查看: 1383|回復(fù): 2
求助大佬Arduino一直報錯,未正確引用 WiFi 庫如何解決
ID:1116346 發(fā)表于 2025-1-1 15:03 | 顯示全部樓層 |閱讀模式
arduino版本為2.3.4,開發(fā)板esp32-wroom-32e, ESP32-D0WD-V3 芯片。arduino重新下載安裝了幾次庫也是還是報這個錯誤如何解決
報錯內(nèi)容如下c:\Users\cxfqa\Documents\Arduino\libraries\ThingsCloud_ESP_SDK\src\ThingsCloudMQTT.cpp: In member function 'bool ThingsCloudMQTT::handleWiFi()':
c:\Users\cxfqa\Documents\Arduino\libraries\ThingsCloud_ESP_SDK\src\ThingsCloudMQTT.cpp:207:9: error: 'WiFi' was not declared in this scope
  207 |         WiFi.disconnect(true);
c:\Users\cxfqa\Documents\Arduino\libraries\ThingsCloud_ESP_SDK\src\ThingsCloudMQTT.cpp:214:29: error: 'WiFi' was not declared in this scope
  214 |     bool isWifiConnected = (WiFi.status() == WL_CONNECTED);
c:\Users\cxfqa\Documents\Arduino\libraries\ThingsCloud_ESP_SDK\src\ThingsCloudMQTT.cpp:214:46: error: 'WL_CONNECTED' was not declared in this scope; did you mean 'MQTT_CONNECTED'?
      |                                              MQTT_CONNECTED
c:\Users\cxfqa\Documents\Arduino\libraries\ThingsCloud_ESP_SDK\src\ThingsCloudMQTT.cpp:235:30: error: 'WL_CONNECT_FAILED' was not declared in this scope; did you mean 'MQTT_CONNECT_FAILED'?
  235 |         if (WiFi.status() == WL_CONNECT_FAILED || millis() - _lastWifiConnectiomAttemptMillis >= _wifiReconnectionAttemptDelay)
      |                              MQTT_CONNECT_FAILED
c:\Users\cxfqa\Documents\Arduino\libraries\ThingsCloud_ESP_SDK\src\ThingsCloudMQTT.cpp: In member function 'bool ThingsCloudMQTT::handleMQTT()':
c:\Users\cxfqa\Documents\Arduino\libraries\ThingsCloud_ESP_SDK\src\ThingsCloudMQTT.cpp:330:17: error: 'WiFi' was not declared in this scope
  330 |                 WiFi.disconnect(true);
c:\Users\cxfqa\Documents\Arduino\libraries\ThingsCloud_ESP_SDK\src\ThingsCloudMQTT.cpp: In member function 'void ThingsCloudMQTT::onWiFiConnectionEstablished()':
c:\Users\cxfqa\Documents\Arduino\libraries\ThingsCloud_ESP_SDK\src\ThingsCloudMQTT.cpp:364:79: error: 'WiFi' was not declared in this scope
  364 |         Serial.printf("WiFi: Connected (%fs), ip : %s \n", millis() / 1000.0, WiFi.localIP().toString().c_str());
c:\Users\cxfqa\Documents\Arduino\libraries\ThingsCloud_ESP_SDK\src\ThingsCloudMQTT.cpp: In member function 'void ThingsCloudMQTT::onWiFiConnectionLost()':
c:\Users\cxfqa\Documents\Arduino\libraries\ThingsCloud_ESP_SDK\src\ThingsCloudMQTT.cpp:380:9: error: 'WiFi' was not declared in this scope
  380 |         WiFi.disconnect(true);
c:\Users\cxfqa\Documents\Arduino\libraries\ThingsCloud_ESP_SDK\src\ThingsCloudMQTT.cpp: In member function 'void ThingsCloudMQTT::connectToWifi()':
c:\Users\cxfqa\Documents\Arduino\libraries\ThingsCloud_ESP_SDK\src\ThingsCloudMQTT.cpp:652:5: error: 'WiFi' was not declared in this scope
  652 |     WiFi.mode(WIFI_STA);
c:\Users\cxfqa\Documents\Arduino\libraries\ThingsCloud_ESP_SDK\src\ThingsCloudMQTT.cpp:652:15: error: 'WIFI_STA' was not declared in this scope; did you mean 'WIFI_IF_STA'?
      |               WIFI_IF_STA
exit status 1
Compilation error: exit status 1
ID:277550 發(fā)表于 2025-1-1 20:36 | 顯示全部樓層
開發(fā)板的庫不對。
ID:88256 發(fā)表于 2025-1-2 09:52 | 顯示全部樓層
有可能是庫版本不對,有一個笨笨的辦法,打開WiFi庫的示例,對比各個函數(shù)的使用方法,將程序中的函數(shù)改成示例中的用法。
