查看: 3441|回復(fù): 1
C8051F340單片機(jī)SPI串行驅(qū)動(dòng)JCM12232F液晶屏遇到問(wèn)題
ID:63990 發(fā)表于 2014-7-14 22:10 | 顯示全部樓層 |閱讀模式
程序代碼如下,求大神指點(diǎn)
#include "c8051F340.h"
#include "def.h"
//#include "USB_API.h"
#include "intrins.h"
//#endif
// *** 局部常數(shù)
// ****** MCU
#define MCU_SYS_CLK (12000000) // clock frequency in MHz
#define MCU_SPI_CLK (1000000) // MCU與RC522之間的通信速率最大為1MHz
#define MCU_UART_RATE (9600) // Baud rate of UART in bps
sbit LCD_CS = P0^7; // LCD片選信號(hào)
// *** 全局變量
dbyte KEY_XDATA gRecevBuffer[30] = {0x00};
uint1 gCount = 0;
dbool gCompl = 0;
dvoid McuDelayUs(uint1 aUs)
    while(aUs--)
        _nop_();_nop_();_nop_();_nop_();
dvoid McuDelayMs(uint1 aMs)
     while(aMs--)
          McuDelayUs(1000);
void SpiInit()
    SPI0CFG = 0x60; // 允許主方式
    SPI0CN = 0x0D; // 4線單主方式,使能SPI0
    SPI0CKR = MCU_SYS_CLK / (2 * MCU_SPI_CLK) - 1; // 注意選擇SPI時(shí)鐘
    NSSMD0 = 1; // NSS的輸出值由NSSMD0(SPI0CN.2)控制
dbyte SpiWrite(dbyte aByte)
    SPIF = 0;
    SPI0DAT = aByte;
    while(!SPIF);
    SPIF = 0;
    return SPI0DAT;
dvoid Spi0SelectLcd()
    NSSMD0 = 0;
dvoid Spi0DisableAllDevices()
    NSSMD0 = 1;
// *** 全局函數(shù)
dvoid McuInit()
    PCA0MD &= ~0x40;
    EA = 1;
    OSCICN |= 0x83; // 內(nèi)部振蕩器使能,SYSCLK為內(nèi)部振蕩器不分頻
    RSTSRC |= 0x04; // 使能時(shí)鐘丟失檢測(cè)器
// PORT_Init
// P0.0  -  SCK  (SPI0), Push-Pull,  Digital
// P0.1  -  MISO (SPI0), Open-Drain, Digital
// P0.2  -  MOSI (SPI0), Push-Pull,  Digital
// P0.3  -  NSS  (SPI0), Push-Pull,  Digital
// P0.4  -  TX0  (UART0), Push-Pull,  Digital
// P0.5  -  RX0  (UART0), Open-Drain, Digital
// p2.4  -  RST  (SPI0), Push-Pull,  Digital, skipped
// P0.7  -  LCD_CS(SPI0),Push-Pull,  Digital, skipped
    P0MDOUT = 0xDD;
    P0SKIP = 0xC0;
    P2MDOUT |= 0x10;
    P2SKIP |= 0x10;
    P4MDOUT |= 0x80;
//    P4 &= 0x7f;// 接收
    P4 |= 0x80;// 發(fā)送
    XBR0 = 0x03; // SPI I/O連到端口引腳
    XBR1 = 0x40; // 交叉開(kāi)關(guān)使能
    SpiInit();
void Lcd_Write(uint1 flag, dbyte command_data)
    uint1 i_data,temp_data1,temp_data2;
    LCD_CS = 1;
    if(1 == flag)    //flag是1,寫(xiě)入指令
        Spi0SelectLcd();
        SpiWrite(0xf8);
        Spi0DisableAllDevices();
    else        //flag非1,寫(xiě)入數(shù)據(jù)
        Spi0SelectLcd();
        SpiWrite(0xfa);
    i_data = command_data;
    i_data &= 0xf0;
    Spi0SelectLcd();
    SpiWrite(i_data);
    temp_data1 = i_data & 0xf0;
    temp_data2 = i_data & 0x0f;
    temp_data1 >>= 4;
    temp_data2 <<= 4;
    i_data = temp_data1 | temp_data2;
    i_data &= 0xf0;
    Spi0SelectLcd();
    SpiWrite(i_data);
    LCD_CS = 0;
    McuDelayMs(10);
void Lcd_init()
    uint1 command_data;
    McuDelayMs(100);
    command_data = 0x30;
    Lcd_Write(1,command_data); /*功能設(shè)置:一次送8位數(shù)據(jù),基本指令集*/
    command_data = 0x04;
    Lcd_Write(1,command_data); /*點(diǎn)設(shè)定:顯示字符/光標(biāo)從左到右移位,DDRAM地址加1*/
    command_data = 0x0f;
    Lcd_Write(1,command_data); /*顯示設(shè)定:開(kāi)顯示,顯示光標(biāo),當(dāng)前顯示位反白閃動(dòng)*/
    command_data = 0x01;
    Lcd_Write(1,command_data); /*清DDRAM*/
    command_data = 0x02;
    Lcd_Write(1,command_data); /*DDRAM地址歸位*/
    command_data = 0x80;
    Lcd_Write(1,command_data); /*把顯示地址設(shè)為0X80,即為第一行的首位*/
void Lcd_Display()
    uint1 command_data;
    Lcd_Write(2,'a');
    McuDelayMs(3000);
int main()
    McuInit();
    Lcd_init();
    Lcd_Display();
    while(1);
    return 0;
ID:44262 發(fā)表于 2014-7-17 16:38 來(lái)自觸屏版 | 顯示全部樓層
程序運(yùn)行以后是什么效果?
