查看: 6837|回復: 3
求助單片機液晶顯示問題
ID:17137 發(fā)表于 2009-10-11 13:33 | 顯示全部樓層 |閱讀模式
小弟學單片機的時間不長,自己寫了個51單片機控制1602液晶顯示器顯示電子表的程序,但是調(diào)試程序的時候用按鍵調(diào)時間的時候老是在秒的后面還顯示出兩個數(shù)字,不知道這是為什么,秒后面并沒有讓他顯示,還是顯示了數(shù)字。希望高手不吝賜教;源程序如下:
#include<reg52.h>
sbit RS=P1^0;
sbit RW=P1^1;
sbit EN=P1^2;
sbit K1=P3^2;
sbit K2=P3^3;
sbit K3=P3^4;
unsigned int second,minute,hour;
unsigned int cnt;
unsigned int ms;
unsigned char x=0x88;
unsigned char y=0x85;
unsigned char z=0x82;
//*********延時******************
void yanshi(ms)
 unsigned int i;
 while(ms--)
  for(i=120;i>0;i--);
//*********寫命令*********
write_cmd(unsigned char cmd)
  RS=0;
  RW=0;
  P0=cmd;
  yanshi(5);
  EN=1;
  yanshi(5);
  EN=0;
//*****************寫數(shù)據(jù)***********
write_data(unsigned char date)
 RS=1;
 RW=0;
 P0=date;
 yanshi(5);
 EN=1;
 yanshi(5);
 EN=0;
//*******初始化*************
void init()
 EN=0;
 write_cmd(0x38);
 write_cmd(0x0e);
 write_cmd(0x06);
 write_cmd(0x01);
 write_cmd(0x80);
 write_cmd(0x84);
 write_data(':');
 write_cmd(0x87);
 write_data(':');
 //*********************寫時間*******
   write_SFM(unsigned char date)
 unsigned char shi,fen;
 shi=date/10;
 fen=date%10;
 write_data(shi+0x30);
 write_data(fen+0x30);
 //*********主函數(shù)入口**********
 main()
 TMOD=0x02;
 TH0=0xa4;
 TL0=0xa4;
 ET0=1;
 EA=1;
 TR0=1;
 init();
   if(K1==0)
    yanshi(50);
 if(K1==0)
   second++;
   if(second==60)
   second=0;
     write_cmd(x);
                write_SFM(second);
  while(K1==0);
  if(K2==0)
    yanshi(50);
     if(K2==0)
    minute++;
    if(minute==60)
     minute=0;
       write_cmd(0x85);
                write_SFM(minute);
     while(K2==0);
  if(K3==0)
    yanshi(50);
    if(K3==0)
     hour++;
     if(hour==24)
    hour=0;
             write_cmd(z);
                write_SFM(hour);
    while(K3==0);
void t0() interrupt 1
    TH0=0xa4;
 TL0=0xa4;
   cnt++;
  if(cnt==10000)
  cnt=0;
  second++;
   write_cmd(x);
        write_SFM(second);
  if(second==60)
    second=0;
    minute++;
   write_cmd(y);
        write_SFM(minute);
    if(minute==60)
     minute=0;
  hour++;
  write_cmd(z);
        write_SFM(hour);
   if(hour==24)
     hour=0;
[此貼子已經(jīng)被作者于2009-10-11 13:35:51編輯過]
ID:16415 發(fā)表于 2009-10-14 11:14 | 顯示全部樓層
加油,偶也剛學...
ID:17746 發(fā)表于 2009-10-21 15:16 | 顯示全部樓層
我剛編了一個程序和你的功能差不多,是用1602和S51單片機編的一個時鐘,可以顯示年月日和時分秒以及星期,你要源程序嗎,我也是剛學,咱們大家可以互相學習
ID:18277 發(fā)表于 2009-10-29 12:18 | 顯示全部樓層
呵呵 我也遇到過這個問題 簡單的解決方法是在對液晶屏進行初始化時把整個液晶屏全部寫滿空格 完成后再對需要顯示的部分重新寫 我就是這么辦的 你試一下
