網(wǎng)購(gòu)幾塊PCF8574T驅(qū)1602液晶模塊,代碼是壇里前輩寫的,實(shí)驗(yàn)液晶不能顯示,檢查硬件沒(méi)有錯(cuò)誤,始終不能解決問(wèn)題。無(wú)奈之下求助DpSk,生成的代碼編譯時(shí)出錯(cuò),提示67行數(shù)據(jù)類型錯(cuò)誤,將66行子函數(shù)的參數(shù)rs數(shù)據(jù)類型由bit改為unsigned char后編譯成功,下載到單片機(jī)顯示正常。AI生成的代碼也不錯(cuò)。
#include <STC15.h>
#include <intrins.h>
#define PCF_ADDR 0x4E
sbit SDA = P0^1; // I2C數(shù)據(jù)線
sbit SCL = P0^0; // I2C時(shí)鐘線
void delay_us(unsigned int us) {
while (us--) {
_nop_();
_nop_();
_nop_();
_nop_();
void delay_ms(unsigned int ms) {
unsigned int i, j;
for (i = 0; i < ms; i++)
for (j = 0; j < 114; j++);
void I2C_Start() {
SDA = 1;
SCL = 1;
delay_us(5);
SDA = 0;
delay_us(5);
SCL = 0;
void I2C_Stop() {
SDA = 0;
SCL = 1;
delay_us(5);
SDA = 1;
delay_us(5);
void I2C_WriteByte(unsigned char dat) {
unsigned char i;
for (i = 0; i < 8; i++) {
SDA = (dat & 0x80) ? 1 : 0;
dat <<= 1;
SCL = 1;
delay_us(5);
SCL = 0;
delay_us(5);
SDA = 1; // 釋放總線等待ACK
SCL = 1;
delay_us(5);
SCL = 0;
void PCF8574_Write(unsigned char dat) {
I2C_Start();
I2C_WriteByte(PCF_ADDR);
I2C_WriteByte(dat);
I2C_Stop();
void lcd_send_nibble(unsigned char nibble, unsigned char rs) {
unsigned char data_pcf;
// 數(shù)據(jù)位: P4-P7, RS: P0, E: P2, Backlight: P3 (開(kāi)啟)
data_pcf = (nibble << 4) | (rs << 0) | (1 << 3);
// E下降沿
PCF8574_Write(data_pcf & ~(1 << 2)); // E=0
delay_us(1);
PCF8574_Write(data_pcf | (1 << 2)); // E=1
delay_us(1);
delay_us(100);
void lcd_send_byte(unsigned char dat, bit rs) {
lcd_send_nibble(dat >> 4, rs); // 高四位
lcd_send_nibble(dat & 0x0F, rs); // 低四位
void lcd_init() {
delay_ms(50);
lcd_send_nibble(0x03, 0);
delay_ms(5);
delay_ms(1);
delay_us(100);
lcd_send_nibble(0x02, 0);
delay_us(100);
lcd_send_byte(0x28, 0); // 4位, 2行, 5x8
delay_us(100);
lcd_send_byte(0x0C, 0); // 顯示開(kāi), 光標(biāo)關(guān)
delay_us(100);
lcd_send_byte(0x06, 0); // 增量不移屏
delay_us(100);
lcd_send_byte(0x01, 0); // 清屏
delay_ms(2);
void lcd_set_cursor(unsigned char row, unsigned char col) {
unsigned char address = (row == 0) ? 0x80 : 0xC0;
lcd_send_byte(address + col, 0);
void lcd_write_string(char *str) {
while (*str) {
lcd_send_byte(*str++, 1);
void main() {
lcd_init();
lcd_set_cursor(0, 0);
lcd_write_string("Hello World!");
lcd_set_cursor(1, 0);
lcd_write_string("51 & PCF8574T");
while (1);
