查看: 2653|回復(fù): 0
I2C————AT24C02程序無(wú)現(xiàn)象
ID:58980 發(fā)表于 2014-6-11 18:14 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
寫(xiě)的程序如下:實(shí)驗(yàn)現(xiàn)象沒(méi)有。求教高人指點(diǎn)。
#include<reg52.h>
#define uint  unsigned int
sbit scl=P2^1;
sbit sda=P2^0;
sbit de=P1^4;
sbit dula=P2^7;
sbit wela=P2^6;
void delay()  [url=]//@12.000MHz[/url]
void Delay2ms()  [url=]//@12.000MHz[/url] 2毫秒延時(shí)
unsigned char i, j;
i = 4;
j = 225;
do
  while (--j);
} while (--i);
void init()
sda=1;
scl=1;
delay();
void start()      //開(kāi)始信號(hào)
sda=1;
delay();
scl=1;
delay();
sda=0;
delay();
void stop()       //停止信號(hào)
sda=0;
delay();
scl=1;
delay();
sda=1;
delay();
void respons()     //應(yīng)答
uchar i;
scl=1;
delay();
while((sda==1)&&(i<255))i++;
scl=0;
delay();
void write_byte(uchar date)    //寫(xiě)一個(gè)字節(jié)
uchar i,temp;
temp=date;
for(i=0;i<8;i++)
  scl=0;
  delay();
  temp<<=1;
  sda=CY;
  delay();
  scl=1;
  delay();
scl=0;
delay();
sda=1;
delay();
uchar read_byte(void)     //讀取一個(gè)字節(jié)
uchar i,j;
scl=0;
delay();
sda=1;
delay();
for(i=0;i<8;i++)
  scl=1;
  delay();
  j=(j<<1)|sda;
  scl=0;
  delay();
return j;
void write_add(uchar address,uchar date)
{                        //在xx位置寫(xiě)個(gè)字節(jié)
start();                      /**/
write_byte(0xa0);       /**/
respons();
write_byte(address);
respons();
write_byte(date);
respons();
stop();
uchar read_add(uchar address)
uchar date;
start();
write_byte(0xa0);
respons();
respons();
start();
write_byte(0xa1);
respons();
date=read_byte();
stop();
return date;
init();
start();
write_add(0x01,0xaa);
delay();
Delay4ms();
P0=read_add(0xaa);
delay();
Delay4ms();
de=0;
while(1);
