因為在C語言,你在做數(shù)組到時候他就會帶入,這一個程序。
- ; This file is part of the CX51 Compiler package
- ; Copyright (c) 1988-2003 Keil Elektronik GmbH and Keil Software, Inc.
- ; *** <<< Use Configuration Wizard in Context Menu >>> ***
- ; INIT_MX.A51: This code is executed, if the application program contains
- ; initialized variables at file level.
- ; If you are using uVision2, just add the file as last file to your project.
- ; *** IMPORTANT NOTE ***: this file needs to be the last file of the linker
- ; input list. If you are using uVision2 this file should be therefore the
- ; last file in your project tree.
- ; To translate this file use Ax51 with the following invocation:
- ; AX51 INIT_MX.A51
- ; To link the modified INIT_MX.OBJ file to your application use the following
- ; linker invocation:
- ; LX51 your object file list, INIT.OBJ controls
- ; User-defined Watch-Dog Refresh.
- ; If the C application contains many initialized variables uses a watchdog
- ; it might be possible that the user has to include a watchdog refresh into
- ; the initialization process. The watchdog refresh routine can be included
- ; in the following MACRO and can alter all CPU registers except
- ; DPTR.
- WATCHDOG MACRO
- ; Include any Watchdog refresh code here
- ENDM
- ;<h> Far Memory Support
- ; If the C application contains variables in the far memory space that are
- ; initialized, you need to set the following define to 1.
- ; --- Set XBANK = 1 when far variables should be initialized
- ; <q> XBANK: Initialize variables in far memory
- ; <i>If the C application contains variables in the far memory space that are
- ; <i>initialized, you need to check this box.
- $SET (XBANK = 1)
- ;</h>
- ; Standard SFR Symbols
- ACC DATA 0E0H
- DPL DATA 82H
- DPH DATA 83H
- NAME ?C_INIT
- ?C_C51STARTUP SEGMENT CODE
- ?C_INITSEG SEGMENT CODE ; Segment zur Initialisierung
- INIT_IorP MACRO
- IorPData: ; If CY=1 PData Values
- CLR A
- MOVC A,@A+DPTR
- INC DPTR
- MOV R0,A ; Start Address
- IorPLoop: CLR A
- MOVC A,@A+DPTR
- INC DPTR
- JC PData
- MOV @R0,A
- SJMP Common
- PData: MOVX @R0,A
- Common: INC R0
- DJNZ R7,IorPLoop
- JMP Loop
- ENDM
- EXTRN CODE (MAIN)
- PUBLIC ?C_START
- RSEG ?C_C51STARTUP
- INITEND: EJMP MAIN
- $IF (XBANK = 0)
- INIT_IorP
- $ENDIF
- Bits: CLR A
- MOVC A,@A+DPTR
- INC DPTR
- MOV R0,A
- ANL A,#007H
- ADD A,#Table-LoadTab
- XCH A,R0
- CLR C
- RLC A ; Bit Condition to Carry
- SWAP A
- ANL A,#00FH
- ORL A,#20H ; Bit Address
- XCH A,R0 ; convert to Byte Addressen
- MOVC A,@A+PC
- LoadTab: JC Setzen
- CPL A
- ANL A,@R0
- SJMP BitReady
- Setzen: ORL A,@R0
- BitReady: MOV @R0,A
- DJNZ R7,Bits
- SJMP Loop
- Table: DB 00000001B
- DB 00000010B
- DB 00000100B
- DB 00001000B
- DB 00010000B
- DB 00100000B
- DB 01000000B
- DB 10000000B
- ?C_START:
- MOV DPTR,#?C_INITSEG
- Loop:
- WATCHDOG
- CLR A
- MOV R6,#1
- MOVC A,@A+DPTR
- JZ INITEND
- INC DPTR
- MOV R7,A
- ANL A,#3FH
- JNB ACC.5,NOBIG
- ANL A,#01FH
- MOV R6,A
- CLR A
- MOVC A,@A+DPTR
- INC DPTR
- JZ NOBIG
- INC R6
- NOBIG: XCH A,R7
- ; ---- Init for far Variables
- $IF (XBANK = 1)
- ANL A,#0E0H
- CJNE A,#0E0H,NOHDATA
- HPTRINIT: CLR A
- MOVC A,@A+DPTR
- MOV R3,A
- INC DPTR
- CLR A
- MOVC A,@A+DPTR
- MOV R2,A
- INC DPTR
- CLR A
- MOVC A,@A+DPTR
- MOV R1,A
- INC DPTR
- HLOOP: CLR A
- MOVC A,@A+DPTR
- EMOV @PR0,A
- INC DPTR
- INC R1
- MOV A,R1
- JNZ HINC
- INC R2
- HINC: DJNZ R7,HLOOP
- DJNZ R6,HLOOP
- SJMP Loop
- NOHDATA:
- $ENDIF
- ANL A,#0C0H ; Typ is in Bit 6 and Bit 7
- ADD A,ACC
- JZ IorPData
- JC Bits
- XdataMem: CLR A
- MOVC A,@A+DPTR
- INC DPTR
- MOV R2,A ; High
- CLR A
- MOVC A,@A+DPTR
- INC DPTR
- MOV R0,A ; LOW
- XLoop: CLR A
- MOVC A,@A+DPTR
- INC DPTR
- XCH A,R0
- XCH A,DPL
- XCH A,R0
- XCH A,R2
- XCH A,DPH
- XCH A,R2
- MOVX @DPTR,A
- INC DPTR
- XCH A,R0
- XCH A,DPL
- XCH A,R0
- XCH A,R2
- XCH A,DPH
- XCH A,R2
- DJNZ R7,XLoop
- DJNZ R6,XLoop
- SJMP Loop
- $IF (XBANK = 1)
- INIT_IorP
- $ENDIF
- RSEG ?C_INITSEG
- DB 0
- ; STRUCTURE OF THE INITIALIZATION INFORMATION
- ; This section describes the initialization data generated by C51 for
- ; explicit variable initializations (in segment ?C_INITSEC).
- ; Explicit variable initilizations at C source level are stored by C51 in
- ; the segment ?C_INITSEC. All partial segments are combined at linker level
- ; to one segment. The segment end value DB 0 is taken from this library module
- ; INIT.A51.
- ; Structure of the ?C_INITSEC information:
- ; Info (see below) [BYTE] ----+ repeated
- ; additional info [BYTES depend on Info] ----+ repeated
- ; 0x00 [BYTE] end of list mark
- ; Info has the following format:
- ; Bit 7 6 5 4 3 2 1 0
- ; Info T T B L L L L L T=Type B=BIGBIT L=LENGTH
- ; If BIGBIT is set, another LENGTH BYTE FOLLOWS. The LENGTH
- ; info of the first byte is then the HIGH part.
- ; Typ is one of the following:
- ; 0 := IDATA init values; the following bytes follow:
- ; - 1 byte address
- ; - init data bytes according LENGTH specification
- ; 1 := XDATA init values; the following bytes follow:
- ; - 2 byte address (high byte first)
- ; 2 := PDATA init values; the following bytes follow:
- ; 3, BIGBIT=0 := BIT init values; the followign bytes follow:
- ; - 1 byte for each bit according LENGTH specification
- ; this byte has the following format:
- ; I B B B B B B B I := state of the bit
- ; B := bit address
- ; 3, BIGBIT=1 := HDATA init values; the following bytes follow:
- ; - another LENGTH byte (since BIGBIT is always 1)
- ; - 3 byte address (MSB first)
- ; - data bytes according LENGTH specification
- END
