2025-1-8 22:55 上傳
#include <intrins.h>
#include "math.h"
//“程序開發(fā)調(diào)試設(shè)置項(xiàng)”
#define DY_DELAY 10 // 設(shè)置每一個(gè)點(diǎn)顯示的時(shí)間長度(1~20)
float VCC = 3.3; // 設(shè)置基準(zhǔn)電壓
float Rp = 100000.0; // 設(shè)置上拉電阻
float Bx = 3950.0; // 設(shè)置熱敏電阻B值
float Rt; // 熱敏電阻的實(shí)際阻值
float Tk2 = 273.15 + 25.0;
float Ka = 273.15;
float vol; // 設(shè)置測量電壓
data unsigned char temp; // 實(shí)際溫度
data unsigned char temp_set = 0; // 設(shè)置溫度
data unsigned char temp_set1 = 150; // 設(shè)置溫度2
data unsigned char temp_set2 = 0; // 設(shè)置溫度2
float DTADC;
sbit DIG1 = P5 ^ 5;
sbit DIG2 = P1 ^ 2;
sbit SEG_A = P3 ^ 7;
sbit SEG_B = P3 ^ 2;
sbit SEG_C = P3 ^ 3;
sbit SEG_D = P3 ^ 5;
sbit SEG_E = P3 ^ 4;
sbit SEG_F = P3 ^ 6;
sbit SEG_G = P1 ^ 1;
sbit BUTTON1 = P1 ^ 6;
sbit BUTTON2 = P1 ^ 5;
sbit BUTTON3 = P1 ^ 4;
sbit RESET = P5 ^ 4;
sbit RELAY = P1 ^ 3;
/*Define ADC operation const for ADC_CONTR*/
#define ADC_POWER 0x80 //ADC電源控制位
#define ADC_FLAG 0x20 //ADC完成標(biāo)志位
#define ADC_START 0x40 //ADC啟動(dòng)控制位
#define ADC_SPEEDLL 0x00 //ADC速度選擇
bit flag = 0;
typedef unsigned char BYTE;
data unsigned char DY_PWM; // 顯示亮度
unsigned char code disdata[] = {
0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90 // 數(shù)碼管段碼表(0~9)
void delay(unsigned int a) { // 用于點(diǎn)掃描的延時(shí)
unsigned int i;
while (--a != 0) {
for (i = 0; i < DY_DELAY; i++);
void delay1ms(unsigned int a) { // 1ms延時(shí)程序
unsigned int i;
while (--a != 0) {
for (i = 0; i < 24000; i++);
void dis_off(void) {
DIG1 = 1; // 關(guān)閉所有數(shù)碼管
DIG2 = 1;
SEG_A = 0;
SEG_B = 0;
SEG_C = 0;
SEG_D = 0;
SEG_E = 0;
SEG_F = 0;
SEG_G = 0;
delay(10 - DY_PWM);
void diplay_data (unsigned char digit, unsigned char value) {
DIG1 = 0;
DIG2 = 0;
// 設(shè)置段碼(共陽極數(shù)碼管,段碼為高電平點(diǎn)亮)
SEG_A = (value & 0x01) ? 0 : 1;
SEG_B = (value & 0x02) ? 0 : 1;
SEG_C = (value & 0x04) ? 0 : 1;
SEG_D = (value & 0x08) ? 0 : 1;
SEG_E = (value & 0x10) ? 0 : 1;
SEG_F = (value & 0x20) ? 0 : 1;
SEG_G = (value & 0x40) ? 0 : 1;
// 選通對(duì)應(yīng)的數(shù)碼管
if (digit == 1) {
DIG1 = 0;
} else if (digit == 2) {
DIG2 = 0;
delay(DY_DELAY); // 保持顯示時(shí)間
dis_off(); // 關(guān)閉顯示,避免重影
//void GetADCResult(BYTE ch) {
// ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ch | ADC_START;
// _nop_(); // 必須等待才能查詢
// _nop_();
// _nop_();
// _nop_();
// while (!(ADC_CONTR & ADC_FLAG)); // 等待完成標(biāo)志
// ADC_CONTR &= ~ADC_FLAG; // 關(guān)閉ADC
// uint GetADCResult(uchar CH)
ADC_CONTR=ADC_POWER|ADC_START|CH;//啟動(dòng)轉(zhuǎn)換1100 1000
_nop_();_nop_(); //小延時(shí)
while (!(ADC_CONTR & ADC_FLAG));//等待ADC轉(zhuǎn)換完成標(biāo)志置位 1010 0000
ADC_CONTR &=~ADC_FLAG; //清完成標(biāo)志
//返回十位ADC結(jié)果
void InitADC() {
P1M1 |= 0x80; // 開P1.7的ADC功能
P1M0 &= ~0x80;
ADC_RES = 0;
ADC_CONTR = ADC_POWER; // 開P1.7的ADC功能
void init(void) { // 上電初始化
// 設(shè)置I/O口工作方式
P1M0 = 0x1F; // P1.0, P1.1, P1.2, P1.3為推挽輸出,P1.4-P1.6按鍵輸入,P1.7為ADC輸入
P1M1 = 0x80; // P1.7配置為ADC輸入,其余引腳為推挽輸出或準(zhǔn)雙向口
P3M0 = 0xFC; // P3.2-P3.7為推挽輸出,P3.0和P3.1為準(zhǔn)雙向口(用于TX/RX)
P3M1 = 0x00; // 設(shè)置為準(zhǔn)雙向口
P5M0 = 0x20; // P5.4為復(fù)位引腳,P5.5為數(shù)碼管位控制(推挽輸出)
P5M1 = 0x00; // 設(shè)置為準(zhǔn)雙向口
DY_PWM = 9;
dis_off();
void process_buttons(void) {
if (BUTTON1 == 0) {
delay1ms(10); // 簡單的防抖
if (BUTTON1 == 0) {
// 處理按鍵1被按下的事件
if (BUTTON2 == 0) {
delay1ms(10);
if (BUTTON2 == 0) {
// 處理按鍵2被按下的事件
if (BUTTON3 == 0) {
delay1ms(10);
if (BUTTON3 == 0) {
// 處理按鍵3被按下的事件
if (RESET == 0) {
// 復(fù)位系統(tǒng)或執(zhí)行相應(yīng)的操作
void main (void){ //主程序
init();
InitADC(); //Init ADC sfr
DTADC=0;
temp_set=0;
delay1ms(100);
while (1){
unsigned int i;
unsigned int a;
i=i+1;
GetADCResult(6);
temp_set=ADC_RES;
GetADCResult(7);
DTADC=ADC_RES+DTADC;
DTADC=(ADC_RES<<2)+ADC_RESL +DTADC;
if(i==10)
i=0;
if(a>0) a--;
else flag=0;
DTADC=DTADC/10;
temp_set1=temp_set;
if((temp_set1>(temp_set2+2)) ||(temp_set1<(temp_set2-2))){ flag=1; a=200; }
temp_set2=temp_set1;
vol=DTADC*VCC/256;
DTADC=0;
temp_set=0;
Rt=(vol * Rp ) / (VCC-vol);
temp=1/(1/Tk2+ log(Rt/Rp)/Bx)-Ka+0.5;
if (flag == 0) { // 顯示當(dāng)前溫度
diplay_data (1, disdata[temp / 10]); // 顯示十位
diplay_data (2, disdata[temp % 10]); // 顯示個(gè)位
} else { // 顯示設(shè)置溫度
diplay_data (1, disdata[temp_set1 / 10]);
diplay_data (2, disdata[temp_set1 % 10]);
顯示溫度顯示不對(duì)是什么原因?
