查看: 854|回復(fù): 3
鉛酸蓄電池放電容量測試儀電路及軟件設(shè)計(jì)求指點(diǎn)
電路采用改變PWM占空比達(dá)到恒流放電,軟件是很簡單的算法。PROTEUS已仿真(非?D且要過好一陣虛擬示波器才能出波形)。因水平有限電路及軟件這樣設(shè)計(jì)不知是否正確,尋求意見,若能完善再DIY.
以下是源代碼
#include <reg51.h>
#include <intrins.h>
#define ulong unsigned long
/**********1602************/
sbit RS=P1^5;
sbit EN=P1^4;
sbit LCD_D4=P1^3;
sbit LCD_D5=P1^2;
sbit LCD_D6=P1^1;
sbit LCD_D7=P1^0;
sbit SW=P3^2;
sbit PWM_OUT=P3^3;
sbit FMQ=P3^7;
/*********ADC0832**********/
sbit  CS  = P3^4;
sbit  CLK = P3^5;
sbit  DI0 = P3^1;
sbit  WCS  = P3^0;
sbit  WCLK = P1^6;
sbit  WDI0 = P1^7;
unsigned char Data[8];
unsigned char Table[]="0123456789";
unsigned char hour=0;//小時(shí)
unsigned char min=0;//分鐘
unsigned char miao=0;//秒
unsigned char mstn=0;//50ms計(jì)數(shù)
bit ptt=0;//秒閃爍標(biāo)志
unsigned long AH=0;
unsigned int num=0;
/********以下是函數(shù)聲明********/
void LCD_en_write(void);//液晶使能
void LCD_by(uchar abc);//寫字節(jié)
void LCD_set_xy(uchar x, uchar y);//寫地址
void LCD_write_str(uchar X,uchar Y,uchar *s);//寫字符串
void LCD_init(void);//液晶初始化
void del_ms(uint n);//ms延時(shí)函數(shù)
void delay_5us(void);//5us延時(shí)函數(shù)
void delay_nus(uint n);//N us延時(shí)函數(shù)
void process_3(unsigned long i,unsigned char *p) ;
void display_AH(unsigned char x, unsigned char y, unsigned char *p);
void Timer0_Init(void);
void Timer1_Init(void);
void display_SJ(uchar x,uchar y,uchar hour,uchar min);//時(shí)間顯示函數(shù)
void display_V(unsigned char x, unsigned char y, uchar *p);
void display_A(unsigned char x, unsigned char y, uchar *p);
uchar V_A();//電壓/電流采集函數(shù)
uchar SET_A();//電流調(diào)節(jié)采集函數(shù)
uchar V_A(bit CH)//電壓/電流采集函數(shù)
  uchar i,dat,dat2;
  CS=0;
  _nop_();
  DI0=1;
  CLK=1;
  _nop_();
  CLK=0;
  _nop_();
   DI0=1;
  CLK=1;
  _nop_();
  CLK=0;
  _nop_();
        if(CH==0)
         DI0=0;//V
        if(CH==1)
         DI0=1;//A
  CLK=1;
  _nop_();
  CLK=0;
  DI0=1;
  dat=0;
  for(i=0;i<8;i++)
       dat<<=1;
       CLK=1;
       _nop_();
       CLK=0;
       _nop_();
       dat|=DI0;
     dat2=0;
   if(DI0==1)
     dat2=0x80;
   for(i=0;i<7;i++)
        dat2>>=1;
        CLK=1;
        _nop_();
        CLK=0;
        _nop_();
        if(DI0==1)
        dat2|=0x80;
    CS=1;
    CLK=0;
    DI0=1;
    if(dat==dat2)
    return(dat);
    return 0;
uchar SET_A()//電流調(diào)節(jié)采集函數(shù)
  uchar i,dat,dat2;
  WCS=0;
  _nop_();
  WDI0=1;
  WCLK=1;
  _nop_();
  WCLK=0;
  _nop_();
  WDI0=1;
  WCLK=1;
  _nop_();
  WCLK=0;
  _nop_();
  WDI0=0;//
  WCLK=1;
  _nop_();
  WCLK=0;
  WDI0=1;
  dat=0;
  for(i=0;i<8;i++)
       dat<<=1;
       WCLK=1;
       _nop_();
       WCLK=0;
       _nop_();
       dat|=WDI0;
     dat2=0;
   if(WDI0==1)
     dat2=0x80;
   for(i=0;i<7;i++)
        dat2>>=1;
        WCLK=1;
        _nop_();
        WCLK=0;
        _nop_();
        if(WDI0==1)
        dat2|=0x80;
    WCS=1;
    WCLK=0;
    WDI0=1;
    if(dat==dat2)
    return(dat);
    return 0;
  unsigned char q[2];
  unsigned char w[2];
  q[0]=hour/10;
  q[1]=hour%10;
  w[0]=min/10;
  w[1]=min%10;
  LCD_set_xy( x, y );
  RS=1;
  LCD_by(Table[q[0]]);
  LCD_by(Table[q[1]]);
  if(ptt==1||SW==1)
      LCD_write_str(13,0,":");//秒閃爍
      LCD_write_str(13,0," ");
  LCD_by(Table[w[0]]);
  LCD_by(Table[w[1]]);
void process_3(unsigned long i,uchar *p)
  p[0]=i/100%10;
  p[1]=i/10%10;
  p[2]=i%10;
void display_AH(unsigned char x, unsigned char y, uchar *p)
  unsigned char i;
  LCD_set_xy( x, y );
  RS=1;
  for(i=0;i<3;i++)
    if(i==2)
      LCD_write_str(12,1,".");
      LCD_by(Table[p[i]]);
  unsigned char i;
  LCD_set_xy( x, y );
  RS=1;
  for(i=0;i<3;i++)
    if(i==2)
      LCD_write_str(3,0,".");
  unsigned char i;
  LCD_set_xy( x, y );
  RS=1;
  for(i=0;i<3;i++)
    if(i==2)
      LCD_write_str(3,1,".");
     delay_5us();
     EN=1;
     delay_5us();
     EN=0;
    delay_nus(500);
    if(((abc<<0)&0x80)==0)
     LCD_D7=0;
     else LCD_D7=1;
    if(((abc<<1)&0x80)==0)
     LCD_D6=0;
     else LCD_D6=1;
    if(((abc<<2)&0x80)==0)
     LCD_D5=0;
     else LCD_D5=1;
    if(((abc<<3)&0x80)==0)
     LCD_D4=0;
     else LCD_D4=1;
    LCD_en_write();
    if(((abc<<4)&0x80)==0)
     LCD_D7=0;
     else LCD_D7=1;
    if(((abc<<5)&0x80)==0)
     LCD_D6=0;
     else LCD_D6=1;
    if(((abc<<6)&0x80)==0)
     LCD_D5=0;
     else LCD_D5=1;
    if(((abc<<7)&0x80)==0)
     LCD_D4=0;
     else LCD_D4=1;
    LCD_en_write();
void LCD_set_xy( uchar x, uchar y )
    uchar address;
    if (y == 0) address = 0x80 + x;
    address = 0xc0 + x;
    RS=0;
    LCD_by(address);
    LCD_set_xy(X,Y);
    RS=1;
    while(*s)
       LCD_by(*s);
       s++;
void LCD_init(void)
    RS=0;
    del_ms(500);
    LCD_by(0x30);
    del_ms(60);
    LCD_by(0x30);
    del_ms(10);
    LCD_by(0x30);
    del_ms(10);
    LCD_by(0x02);
    del_ms(10);
    LCD_by(0x28);
    del_ms(10);
    LCD_by(0x08);
    del_ms(10);
    LCD_by(0x01);
    del_ms(10);
    LCD_by(0x06);
    del_ms(10);
    LCD_by(0x0C);
    del_ms(100);
void delay_nus(uint n)//N us延時(shí)函數(shù)
   uint i=0;
   for (i=0;i<n;i++){;}
void delay_5us(void)//@12.000MHz//5us延時(shí)函數(shù)
   unsigned char data i;
   _nop_();
   _nop_();
   i = 12;
   while (--i);
void del_ms(uint n)//ms延時(shí)函數(shù)
   uchar j;
   while(n--)
  {for(j=0;j<125;j++);}
void Timer1_Init(void)                //50毫秒@12.000MHz
        TMOD &= 0x0F;
        TL1 = 0xB0;
        TH1 = 0x3C;
        TF1 = 0;
void Timer0_Init(void)                //4微秒@12.000MHz
        TMOD &= 0xF0;
        TL0 = 0xFC;
        TH0 = 0xFF;
        TF0 = 0;
void timer1(void) interrupt 3
      TL1 = 0xB0;
      TH1 = 0x3C;
      TF1 = 0;
      mstn++;
      if(mstn==20)
          mstn=0;
          miao++;
          ptt=~ptt;
          if(miao==60)
               miao=0;
               min++;
               if(min==60)
                   min=0;
                   hour++;
                   if(hour==100)
                       hour=100;
void timer0(void) interrupt 1
     static unsigned char count=0;
     TL0 = 0xFC;                //4us
     TH0 = 0xFF;
     TF0=0;
     count++;
     if(count>=255)count=0;//4us*255=1020us
     if(count>=num)PWM_OUT=1;//改變占空比
     else PWM_OUT=0;//調(diào)整電流
void main(void)
         uchar Set_A=0;
         uchar Batt_A=0;
         uchar Batt_V=0;
         uchar A_A=0;
         uchar V_V=0;
         ulong AH=0;
         LCD_init();
         del_ms(10);
         Timer0_Init();
         del_ms(10);
         Timer1_Init();
         del_ms(10);
         FMQ=1;
         PWM_OUT=1;
         ET0=1;
         ET1=1;
         EA=1;
                  Set_A=SET_A();//電流調(diào)節(jié)
                  V_V=V_A(0);
                  Batt_V=V_V*200./255;//電池電壓
                  A_A=V_A(1);
                  Batt_A=A_A*200./255;//放電電流
                  if(SW==1)//停止
                          TR0=0;
                          TR1=0;
                          PWM_OUT=1;//放電MOS管截止
                  if(SW==0)//開始
                          TR0=1;
                          TR1=1;
                          num=num+(Set_A-A_A)/2;//恒流放電
                    if(V_V<=108)//12V電池放電截止
                          //        while(1)//加上這段仿真會(huì)停止
                                //          TR0=0;
                                //          TR1=0;
                                //          PWM_OUT=1;
                                //          FMQ=0;//蜂鳴器響
                                AH=hour*60+min;//放電容量計(jì)算
                                AH*=Batt_A;
                                AH/=60;
                           display_SJ(11,0,hour,min);//時(shí)間
                          process_3(AH,Data);
                          display_AH(10,1,Data);//容量
                          LCD_write_str(14,1,"AH");
                          process_3(Batt_V,Data);
                          display_V(1,0,Data);//電壓
                          LCD_write_str(5,0,"V");
                          process_3(Batt_A,Data);
                          display_A(1,1,Data);//電流
                          LCD_write_str(5,1,"A");
鉛酸蓄電池放電容量測試儀.zip
167.08 KB, 下載次數(shù): 0, 下載積分: 黑幣 -5
收藏收藏2 分享淘帖 頂 踩
ID:469589 發(fā)表于 2025-2-8 13:54 | 只看該作者
R5、R9對于12V不構(gòu)成短路嗎???
ID:1136941 發(fā)表于 2025-2-9 11:07 | 只看該作者
GlenXu 發(fā)表于 2025-2-8 13:54
12V/R5+R9約等于24A(峰值),1ms周期內(nèi)改變占空比就可改變平均電流,我是這樣考慮的,不知道對不對。
ID:1136941 發(fā)表于 2025-2-10 10:37 | 只看該作者
12V/R5+R9=24A(峰值電流),改變占空比也就改變了平均電流,我是這樣考慮的,不知道對不對。
