這個(gè)工程不是缺少庫(kù)那么簡(jiǎn)單,麻煩大佬們幫忙看下。
1. 工程 test_3rdlib 是可以編譯的,它是直接將所有代碼加進(jìn)去直接編譯的。
2. test_3rdlib_app依賴(lài)動(dòng)態(tài)庫(kù) test_3rdlib_shared的,這兩個(gè)工程都編譯不過(guò)。 test_3rdlib_shared依賴(lài)第三方庫(kù),第三方庫(kù)見(jiàn)out目錄。
3. test_3rdlib_static 這個(gè)動(dòng)態(tài)庫(kù)也是可以編譯的。
鏈接: https://pan.baidu.com/s/1AHPhQ-33o3mtCbFPH418WA?pwd=4hrf 提取碼: 4hrf
報(bào)錯(cuò)的工程是 test_3rdlib_app 和 test_3rdlib_shared。
3:58:41:318 1>MSVCRTD.lib(init.obj) : error LNK2019: unresolved external symbol _CrtDbgReport referenced in function _CRT_RTC_INIT
13:58:41:318 1>MSVCRTD.lib(init.obj) : error LNK2019: unresolved external symbol _CrtDbgReportW referenced in function _CRT_RTC_INITW
13:58:41:318 1>MSVCRTD.lib(error.obj) : error LNK2019: unresolved external symbol strcpy_s referenced in function "void __cdecl _RTC_StackFailure(void *,char const *)" (?_RTC_StackFailure@@YAXPEAXPEBD@Z)
13:58:41:318 1>MSVCRTD.lib(error.obj) : error LNK2019: unresolved external symbol strcat_s referenced in function "void __cdecl _RTC_StackFailure(void *,char const *)" (?_RTC_StackFailure@@YAXPEAXPEBD@Z)
13:58:41:318 1>MSVCRTD.lib(error.obj) : error LNK2019: unresolved external symbol __stdio_common_vsprintf_s referenced in function _vsprintf_s_l
13:58:41:318 1>MSVCRTD.lib(error.obj) : error LNK2001: unresolved external symbol __C_specific_handler_noexcept
13:58:41:318 1>MSVCRTD.lib(pdblkup.obj) : error LNK2019: unresolved external symbol _wmakepath_s referenced in function "int __cdecl GetPdbDllPathFromFilePath(wchar_t const *,wchar_t *,unsigned __int64)" (?GetPdbDllPathFromFilePath@@YAHPEB_WPEA_W_K@Z)
13:58:41:318 1>MSVCRTD.lib(pdblkup.obj) : error LNK2019: unresolved external symbol _wsplitpath_s referenced in function "int __cdecl GetPdbDllPathFromFilePath(wchar_t const *,wchar_t *,unsigned __int64)" (?GetPdbDllPathFromFilePath@@YAHPEB_WPEA_W_K@Z)
13:58:41:318 1>MSVCRTD.lib(pdblkup.obj) : error LNK2019: unresolved external symbol wcscpy_s referenced in function "int __cdecl GetPdbDllPathFromFilePath(wchar_t const *,wchar_t *,unsigned __int64)" (?GetPdbDllPathFromFilePath@@YAHPEB_WPEA_W_K@Z)
13:58:41:318 1>MSVCRTD.lib(pdblkup.obj) : error LNK2019: unresolved external symbol __vcrt_GetModuleFileNameW referenced in function "struct HINSTANCE__ * __cdecl GetPdbDll(void)" (?GetPdbDll@@YAPEAUHINSTANCE__@@XZ)
13:58:41:318 1>MSVCRTD.lib(pdblkup.obj) : error LNK2019: unresolved external symbol __vcrt_GetModuleHandleW referenced in function "struct HINSTANCE__ * __cdecl GetPdbDll(void)" (?GetPdbDll@@YAPEAUHINSTANCE__@@XZ)
13:58:41:318 1>MSVCRTD.lib(pdblkup.obj) : error LNK2019: unresolved external symbol __vcrt_LoadLibraryExW referenced in function "struct HINSTANCE__ * __cdecl GetPdbDll(void)" (?GetPdbDll@@YAPEAUHINSTANCE__@@XZ)
13:58:41:318 1>BuildSrc\Debug\test_3rdlib.dll : fatal error LNK1120: 17 unresolved externals
