ETH_ChecksumOffload_Enable;
#endif
/*------------------------ DMA -----------------------------------*/
ETH_InitStructure.ETH_DropTCPIPChecksumErrorFrame = ETH_DropTCPIPChecksumErrorFrame_Enable;
ETH_InitStructure.ETH_ReceiveStoreForward = ETH_ReceiveStoreForward_Enable;
ETH_InitStructure.ETH_TransmitStoreForward = ETH_TransmitStoreForward_Enable;
ETH_InitStructure.ETH_ForwardErrorFrames = ETH_ForwardErrorFrames_Disable;
ETH_InitStructure.ETH_ForwardUndersizedGoodFrames = ETH_ForwardUndersizedGoodFrames_Disable;
ETH_InitStructure.ETH_SecondFrameOperate = ETH_SecondFrameOperate_Enable;
ETH_InitStructure.ETH_AddressAlignedBeats = ETH_AddressAlignedBeats_Enable;
ETH_InitStructure.ETH_FixedBurst = ETH_FixedBurst_Enable;
ETH_InitStructure.ETH_RxDMABurstLength = ETH_RxDMABurstLength_32Beat;
ETH_InitStructure.ETH_TxDMABurstLength = ETH_TxDMABurstLength_32Beat;
ETH_InitStructure.ETH_DMAArbitration = ETH_DMAArbitration_RoundRobin_RxTx_2_1;
/*初始化以太網(wǎng),第二個參數(shù)為PHY芯片地址*/
ETH_Init(Ð_InitStructure, 0x01); // Realtek820 PHY地址通常為0x01
//接收描述符初始化
rx_descr_init();
//發(fā)送描述符初始化
tx_descr_init();
/* 使能正�?傊袛嗪徒邮罩袛�*/
ETH_DMAITConfig(ETH_DMA_IT_NIS | ETH_DMA_IT_R, ENABLE);
//使能發(fā)送和接收
ETH->DMAOMR |= DOMR_ST | DOMR_SR;
ETH->MACCR |= MCR_RE | MCR_TE;
//配置MAC地址,否則只能收到廣播數(shù)據(jù)
ETH_MACAddressConfig(ETH_MAC_Address0, own_hw_adr);
// 使能和禁止以太網(wǎng)中斷
void int_enable_eth(void) {
/* Ethernet Interrupt Enable function. */
NVIC->ISER[1] = 1 << 29;
void int_disable_eth(void) {
/* Ethernet Interrupt Disable function. */
NVIC->ICER[1] = 1 << 29;
// 發(fā)送一幀數(shù)據(jù)(提供給RL-TCPnet的接口函數(shù))
void send_frame(OS_FRAME *frame) {
U32 *sp, *dp;
U32 i, j;
j = TxBufIndex;
/* 等待之前數(shù)據(jù)發(fā)送完 */
while (Tx_Desc[j].CtrlStat & DMA_TX_OWN);
sp = (U32 *)&frame->data[0];
dp = (U32 *)Tx_Desc[j].Addr;
/* 拷貝需要發(fā)送的數(shù)據(jù)到發(fā)送描述符指定的內(nèi)存 */
for (i = (frame->length + 3) >> 2; i; i--) {
*dp++ = *sp++;
//發(fā)送數(shù)據(jù)量
Tx_Desc[j].Size = frame->length;
//修改發(fā)送描述符屬于DMA
Tx_Desc[j].CtrlStat |= DMA_TX_OWN;
/* 往DMATPDR中寫數(shù)據(jù)開始DMA傳輸 */
if ((ETH->DMASR | DSR_TBUS) != 0) {
ETH->DMASR = DSR_TBUS;
ETH->DMATPDR = 0;
if (++j == NUM_TX_BUF) j = 0;
TxBufIndex = j;
// 以太網(wǎng)中斷服務(wù)函數(shù)(用于接收以太網(wǎng)數(shù)據(jù))
void ETH_IRQHandler(void) {
/* Ethernet Controller Interrupt function. */
OS_FRAME *frame;
U32 i, RxLen;
U32 *sp, *dp;
// 接收描述符初始化
void rx_descr_init() {
// 初始化代碼
// 發(fā)送描述符初始化
void tx_descr_init() {
// 初始化代碼
// 配置MAC地址
void ETH_MACAddressConfig(ETH_MAC_Address_TypeDef* MACAddr, uint8_t *Addr) {
// 配置代碼
// 以太網(wǎng)硬件重置
void ETH_SoftwareReset() {
// 重置代碼
// 檢查重置狀態(tài)
uint32_t ETH_GetSoftwareResetStatus() {
// 檢查狀態(tài)代碼
return 0;
// 以太網(wǎng)初始化
void ETH_Init(ETH_InitTypeDef* Init, uint8_t PhyAddress) {
// 初始化代碼
// 以太網(wǎng)中斷配置
void ETH_DMAITConfig(uint32_t DMA_IT, FunctionalState NewState) {
// 中斷配置代碼
// 以太網(wǎng)MAC地址配置
// MAC地址配置代碼
// 以太網(wǎng)軟件重置
// 軟件重置代碼
// 以太網(wǎng)DMA中斷配置
// DMA中斷配置代碼
// 以太網(wǎng)DMA傳輸緩沖區(qū)配置
void ETH_DMATxDescChainInit(ETH_DMADescTypeDef *DMATxDescTab, uint8_t *TxBuff, uint32_t TxBuffCount) {
// DMA傳輸緩沖區(qū)配置代碼
// 以太網(wǎng)DMA接收緩沖區(qū)配置
void ETH_DMARxDescChainInit(ETH_DMADescTypeDef *DMARxDescTab, uint8_t *RxBuff, uint32_t RxBuffCount) {
// DMA接收緩沖區(qū)配置代碼
// 以太網(wǎng)DMA傳輸描述符初始化
void ETH_DMATxDescInit(ETH_DMADescTypeDef *DMATxDesc, uint32_t BufferAddr, uint32_t BufferLength, uint32_t IOC) {
// DMA傳輸描述符初始化代碼
// 以太網(wǎng)DMA接收描述符初始化
void ETH_DMARxDescInit(ETH_DMADescTypeDef *DMARxDesc, uint32_t BufferAddr, uint32_t BufferLength) {
// DMA接收描述符初始化代碼
// DMA傳輸緩沖區(qū)配置代碼
// DMA接收緩沖區(qū)配置代碼
// DMA傳輸描述符初始化代碼
// DMA接收描述符初始化代碼
// 以太網(wǎng)DMA中斷配置
// 中斷配置代碼
// DMA傳輸緩沖區(qū)配置代碼
// DMA接收緩沖區(qū)配置代碼
// DMA傳輸描述符初始化代碼
// DMA接收描述符初始化代碼
需要根據(jù)Realtek820的數(shù)據(jù)手冊來配置PHY寄存器,以確保PHY與STM32F107VCT6芯片正確通信。您還需要實現(xiàn)`rx_descr_init`、`tx_descr_init`、`ETH_MACAddressConfig`、`ETH_SoftwareReset`、`ETH_GetSoftwareResetStatus`、`ETH_Init`、`ETH_DMAITConfig`、`ETH_DMATxDescChainInit`、`ETH_DMARxDescChainInit`、`ETH_DMATxDescInit`、`ETH_DMARxDescInit`等函數(shù)的具體實現(xiàn)。這些函數(shù)的具體實現(xiàn)取決于您的硬件配置和需求。 |
