查看: 2817|回復(fù): 3
求各位大哥,幫小弟看看這個(gè)密碼鎖的程序錯(cuò)在哪了。!調(diào)了一天都沒調(diào)好!!
ID:60462 發(fā)表于 2014-4-16 22:59 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg52.h>
uchar one;
uchar two=8;
uchar k;
sbit rs=P2^0;
sbit e=P2^1;
sbit scl=P2^4;
sbit sda=P2^5;
sbit led=P2^7;
uchar code table1[]="Your password...";
uchar code table2[]="error !!!";
uchar code table3[]="unlock ok";
uchar code key1[]={0xfe,0xfd,0xfb};
uchar code key2[]={0xee,0xde,0xbe,0x7e,0xed,0xdd,0xbd,0x7d,0xeb,0xdb};
uchar code key3[]={0xbb,0x7b};
uchar code key4[]="0123456789";
void delay_1us()
{;;}                                         //微秒延時(shí)
void delay(uchar time)                        //毫秒延時(shí)
                uchar i;
                for(;time>0;time--)
                        for(i=0;i<125;i++);
void write_com(uchar com)                //液晶命令輸入
                rs=0;
                P1=com;
                delay(1);
                e=1;
                delay(1);
                e=0;
void write_dat(uchar datt)                //液晶數(shù)據(jù)輸入
                rs=1;
                P1=datt;
                delay(1);
                e=1;
                delay(1);
                e=0;
void init()                                //液晶初始化
                e=0;
                write_com(0x38);
                write_com(0x0c);
                write_com(0x06);
                write_com(0x01);
void display1(uchar * dat,uchar n,uchar m)        table1,table2,table3數(shù)據(jù)的輸入
                uchar i;
                write_com(0x80+m+1);
                for(i=0;i<n;i++)
                                write_dat(dat[i]);
                                delay(1);
void inti1()                                //I2c的初始化
                scl=1;
                delay_1us();
                sda=1;
                delay_1us();
void start()                                //I2c的開啟
                sda=1;
                delay_1us();
                scl=1;
                delay_1us();
                sda=0;
                delay_1us();
void repons()                                //I2c的應(yīng)答
                uchar i;
                scl=1;
                delay_1us();
                while((sda==1)&&(i<250))
                        i++;
                scl=0;
                delay_1us();
void stop()                                //I2c的停止
                sda=0;
                delay_1us();
                scl=1;
                delay_1us();
                sda=1;
                delay_1us();
void  writebyte(uchar //I2c的寫入一字節(jié)
                uchar i,temp;
                temp=dat;
                for(i=0;i<8;i++)
                                temp=temp<<1;
                                scl=0;
                                delay_1us();
                                sda=CY;
                                delay_1us();
                                scl=1;
                                delay_1us();
                scl=0;
                delay_1us();
                sda=1;
                delay_1us();
uchar readbyte()                        //I2c的讀一字節(jié)
                uchar i,d;
                scl=0;
                delay_1us();
                sda=1;
                for(i=0;i<8;i++)
                                scl=1;
                                delay_1us();
                                d=(d<<1)|sda;
                                scl=0;
                                delay_1us();
                return d;
void write_dat1(uchar address, uchar dat)        //寫入數(shù)據(jù)
                start();
                writebyte(0xa0);
                repons();
                writebyte(address);
                repons();
                writebyte(dat);
                repons();
                stop();
uchar read_dat1(uchar address)                //讀數(shù)據(jù)
                uchar dat;
                start();
                writebyte(0xa0);
                repons();
                writebyte(address);
                repons();
                start();
                writebyte(0xa1);
                repons();
                dat=readbyte();
                stop();
                return dat;
uchar compare()                                //比較輸入的密碼與存入的密碼
                uchar i,n,m,b=0;
                for(i=0;i<6;i++)
                                n=read_dat1(1+i);
                                m=read_dat1(8+i);
                                if(n==m) b++;
                         if(b==6) return 1;
                        else return 0;
        void key_buf()                                //密碼的輸入
                uchar i,j,uu;
                for(i=0;i<3;i++)
                                P3=key1[i];
                                uu=P3;
                        if((uu&0xf0)!=0xf0)
                                delay(10);
                                for(j=0;j<10;j++)
                                                 if(key2[j]==uu)
        if(k<6)
        write_dat(key4
[j]);                //輸入6位數(shù)密碼
        write_dat1(two,j);
        two++;
        k++;
                                                  while(P3==key2[j]);
                                                if(uu==key3[1])                //開密碼
        one=compare();
        if(one==1)
        led=0;
        display1
(table3,9,0x40);
        else  display1(table2,9,0x40);
        one=0;
        while(P3==key3[1]);
                                                if(uu==key3[0])                //鎖密碼
        k=0;
        two=8;
        led=1;
        write_com(0x01);
        display1(table1,15,0x40);
        write_com(0x80+0x40+1);
        while(P3==key3[0]);
                uchar i;
                init();
                inti1();
                for(i=0;i<6;i++)
                write_dat1(i+1,i+1); //初始密碼123456
                         key_buf();
ID:60462 發(fā)表于 2014-4-16 23:16 | 只看該作者
  電路在這里。。!
新建 Microsoft Word 文檔.rar
22.05 KB, 下載次數(shù): 3
ID:60076 發(fā)表于 2014-4-17 01:14 | 只看該作者
ID:60462 發(fā)表于 2014-4-17 20:11 | 只看該作者
liumei 發(fā)表于 2014-4-17 01:14
http://www.torrancerestoration.com/bbs/dpj-22586-1.html
代碼不全:我想知道我寫錯(cuò)在那里。。!
