查看: 390|回復(fù): 0
為什么不顯示第二個從機的數(shù)據(jù)
ID:1143623 發(fā)表于 2025-3-17 18:30 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
兩發(fā)一收,發(fā)1接收沒問題同時跟發(fā)二接收就出問題了發(fā)2的數(shù)據(jù)沒有變化#include <reg52.h>
#include <intrins.h>
#include <stdio.h>
#define  uint  unsigned int
#define  uchar unsigned char
        #define TX_ADR_WIDTH   5// 5字節(jié)寬度的發(fā)送/接收地址
#define TX_PLOAD_WIDTH 12  // 數(shù)據(jù)通道有效數(shù)據(jù)寬度
        #define TX_ADR_WIDTH1   5// 5字節(jié)寬度的發(fā)送/接收地址
#define TX_PLOAD_WIDTH1 12  // 數(shù)據(jù)通道有效數(shù)據(jù)寬度
uchar code TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01};
uchar code TX_ADDRES[TX_ADR_WIDTH1] = {0xc2,0xc2,0xc2,0xc2,0xc1};
// 定義一個靜態(tài)發(fā)送地址
uchar RX_BUF[TX_PLOAD_WIDTH];
uchar TX_BUF[TX_PLOAD_WIDTH];
uchar RX_BUF1[TX_PLOAD_WIDTH1];
uchar TX_BUF1[TX_PLOAD_WIDTH1];
#define  Nack_counter  10
sbit LCD_RS = P0^6;
sbit LCD_RW = P0^5;
sbit LCD_EN= P0^7;
#define LCD_DATA P2
sbit CE = P3^7;
sbit CSN = P3^2;
sbit SCK = P3^6;
sbit MOSI = P3^3;
sbit MISO = P3^5;
sbit IRQ = P3^4;
uchar flag;
uchar DATA = 0x01;
uchar bdata sta;
sbit  RX_DR         = sta^6;
sbit  TX_DS         = sta^5;
sbit  MAX_RT = sta^4;
#define NRF_WRITE_REG(reg, value) nrf_write_register(reg, value)
#define NRF_READ_REG(reg) nrf_read_register(reg)
unsigned char RxBuf[20];  // 接收緩沖區(qū)
unsigned char RxBuf1[20];
/*******************命令寄存器***************************/
#define  R_REGISTER      0x00//讀取配置寄存器
#define  W_REGISTER      0x20//寫配置寄存器
// SPI(nRF24L01) commands
#define READ_REG    0x00  // Define read command to register
#define WRITE_REG   0x20  // Define write command to register
#define RD_RX_PLOAD 0x61  // Define RX payload register address
#define WR_TX_PLOAD 0xA0  // Define TX payload register address
#define FLUSH_TX    0xE1  // Define flush TX register command
#define FLUSH_RX    0xE2  // Define flush RX register command
#define REUSE_TX_PL 0xE3  // Define reuse TX payload register command
#define NOP         0xFF  // Define No Operation, might be used to read status register
// SPI(nRF24L01) registers(addresses)
#define CONFIG      0x00  // 'Config' register address
#define EN_AA       0x01  // 'Enable Auto Acknowledgment' register address
#define EN_RXADDR   0x02  // 'Enabled RX addresses' register address
#define SETUP_AW    0x03  // 'Setup address width' register address
#define SETUP_RETR  0x04  // 'Setup Auto. Retrans' register address
#define RF_CH       0x05  // 'RF channel' register address
#define RF_SETUP    0x06  // 'RF setup' register address
#define STATUS      0x07  // 'Status' register address
#define OBSERVE_TX  0x08  // 'Observe TX' register address
#define CD          0x09  // 'Carrier Detect' register address
#define RX_ADDR_P0  0x0A  // 'RX address pipe0' register address
#define RX_ADDR_P1  0x0B  // 'RX address pipe1' register address
#define RX_ADDR_P2  0x0C  // 'RX address pipe2' register address
#define RX_ADDR_P3  0x0D  // 'RX address pipe3' register address
#define RX_ADDR_P4  0x0E  // 'RX address pipe4' register address
#define RX_ADDR_P5  0x0F  // 'RX address pipe5' register address
#define TX_ADDR     0x10  // 'TX address' register address
#define RX_PW_P0    0x11  // 'RX payload width, pipe0' register address
#define RX_PW_P1    0x12  // 'RX payload width, pipe1' register address
#define RX_PW_P2    0x13  // 'RX payload width, pipe2' register address
#define RX_PW_P3    0x14  // 'RX payload width, pipe3' register address
#define RX_PW_P4    0x15  // 'RX payload width, pipe4' register address
#define RX_PW_P5    0x16  // 'RX payload width, pipe5' register address
#define FIFO_STATUS 0x17  // 'FIFO Status Register' register address
void delay_ms(uchar x);
unsigned char NRFSPI(unsigned char date)
  unsigned char i;
           for(i=0;i<8;i++)          // 循環(huán)8次
          if(date&0x80)
            MOSI=1;
            MOSI=0;   // byte最高位輸出到MOSI
             date<<=1;             // 低一位移位到最高位
             SCK=1;
          if(MISO)               // 拉高SCK,nRF24L01從MOSI讀入1位數(shù)據(jù),同時從MISO輸出1位數(shù)據(jù)
               date|=0x01;               // 讀MISO到byte最低位
             SCK=0;                    // SCK置低
    return(date);                   // 返回讀出的一字節(jié)
void SPI_Write(unsigned char dat) {
    unsigned char i;
    for(i=0; i<8; i++) {
        MOSI = (dat & 0x80);
        dat <<= 1;
        SCK = 1;
        _nop_();_nop_();
        SCK = 0;
函數(shù): init_io()
描述:
    初始化IO
void init_io(void)
        CE  = 0;        // 待機
        CSN = 1;        // SPI禁止
        SCK = 0;        // SPI時鐘置低
        IRQ = 1;        // 中斷復(fù)位
函數(shù):delay_ms()
描述:
    延遲x毫秒
    uchar i, j;
    i = 0;
    for(i=0; i<x; i++)
       j = 250;
       while(--j);
           j = 250;
       while(--j);
函數(shù):SPI_RW()
描述:
    根據(jù)SPI協(xié)議,寫一字節(jié)數(shù)據(jù)到nRF24L01,同時從nRF24L01
        讀出一字節(jié)
uchar SPI_RW(uchar byte)
        uchar i;
           for(i=0; i<8; i++)          // 循環(huán)8次
                   MOSI = (byte & 0x80);   // byte最高位輸出到MOSI
                   byte <<= 1;             // 低一位移位到最高位
                   SCK = 1;                // 拉高SCK,nRF24L01從MOSI讀入1位數(shù)據(jù),同時從MISO輸出1位數(shù)據(jù)
                   byte |= MISO;               // 讀MISO到byte最低位
                   SCK = 0;                    // SCK置低
    return(byte);                   // 返回讀出的一字節(jié)
函數(shù):SPI_RW_Reg()
描述:
    寫數(shù)據(jù)value到reg寄存器
uchar SPI_RW_Reg(uchar reg, uchar value)
        uchar status;
          CSN = 0;                   // CSN置低,開始傳輸數(shù)據(jù)
          status = SPI_RW(reg);      // 選擇寄存器,同時返回狀態(tài)字
          SPI_RW(value);             // 然后寫數(shù)據(jù)到該寄存器
          CSN = 1;                   // CSN拉高,結(jié)束數(shù)據(jù)傳輸
          return(status);            // 返回狀態(tài)寄存器
函數(shù):SPI_Read()
描述:
    從reg寄存器讀一字節(jié)
uchar SPI_Read(uchar reg)
        uchar reg_val;
          reg_val = SPI_RW(0);        // 然后從該寄存器讀數(shù)據(jù)
          return(reg_val);            // 返回寄存器數(shù)據(jù)
函數(shù):SPI_Read_Buf()
描述:
    從reg寄存器讀出bytes個字節(jié),通常用來讀取接收通道
        數(shù)據(jù)或接收/發(fā)送地址
uchar SPI_Read_Buf(uchar reg, uchar * pBuf, uchar bytes)
        uchar status, i;
          for(i=0; i<bytes; i++)
            pBuf[i] = SPI_RW(0);    // 逐個字節(jié)從nRF24L01讀出
函數(shù):SPI_Write_Buf()
描述:
    把pBuf緩存中的數(shù)據(jù)寫入到nRF24L01,通常用來寫入發(fā)
        射通道數(shù)據(jù)或接收/發(fā)送地址
uchar SPI_Write_Buf(uchar reg, uchar * pBuf, uchar bytes)
        uchar status, i;
            SPI_RW(pBuf[i]);        // 逐個字節(jié)寫入nRF24L01
函數(shù):RX_Mode()
描述:
    這個函數(shù)設(shè)置nRF24L01為接收模式,等待接收發(fā)送設(shè)備的數(shù)據(jù)包
void RX_Mode(void)
        CE = 0;
          SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH);  // 接收設(shè)備接收通道0使用和發(fā)送設(shè)備相同的發(fā)送地址
           SPI_Write_Buf(WRITE_REG + RX_ADDR_P1, TX_ADDRES, TX_ADR_WIDTH);
          SPI_RW_Reg(WRITE_REG + EN_AA, 0x03);               // 使能接收通道0自動應(yīng)答
          SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x03);           // 使能接收通道0
          SPI_RW_Reg(WRITE_REG + RF_CH, 40);                 // 選擇射頻通道0x40
          SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH);  // 接收通道0選擇和發(fā)送通道相同有效數(shù)據(jù)寬度
          SPI_RW_Reg(WRITE_REG + RX_PW_P1, TX_PLOAD_WIDTH);
          SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);            // 數(shù)據(jù)傳輸率1Mbps,發(fā)射功率0dBm,低噪聲放大器增益
          SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f);              // CRC使能,16位CRC校驗,上電,接收模式
          CE = 1;                                            // 拉高CE啟動接收設(shè)備
函數(shù):Check_ACK()
描述:
    檢查接收設(shè)備有無接收到數(shù)據(jù)包,設(shè)定沒有收到應(yīng)答信
        號是否重發(fā)
uchar Check_ACK(bit clear)
        while(IRQ);
        sta = SPI_RW(NOP);                    // 返回狀態(tài)寄存器
        if(MAX_RT)
                if(clear)                         // 是否清除TX FIFO,沒有清除在復(fù)位MAX_RT中斷標志后重發(fā)
                        SPI_RW(FLUSH_TX);
        SPI_RW_Reg(WRITE_REG + STATUS, sta);  // 清除TX_DS或MAX_RT中斷標志
        IRQ = 1;
        if(TX_DS)
                return(0x00);
                return(0xff);
void delayms(unsigned int ms) {
    unsigned int i, j;
    for(i=0; i<ms; i++)
        for(j=0; j<114; j++);
uchar exchange(unsigned char dat)
        unsigned char i,j=0;
        for(i=8;i>0;i--)
                j|=(dat&0x01)<<(i-1);
                dat>>=1;
        return j;
void lcd_write_cmd(unsigned char cmd) {
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_DATA =exchange(cmd);
    LCD_EN = 1;
    delay_ms(2);
    LCD_EN = 0;
void lcd_write_data(unsigned char dat) {
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_DATA =exchange(dat);
    LCD_EN = 1;
    delay_ms(2);
    LCD_EN = 0;
void lcd_init() {
    lcd_write_cmd(0x38);
    delay_ms(5);
    lcd_write_cmd(0x0C);
    delay_ms(5);
    lcd_write_cmd(0x06);
    delay_ms(5);
    lcd_write_cmd(0x01);
    delay_ms(5);
void lcd_show_str(unsigned char x, unsigned char y, char *str) {
    unsigned char addr;
    if(y == 0) addr = 0x80 + x;
    else addr = 0xC0 + x;
    lcd_write_cmd(addr);
    while(*str) {
        lcd_write_data(*str++);
        delay_ms(1);
void main() {
//        unsigned char RX_P_NO;//接收通道號
    lcd_init();
      init_io();
            RX_Mode();
    while(1){
       if(SPI_Read_Buf(RD_RX_PLOAD, RX_BUF, TX_PLOAD_WIDTH) ){
            lcd_show_str(0, 0, RX_BUF);
                                           delay_ms(20);
                         init_io();
                          RX_Mode();
                         if(SPI_Read_Buf(RD_RX_PLOAD, RX_BUF1, TX_PLOAD_WIDTH) ){
            lcd_show_str(0, 1, RX_BUF1);
                                                delay_ms(20);
