80黑幣
各位大佬們幫忙看下,如圖是接收引腳波形(自定義協(xié)議發(fā)射的),數(shù)碼管單獨(dú)配置輸出是可以點(diǎn)亮的,目前我想測(cè)試下接收到的數(shù)據(jù),接收到就全部點(diǎn)亮,結(jié)果發(fā)現(xiàn)不能點(diǎn)亮,幫忙看下是不是解碼部分有問題。
void main(void)
GPIO_INIT();
DISI();
Timer0_INIT();
ENI();
CLRWDT();
if(POWER==0)
flag1=0;
PIN1=PIN2=PIN3=PIN4=PIN5=PIN6=PIN7=PIN8=PIN9=PIN10=0;
if(K1_SDA==0)
WDTEN=0; // 關(guān)閉看門狗
BWUCON = 0X08;
PCON1 = 0X80; // 關(guān)閉定時(shí)器0中斷
INTE = 0X02; // 打開io變化中斷
INTF=0;
while(RX==0)
SLEEP();
K1_SDA = 1;
POWER=1;
ABPLCON = 0XFF;
IOSTA = 0XFD;
PORTA = 0X00;
BPHCON = 0XFF;
IOSTB = 0XFF;
PORTB = 0X00;
T0MD = 0X02; // 打開看門狗
PCON1 = 0X81; // 打開定時(shí)器0中斷
INTE = 0X01; // 關(guān)閉外部中斷打開定時(shí)器0中斷
Timer1_INIT();
WDTEN=1;
CLRWDT();
CLRWDT();
if(lvd==11)
if(flag1==0)
if(PWM_C<3)
if(PWM_H1<1000){lvd=11;}
else if(PWM_H1<2000){PIN9=PIN10=1;}
else{PWM_H1=0;PWM_C++;}
flag1=1;
if(flag1==1)
POWER=0;
if(temp==1){PIN9=1;}
display();
LED_SCAN();
des_sever();
if(temp==1)
IOSTA = 0X00;
IOSTB = 0X08;
PIN1=PIN2=PIN3=PIN4=PIN5=PIN6=PIN7=PIN8=1;
PIN9=PIN10=0;
//display(temp);
//LED_SCAN();
void isr(void) __interrupt(0)
if(INTFbits.T0IF)
RfDuty_32Bit();
TMR0 = 163;
INTF= (unsigned char)~(C_INT_TMR0); // Clear T0IF flag bit
if(INTFbits.T1IF)
if(RX){DIR_InCont++;}
INTF= (unsigned char)~(C_INT_TMR1); // 清除T0IF標(biāo)志位
//------------------------------------------解碼-------------------------------------//
void RfDuty_32Bit(void)
if(IR_State==0)
DIR_InCont=0;
T1CR1=0x03;
IR_State=1;
else if(IR_State==1)
IR_Timer=DIR_InCont;
DIR_InCont=0;
if((IR_Timer >= 20) && (IR_Timer <= 30))
IR_State=2;
IR_State=1;
else if(IR_State==2)
DIR_InCont=0;
if((IR_Timer >= 4) && (IR_Timer <= 8))
IR_Data[IR_pData/8]&=~(0x01<<(IR_pData%8)); //0
IR_pData++;
else if((IR_Timer >= 10) && (IR_Timer <= 14))
IR_Data[IR_pData/8]|=(0x01<<(IR_pData%8)); //1
IR_pData++;
IR_pData=0;
IR_State=1;
if(IR_pData>=16)
IR_pData=0;
RX_NUM=IR_Data[0];
RX_LVD=IR_Data[1];
T1CR1=0x02;
IR_State=0;
void des_sever(void)
//unsigned char dsp_code[14]={0X3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0xF0,0X1F,0XFF};//0111 0111
if(RX_NUM==0x01){temp=1;}
else if(RX_NUM==0x02){temp=10;}
else if(RX_NUM==0x03){temp=2;}
else if(RX_NUM==0x04){temp=3;}
else if(RX_NUM==0x05){temp=4;}
else if(RX_NUM==0x06){temp=5;}
else if(RX_NUM==0x07){temp=6;}
else if(RX_NUM==0x08){temp=7;}
else if(RX_NUM==0x09){temp=8;}
else if(RX_NUM==0x0A){temp=9;}
else if(RX_NUM==0x0B){temp=10;}
if(RX_LVD==0x01){lvd=11;}
else if(RX_LVD==0x02){lvd=12;}
else if(RX_LVD==0x03){lvd=12;}
else if(RX_LVD==0x04){lvd=0;}
else if(RX_LVD==0x05){lvd=8;}
else if(RX_LVD==0x60){lvd=13;}
//------------------------------------------定時(shí)器-------------------------------------//
void Timer0_INIT(void)
PCON1 = C_TMR0_Dis;
TMR0 = 0;
T0MD = C_PS0_TMR0 | C_PS0_Div4;
INTE = C_INT_TMR0 | C_INT_TMR1;
PCON1 = C_TMR0_En;
void Timer1_INIT(void)
TMRH = 0;
TMR1 = 97; //50us
T1CR1 = 0x02;
T1CR2 = C_TMR1_ClkSrc_Inst | C_PS1_Div4;
(27.42 KB, 下載次數(shù): 0)
2024-11-25 20:48 上傳
接收引腳收到的波形
最佳答案
查看完整內(nèi)容
RfDuty_32Bit();應(yīng)該用RX腳的下降沿來觸發(fā),而不是定時(shí)器
