查看: 362|回復(fù): 0
關(guān)于nec紅外的單片機(jī)解碼程序
ID:1143041 發(fā)表于 2025-5-10 17:49 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
  1. #include "ray_decode.h"
  2. sbit led2 = P1^0;
  3. sbit led = P1^1;
  4. sbit IR_INPUT = P3^3;  //紅外接收引腳
  5. bit irflag = 0;  //紅外接收標(biāo)志,收到一幀正確數(shù)據(jù)后置1
  6. unsigned char IR_bit_Time = 0;
  7. unsigned char ircode[4];  //紅外代碼接收緩沖區(qū)
  8. unsigned char xdata Ray_bit_timer_Buffer[33];
  9. /* 初始化紅外接收功能 */
  10. void InitInfrared()
  11. {
  12.     IR_INPUT = 1;  //確保紅外接收引腳被釋放
  13.     TMOD &= 0x0F;  //清零T1的控制位
  14.     TMOD |= 0x20;  //配置T1為模式2
  15.         TH1 = 0xA4;
  16.         TL1 = 0xa4;
  17.     TR1 = 0;       //停止T1計(jì)數(shù)
  18.     ET1 = 1;
  19.     IT1 = 1;       //設(shè)置INT1為負(fù)邊沿觸發(fā)
  20.     EX1 = 1;       //使能INT1中斷
  21. }
  22. //低電平560+2= 1120us 高電平 560+560x3 = 2240us
  23. void IR_Decode()
  24. {
  25.         unsigned char value = 0;
  26.         unsigned char i,j,k = 1;
  27.         if(irflag)
  28.         {
  29.
  30.                 irflag = 0;
  31.                 for(i=0;i<4;i++)
  32.                 {
  33.
  34.                         for(j=0;j<8;j++)
  35.                         {
  36.                                 value >>= 1;
  37.                                 if(Ray_bit_timer_Buffer[k] <19 || Ray_bit_timer_Buffer[k]>26) //如果計(jì)數(shù)值不在這個(gè)范圍內(nèi),說明數(shù)據(jù)錯(cuò)誤退出
  38.                                 {
  39.                                         return;
  40.                                 }
  41.                                 else
  42.                                 {
  43.                                         value |= 0x80;
  44.                                 }
  45.
  46.                                 if(Ray_bit_timer_Buffer[k]<9 || Ray_bit_timer_Buffer[k]>14)
  47.                                 {
  48.                                         return;
  49.
  50.                                 }
  51.                                 else
  52.                                 {
  53.                                         value &= 0x7f;
  54.                                 }
  55.
  56.                                 k++;
  57.                         }
  58.                         //LedShow(Ray_bit_timer_Buffer[2]);
  59.                         ircode[i] = value;
  60.                 }
  61.
  62.         }
  63. }
  64. //100us進(jìn)入一次
  65. void Timer1_ISR() interrupt 3
  66. {
  67.         led = ~led;
  68.         IR_bit_Time++;
  69. }
  70. /* INT1中斷服務(wù)函數(shù),執(zhí)行紅外接收及解碼 */
  71. void EXINT1_ISR() interrupt 2
  72. {
  73.
  74.         static unsigned char i = 1;
  75.     static unsigned char IR_start = 0;
  76.         led2 = ~led2;
  77.         TR1 = 1;
  78.         if(IR_start == 0)
  79.         {
  80.
  81.                 Ray_bit_timer_Buffer[0] = IR_bit_Time;
  82.
  83.                 if(Ray_bit_timer_Buffer[0]<130 || Ray_bit_timer_Buffer[0]>140)
  84.                 {
  85.                         //TR1 = 0;
  86.
  87.                         IR_bit_Time = 0;
  88.
  89.                         return;
  90.                 }
  91.                 IR_bit_Time = 0;
  92.                 IR_start = 1;
  93.         }
  94.         Ray_bit_timer_Buffer[i] = IR_bit_Time;
  95.         LedShow(IR_bit_Time);
  96.         IR_bit_Time = 0;
  97.         if(++i >= 33)
  98.         {
  99.
  100.                 i=1;
  101.                 irflag = 1;  //接收完畢后設(shè)置標(biāo)志
  102.                 TR1 = 0;
  103.                 IR_start = 0;
  104.         }
  105.
  106. }
每次下降沿進(jìn)入中斷,然后啟動(dòng)定時(shí)器開始計(jì)數(shù),,但是解碼得出的結(jié)果總是不對(duì),找了兩天問題了還是找不出,希望大佬們幫幫忙
