//*************************C語言寫的可調(diào)數(shù)字時(shí)鐘顯示 *************************
//*******************************2009-10-15***********************************
//***************************可調(diào)數(shù)字鐘功能介紹*******************************
//K1:adjtime K2:hour K3:min K4:OK
//K2:lookalarm K4:OK
//K3:adjalarm K2:hh K3:mm K4:OK
//K4:SET alarm OFF/ON
#include"reg51.h"
unsigned char ss=0,hour=12,min=0,hh=7,mm=30; //初始化 顯示12:00鬧鈴:7:30
unsigned char code leds_a[]={0xC0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90}; //0-9
unsigned char code leds_b[]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10}; //帶點(diǎn)的0-9
sbit P37=P3^7; //蜂鳴器開關(guān)
sbit P20=P2^0;
sbit P21=P2^1;
sbit P22=P2^2;
sbit P23=P2^3; //數(shù)碼管選位
#define K1 0xde
#define K2 0xee
#define K3 0xf6
#define K4 0xdd //按鍵的分別代碼
TIMER_INTO();
unsigned char kbscan(); //鍵盤掃描
void lookalarm(); //查看鬧鈴
void disp_off(); //鬧鈴關(guān)的顯示
void process(); //有按鍵按下的處理
void disp_on(); //鬧鈴開的顯示
void alarm(); //鬧鈴
void disp();
unsigned char flag_alarm=0; //鬧鐘標(biāo)志位,默認(rèn)鬧鈴關(guān)
static unsigned int count=0; //計(jì)數(shù)器初始
unsigned int dema; //數(shù)碼管顯示的延時(shí)標(biāo)中斷志
unsigned int demb; //按鍵的延時(shí)中斷標(biāo)志
unsigned int demc,demd,deme; //demc,demd分別是兩種頻率的半周期計(jì)數(shù),deme是頻率之間轉(zhuǎn)換的標(biāo)志
unsigned char key,flag,temp=0; //key:按鍵代碼的返回,flag:頻率的響應(yīng)時(shí)間控制,temp:控制選擇輸出頻率
main() //主程序
TIMER_INTO(); //定時(shí) 中斷 初始化
alarm(); //鬧鈴
key=kbscan();//掃描鍵盤
process();
disp();
void process() //按鍵的處理
if(key!=0)
if(key==K1)
while((key=kbscan())!=K4)
disp_off();
if((key=kbscan())==K2)
hour++;
disp_off();
if(hour>=24)
hour=0;
if((key=kbscan())==K3)
min++;
if(min>=60)
min=0;
else if(key==K2)
lookalarm();
else if(key==K3)
lookalarm();
hh++;
lookalarm();
if(hh>=24)
hh=0;
mm++;
if(mm>=60)
mm=0;
else if(key==K4)
if(flag_alarm==0)
flag_alarm=1;
flag_alarm=0;
TIMER_INTO() //中斷初始化
TMOD=0X01;
TH0=0Xfe;
TL0=0X0c; //500uS初值
TR0=1;
ET0=1;
EA=1;
timer0() interrupt 1 //中斷進(jìn)程
TR0=0;
TH0=0Xfe;
TL0=0X0c; //重裝初值
TR0=1;
if(dema)
dema--; //2mS延時(shí)
if(demb)
demb--; //40mS延時(shí)
if(demc)
demc--;
if(demd)
demd--;
flag++;
if(flag>=2000)//調(diào)整此處可以調(diào)整頻率響應(yīng)的時(shí)間
flag=0;
temp=1;
deme++;
if(deme>=2)
deme=0;//這里設(shè)計(jì)的是500HZ響應(yīng)1S,1kHZ響應(yīng)1S
temp=0;
count++;
if(count>=2000) //1S延時(shí)
count=0;
ss++;
if(ss>=60)
ss=0;
min++;
if(min>=60)
min=0;
hour++;
if(hour>=24)
hour=0;
void disp()
if(flag_alarm==0)
disp_off(); //關(guān)閉鬧鐘的顯示
disp_on(); //鬧鐘開啟 的顯示
void disp_off() //鬧鈴關(guān)的走時(shí)
P23=0;
P0=leds_a[min%10];
dema =4;//2mS
while(dema!=0);
P23=1;
P22=0;
P0=leds_a[min/10];
dema =4;
while(dema!=0);
P22=1;
P21=0;
P0=leds_b[hour%10];
dema =4;
while(dema!=0);
P21=1;
P20=0;
P0=leds_a[hour/10];
dema =4;
while(dema!=0);
P20=1;
void disp_on() //鬧鈴開的走時(shí)
P23=0;
P0=leds_b[min%10];
dema =4;
while(dema!=0);
P23=1;
P22=0;
P0=leds_a[min/10];
dema =4;
while(dema!=0);
P22=1;
P21=0;
P0=leds_b[hour%10];
dema =4;
while(dema!=0);
P21=1;
P20=0;
P0=leds_a[hour/10];
dema =4;
while(dema!=0);
P20=1;
void lookalarm() //查看鬧鐘
P23=0;
P0=leds_a[mm%10];
dema =4;
while(dema!=0);
P23=1;
P22=0;
P0=leds_a[mm/10];
dema =4;
while(dema!=0);
P22=1;
P21=0;
P0=leds_b[hh%10];
dema =4;
while(dema!=0);
P21=1;
P20=0;
P0=leds_a[hh/10];
dema =4;
while(dema!=0);
P20=1;
unsigned char kbscan() //掃描鍵盤
unsigned char sccode,recode,temp;
P1=0XF8;
temp=P1;
if(temp!=0xf8)
demb=80; //40mS
while(demb!=0);
if(temp==P1)
sccode=0xfe;
while((sccode&0xf7)!=0)
P1=sccode;
if((P1&0xf8)!=0xf8)
recode=P1&0Xf8;
sccode=sccode&0xc7;
return(recode|sccode);
sccode=sccode<<1|0x01;
return(0);
void alarm()//鬧鈴
if((min==mm)&&(hour==hh))
if(flag_alarm==1)
if(temp)
demb=2;
while(demb!=0);//500HZ 1mS取反
P37=~P37;
dema=1;
while(dema!=0);//1KHZ 500uS取反
P37=~P37;
P37=1;
P37=1;
