查看: 3472|回復(fù): 0
旁路串口驅(qū)動
ID:51024 發(fā)表于 2014-8-3 00:49 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
* File Name         : ycc_uart_bypass.c
* Author            : Tangeping
* Version           : V1.0.0
* Date              : 07/3/2014
* Description       : 旁路串口配置
#define  YCC_UARTPASSBY_GLOBALS
#include "stm32f10x.h"
#include "main.h"
#include <stdio.h>
#include <string.h>
#define PASSBY_UART                                USART3
#define PASSBY_TXVALUE                        Uart3_TxValue
#define PASSBYTX_DMA_SIZE                DMA_U3TXBUF_SIZE
#define PASSBYTX_DMA_CH                        DMA1_Channel2
#define PASSBY_RXVALUE                        Uart3_RxValue
#define PASSBYRX_DMA_SIZE                DMA_U3RXBUF_SIZE
#define PASSBYRX_DMA_CH                        DMA1_Channel3
#define PASSBY_TXCOMPLETE                Uart3_TxComplete
#define PASSBY_HEAD                         0xE0;
const uint32_t BaudRate_TABLE[]={4800,9600,19200,38400,57600,115200};
typedef struct{
        u8 id;
    u8 state;
        u8 BaudRate;
        u8 len;
        u8 StopBit;
        u8 Partity;
}UART_INFO;
static UART_INFO uart_info;
#define PASSBY_ONCESIZE        PASSBYTX_DMA_SIZE-6 //最大數(shù)據(jù)長度44=50-4-2
typedef struct{
        vu8 bLength;        //長度,0為無效狀態(tài)
        u8*        bptr;                //緩沖區(qū)指針
}ST_TOSLAVE_BUFFER;
typedef struct{
        u8        bptr[PASSBY_ONCESIZE];                //緩沖區(qū)長度
}ST_TOMASTER_BUFFER;
#define SLAVE_ARRAY         32
#define MASTER_ARRAY                 (SLAVE_ARRAY*3)
static ST_TOMASTER_BUFFER  ToMasterBuf[MASTER_ARRAY]; //發(fā)送緩沖區(qū)
static u8 ToMasterWriteOffset;                                                  //由AVN轉(zhuǎn)向中控
static u8 ToMasterReadOffset;
static ST_TOSLAVE_BUFFER  ToSlaveBuf[SLAVE_ARRAY]; //接收緩沖區(qū)
static u8 ToSlaveWriteOffset;                                           //由中控向外部終端發(fā)送數(shù)據(jù)
static u8 ToSlaveReadOffset;
static u8 Passby_ReadAddr;
u8 PassbyWrite_Data(u8 * data, u8 length)
        u8 i,*ptr;
        if (length == 0 || length > PASSBY_ONCESIZE)
                return 2;
        ptr = (u8*)Mem_Malloc(length);
    if (ptr == NULL)
                return 1;
        if (ToSlaveBuf[ToSlaveWriteOffset].bLength == 0)
                ToSlaveBuf[ToSlaveWriteOffset].bptr = ptr;
                for (i=0;i<length;i++)
                        *ptr++ = *data++;
                ToSlaveBuf[ToSlaveWriteOffset].bLength = length;
                ToSlaveWriteOffset = (++ToSlaveWriteOffset)%SLAVE_ARRAY;
                return 0;
                Mem_Free(ptr);
        return 1;
static void PASSBY_Config()
        USART_InitTypeDef USART_InitStructure;
        USART_InitStructure.USART_StopBits = (uart_info.StopBit > 1?USART_StopBits_2:USART_StopBits_1);
        if(uart_info.Partity == 0)
                USART_InitStructure.USART_Parity =USART_Parity_No;
                USART_InitStructure.USART_WordLength = USART_WordLength_8b;
                USART_InitStructure.USART_Parity =uart_info.Partity==1 ?USART_Parity_Odd:USART_Parity_Even;
                USART_InitStructure.USART_WordLength = USART_WordLength_9b;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
        USART_InitStructure.USART_BaudRate = BaudRate_TABLE[uart_info.BaudRate];
        USART_Init(PASSBY_UART, &USART_InitStructure);
        uart_info.state==ON ? USART_Cmd(PASSBY_UART, ENABLE):USART_Cmd(PASSBY_UART,DISABLE);
static void Passby_Send_Msg()//由中控向外部終端發(fā)數(shù)據(jù)
        if(uart_info.state==ON)
            if (ToSlaveBuf[ToSlaveReadOffset].bLength > 0)//中控向外部終端發(fā)送數(shù)據(jù)
                        PASSBYTX_DMA_CH->CCR &= (uint16_t)(~DMA_CCR1_EN);
                        memcpy(PASSBY_TXVALUE,ToSlaveBuf[ToSlaveReadOffset].bptr,
                                        ToSlaveBuf[ToSlaveReadOffset].bLength);
                        PASSBYTX_DMA_CH->CNDTR = ToSlaveBuf[ToSlaveReadOffset].bLength;
                        MemFree_BufWrite(ToSlaveBuf[ToSlaveReadOffset].bptr);
                        ToSlaveBuf[ToSlaveReadOffset].bLength = 0;
                        ToSlaveReadOffset = (++ToSlaveReadOffset)%SLAVE_ARRAY;
                        PASSBYTX_DMA_CH->CCR |= DMA_CCR1_EN;
                else if (ToMasterBuf[ToMasterReadOffset].bLength > 0)//轉(zhuǎn)發(fā)給中控的數(shù)據(jù)
                        Host_Report_Event(HOST_EVENT_PASSBY_DATA,ToMasterBuf[ToMasterReadOffset].bptr,
        ToMasterBuf[ToMasterReadOffset].bLength);
                        MemFree_BufWrite(ToMasterBuf[ToMasterReadOffset].bptr);
                        ToMasterBuf[ToMasterReadOffset].bLength = 0;
                        ToMasterReadOffset = (++ToMasterReadOffset)%MASTER_ARRAY;
                else return;
static void Passby_Receive_Msg()
        static u16 cndtr = 0,overtime = 0;
        u16 addr,end,i,length;
        end = (PASSBYRX_DMA_SIZE-PASSBYRX_DMA_CH->CNDTR)%PASSBYRX_DMA_SIZE;
        if (cndtr != end)
                cndtr = end;
                addr = Passby_ReadAddr;
                overtime = 1;
                if (addr > end)
                        end += PASSBYRX_DMA_SIZE;
                length = end - addr;
                        while (length > 0)
                                for (i=0; i<length&&i<PASSBY_ONCESIZE; i++)
                                        ToMasterBuf[ToMasterWriteOffset].bptr[i]=
                                        PASSBY_RXVALUE[(addr++)%PASSBYRX_DMA_SIZE];
                                ToMasterBuf[ToMasterWriteOffset].bLength=length>PASSBY_ONCESIZE?PASSBY_ONCESIZE:length;
                                ToMasterWriteOffset = (++ToMasterWriteOffset)%MASTER_ARRAY;
                                length -= length>PASSBY_ONCESIZE?PASSBY_ONCESIZE:length;
                        Passby_ReadAddr = addr%PASSBYRX_DMA_SIZE;
                else return;
        else if (overtime > 0)
                overtime = 0;
                Passby_ReadAddr = cndtr;
void Passby_IT()//10m中斷
        Passby_Receive_Msg();
        Passby_Send_Msg();
void UartPassby_Init()
        u8 i;
        memset(&uart_info,0,sizeof(uart_info));
        Passby_ReadAddr = 0;
        memset(PASSBY_RXVALUE,NULL,sizeof(PASSBY_RXVALUE));
        PASSBY_TXCOMPLETE = ON;
        ToMasterWriteOffset = 0;
        ToMasterReadOffset = 0;
        for (i=0; i<MASTER_ARRAY; i++)
                ToMasterBuf[i].bLength = 0;
        ToSlaveWriteOffset = 0;
        ToSlaveReadOffset = 0;
        for (i=0; i<SLAVE_ARRAY; i++)
                ToSlaveBuf[i].bLength = 0;
        PASSBYRX_DMA_CH->CNDTR = PASSBYRX_DMA_SIZE;
        DMA_Cmd(PASSBYRX_DMA_CH, ENABLE);
        USART_Cmd(PASSBY_UART, DISABLE);
void Uart_Setting_Event(u8 *event, u8 length)
        u8 reprot=0;
        u8 buf[6];
        if(length>0)
                if(event[1]!=uart_info.state     ||
                   event[2]!=uart_info.BaudRate  ||
                   event[3]!=uart_info.StopBit   ||
                   event[5]!=uart_info.Partity)
                         uart_info.state  = event[0];
                        uart_info.BaudRate=event[1];
                        uart_info.len     =event[2];
                        uart_info.StopBit =event[3];
                        uart_info.Partity =event[4];
                        PASSBY_Config();
                        reprot=1;
        else reprot=1;
        if(reprot > 0)
                buf[0]=uart_info.id=0;
                buf[1]=uart_info.state;
                buf[2]=uart_info.BaudRate;
                buf[3]=uart_info.len=3;
                buf[4]=uart_info.StopBit;
                buf[5]=uart_info.Partity;
                Host_Report_Event(HOST_EVENT_PASSBY_SETTING,buf,6);
void UartPassby_Main()
