查看: 327|回復(fù): 2
利用期末閑暇之余,制作了一個(gè)流水燈按鍵程序,四個(gè)按鍵控制LED流水燈的操作 加速
ID:1152291 發(fā)表于 2025-6-5 23:29 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <REGX51.H>
sbit K1 = P3 ^ 2;
sbit K2 = P3 ^ 3;
sbit K3 = P3 ^ 4;
sbit K4 = P3 ^ 5;
unsigned char led_switch = 0;
volatile unsigned int number = 200;
volatile unsigned char temp;
void Delay(unsigned int xms);
void interrupt_init();
void timer_init();
        unsigned char i;
        interrupt_init();
        timer_init();
        while (1)
                if (led_switch == 1)
                        temp = 0x80;
                        for (i = 0; i < 8; i++)
                                P1 = ~(temp >> i);
                                Delay(number);
            if (led_switch == 0)
                continue;
                        temp = 0x01;
                                P1 = ~(temp << i);
                                Delay(number);
        IT0 = 1;
        EX0 = 1;
        IT1 = 1;
        EX1 = 1;
        EA = 1;
void timer_init()
        TMOD = 0X11;                                // 0001 0101 T1定時(shí)方式,模式1(16位),T0定時(shí)方式,模式1(16位)
        TH0 = (65536 - 5000) / 256; // 初始值為64536,定時(shí)5000微秒相當(dāng)于5毫秒;
        TL0 = (65536 - 5000) % 256; //
        ET0 = 1;
        TR0 = 1;                                        // 啟動(dòng)定時(shí)器T0
void Delay(unsigned int ms)
    unsigned char i, j;
    while (ms--)
        i = 2;
        j = 239;
        do
            while (--j);
        } while (--i);
void exint0_ISR() interrupt 0
        led_switch = 1;
void exint1_ISR() interrupt 2
        temp = 0x00;
    P1 = 0xFF;
    led_switch = 0;
void timer0_ISR() interrupt 1
    if ((P3 & 0x30) != 0x30)
        TR0 = 0;
        P1 = 0xFF;
        Delay(50);
            if (K3 == 0)
                number -= 50;
                if (number <= 50)
                    number = 50;
            if (K4 == 0)
                number += 50;
                if (number >= 500)
                    number = 500;
        TR0 = 1;
ID:619259 發(fā)表于 2025-6-6 08:42 | 只看該作者
在定時(shí)器中斷中使用延時(shí)函數(shù),不妥呵兄弟
ID:1152291 發(fā)表于 2025-6-17 14:27 | 只看該作者
cy009 發(fā)表于 2025-6-6 08:42
為啥哦大神可以解答嘛
