查看: 786|回復(fù): 1
51單片機(jī)+TM1652 5位LED二鍵增減計(jì)數(shù)器
ID:33548 發(fā)表于 2025-3-8 22:24 | 顯示全部樓層 |閱讀模式
用模塊廠家資料+豆包+自己修改生成的STC89C51單片機(jī)+TM1652 5位LED二鍵增減計(jì)數(shù)器,實(shí)際調(diào)試OK,獻(xiàn)給大家。
//51單片機(jī)+TM1652二按鍵增減計(jì)數(shù)5位LED顯示C代碼//
//普通顯示,無(wú)中斷,調(diào)試OK
#include "REG51.h"
unsigned char KEY_NUM = 0;
typedef unsigned char u8;
typedef unsigned int u16;
u16 count = 0;    //按鍵計(jì)數(shù)值
sbit up = P3^6;   //增加按鍵
sbit down = P3^7;     //減少按鍵
sbit D_out = P0^0;    //模擬UART數(shù)據(jù)輸出端,連接TM1652數(shù)據(jù)輸入端D_in
const u8 CODE[16] = {0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F, 0x77, 0x7c, 0x39, 0x5e, 0x79, 0x71};  //共陰數(shù)碼管0~F字型碼
void Delay52us()  //@11.0592MHz
    unsigned char i;
    i = 21;
    while (--i);
void Delay5ms()  //@11.0592MHz
    unsigned char i, j;
    i = 9;
    j = 244;
    do
        while (--j);
    } while (--i);
void Delay104us()  //@11.0592MHz
    unsigned char i;
    i = 45;
    while (--i);
void tm1652_send_data(u8 sdat)    //向TM1652發(fā)送數(shù)據(jù)
    unsigned char i = 0, sfalg = 0;
    //起始位
    D_out = 0;
    Delay52us();    //保持52us
    //發(fā)送8位數(shù)據(jù)
    for (i = 0; i < 8; i++)
        if (sdat & 0x01)
            D_out = 1;
            sfalg++;
            D_out = 0;
        Delay52us();
        sdat >>= 1;
    //校驗(yàn)位,按照發(fā)送數(shù)據(jù)中1的個(gè)數(shù)來(lái)判斷
    if (sfalg % 2 == 0)
        D_out = 1;
        D_out = 0;
    Delay52us();
    //停止位
    D_out = 1;
    Delay104us();
void TM_Digtal_Display(u16 num)
    tm1652_send_data(0x08);
    // 確保能正確顯示五位數(shù)
    tm1652_send_data(CODE[num / 10000]);
    tm1652_send_data(CODE[num % 10000 / 1000]);
    tm1652_send_data(CODE[num % 1000 / 100]);
    tm1652_send_data(CODE[num % 100 / 10]);
    tm1652_send_data(CODE[num % 10]);
    Delay5ms();
    tm1652_send_data(0x18);        //向TM1652發(fā)送顯示控制命令
    tm1652_send_data(0xFE);      //設(shè)置位占空比為 15/16,設(shè)置段驅(qū)動(dòng)電流為 8/8,最大亮度。
// 延時(shí)函數(shù),用于按鍵消抖
void delay(unsigned int time)
    unsigned int i, j;
    for (i = 0; i < time; i++)
        for (j = 0; j < 123; j++);
//主函數(shù)
    u16 delaytick = 0;
    // 開(kāi)機(jī)顯示00000
    TM_Digtal_Display(0);
    while (1)
        // 檢測(cè)上按鍵是否按下
        if (up == 0) {
            delay(20);  // 消抖
            if (up == 0)
                if (count < 99999) {
                    count++;
                while (up == 0) {
                    delay(10); // 持續(xù)檢測(cè)按鍵釋放,避免重復(fù)觸發(fā)
                delay(20); // 釋放后再次消抖
        // 檢測(cè)下按鍵是否按下
        if (down == 0) {
            delay(20);  // 消抖
            if (down == 0) {
                if (count > 0) {
                    count--;
                while (down == 0)
        if (++delaytick == 50) // 提高顯示刷新頻率
            delaytick = 0;
            TM_Digtal_Display(count);
        Delay5ms();
ID:1064915 發(fā)表于 2025-5-13 17:45 | 顯示全部樓層
0x08
0x18
0xFE
命令與TM1652 datasheet相符
