查看: 209|回復(fù): 0
stm32f407+lan8720實現(xiàn)UCOSII 下LWIP網(wǎng)絡(luò)聯(lián)網(wǎng)問題
ID:338503 發(fā)表于 2025-5-21 15:19 | 顯示全部樓層 |閱讀模式
#include "tcp_server_demo.h"
#include "lwip/opt.h"
#include "lwip_comm.h"
#include "led.h"
#include "lwip/lwip_sys.h"
#include "lwip/api.h"
//本程序只供學習使用,未經(jīng)作者許可,不得用于其它任何用途
//ALIENTEK STM32F407開發(fā)板
//NETCONN API編程方式的TCP服務(wù)器測試代碼
//正點原子@ALIENTEK
//創(chuàng)建日期:2014/8/15
//版本:V1.0
//版權(quán)所有,盜版必究。
//Copyright(C) 廣州市星翼電子科技有限公司 2009-2019
//All rights reserved
//修改信息
//無
u8 tcp_server_recvbuf[TCP_SERVER_RX_BUFSIZE];        //TCP客戶端接收數(shù)據(jù)緩沖區(qū)
u8 *tcp_server_sendbuf="Explorer STM32F407 NETCONN TCP Server send data\r\n";
u8 tcp_server_flag;        //TCP服務(wù)器數(shù)據(jù)發(fā)送標志位
//TCP客戶端任務(wù)
#define TCPSERVER_PRIO                6
//任務(wù)堆棧大小
#define TCPSERVER_STK_SIZE        300
//任務(wù)堆棧
OS_STK TCPSERVER_TASK_STK[TCPSERVER_STK_SIZE];
//tcp服務(wù)器任務(wù)
static void tcp_server_thread(void *arg)
        OS_CPU_SR cpu_sr;
        u32 data_len = 0;
        struct pbuf *q;
        err_t err,recv_err;
        u8 remot_addr[4];
        struct netconn *conn, *newconn;
        static ip_addr_t ipaddr;
        static u16_t                         port;
        LWIP_UNUSED_ARG(arg);
        conn = netconn_new(NETCONN_TCP);  //創(chuàng)建一個TCP鏈接
        netconn_bind(conn,IP_ADDR_ANY,TCP_SERVER_PORT);  //綁定端口 8號端口
        netconn_listen(conn);                  //進入監(jiān)聽模式
        conn->recv_timeout = 10;          //禁止阻塞線程 等待10ms
        while (1)
                err = netconn_accept(conn,&newconn);  //接收連接請求
                if(err==ERR_OK)newconn->recv_timeout = 10;
                if (err == ERR_OK)    //處理新連接的數(shù)據(jù)
                        struct netbuf *recvbuf;
                        netconn_getaddr(newconn,&ipaddr,&port,0); //獲取遠端IP地址和端口號
                        remot_addr[3] = (uint8_t)(ipaddr.addr >> 24);
                        remot_addr[2] = (uint8_t)(ipaddr.addr>> 16);
                        remot_addr[1] = (uint8_t)(ipaddr.addr >> 8);
                        remot_addr[0] = (uint8_t)(ipaddr.addr);
                        printf("主機%d.%d.%d.%d連接上服務(wù)器,主機端口號為:%d\r\n",remot_addr[0], remot_addr[1],remot_addr[2],remot_addr[3],port);
                                if((tcp_server_flag & LWIP_SEND_DATA) == LWIP_SEND_DATA) //有數(shù)據(jù)要發(fā)送
                                        err = netconn_write(newconn ,tcp_server_sendbuf,strlen((char*)tcp_server_sendbuf),NETCONN_COPY); //發(fā)送tcp_server_sendbuf中的數(shù)據(jù)
                                        if(err != ERR_OK)
                                                printf("發(fā)送失敗\r\n");
                                        tcp_server_flag &= ~LWIP_SEND_DATA;
                                if((recv_err = netconn_recv(newconn,&recvbuf)) == ERR_OK)          //接收到數(shù)據(jù)
                                        OS_ENTER_CRITICAL(); //關(guān)中斷
                                        memset(tcp_server_recvbuf,0,TCP_SERVER_RX_BUFSIZE);  //數(shù)據(jù)接收緩沖區(qū)清零
                                        for(q=recvbuf->p;q!=NULL;q=q->next)  //遍歷完整個pbuf鏈表
                                                //判斷要拷貝到TCP_SERVER_RX_BUFSIZE中的數(shù)據(jù)是否大于TCP_SERVER_RX_BUFSIZE的剩余空間,如果大于
                                                //的話就只拷貝TCP_SERVER_RX_BUFSIZE中剩余長度的數(shù)據(jù),否則的話就拷貝所有的數(shù)據(jù)
                                                if(q->len > (TCP_SERVER_RX_BUFSIZE-data_len)) memcpy(tcp_server_recvbuf+data_len,q->payload,(TCP_SERVER_RX_BUFSIZE-data_len));//拷貝數(shù)據(jù)
                                                else memcpy(tcp_server_recvbuf+data_len,q->payload,q->len);
                                                data_len += q->len;
                                                if(data_len > TCP_SERVER_RX_BUFSIZE) break; //超出TCP客戶端接收數(shù)組,跳出
                                        OS_EXIT_CRITICAL();  //開中斷
                                        data_len=0;  //復(fù)制完成后data_len要清零。
                                        printf("%s\r\n",tcp_server_recvbuf);  //通過串口發(fā)送接收到的數(shù)據(jù)
                                        netbuf_delete(recvbuf);
                                }else if(recv_err == ERR_CLSD)  //關(guān)閉連接
                                        netconn_close(newconn);
                                        netconn_delete(newconn);
                                        printf("主機:%d.%d.%d.%d斷開與服務(wù)器的連接\r\n",remot_addr[0], remot_addr[1],remot_addr[2],remot_addr[3]);
                                        break;
//創(chuàng)建TCP服務(wù)器線程
//返回值:0 TCP服務(wù)器創(chuàng)建成功
//                其他 TCP服務(wù)器創(chuàng)建失敗
INT8U tcp_server_init(void)
        INT8U res;
        OS_CPU_SR cpu_sr;
        res = OSTaskCreate(tcp_server_thread,(void*)0,(OS_STK*)&TCPSERVER_TASK_STK[TCPSERVER_STK_SIZE-1],TCPSERVER_PRIO); //創(chuàng)建TCP服務(wù)器線程
        return res;
以上是正點原子的代碼,正常開機可以聯(lián)網(wǎng)收發(fā)數(shù)據(jù),拔掉網(wǎng)線再插上就連不上網(wǎng),必須斷電重啟才可以。怎樣修改以上代碼,才能實現(xiàn)網(wǎng)線熱插拔自動重聯(lián)網(wǎng)?
