查看: 18168|回復: 24
12864在單片機上顯示圖片(無償奉上)
ID:63839 發(fā)表于 2014-8-28 16:08 | 顯示全部樓層 |閱讀模式
#include<stc12.h>
#include<intrins.h>
#define LCD_data  P0
sbit LCD_RS=P1^0;        // 數據/命令選擇端
sbit LCD_RW=P1^1;        // 讀寫選擇端
sbit LCD_EN=P1^2;        // 使能信號
sbit LCD_PSB=P1^6;    // 并/串選擇
uchar code table[64][16]={
   0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFE,0xDF,0x00,0x1C,0x0E,0x1D,0xFE,0xAF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFE,0xBF,0xF5,0xFD,0xEF,0xD0,0x21,0xB7,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFD,0x81,0x80,0x3C,0x0E,0xD7,0xBD,0xBF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xF9,0x7D,0xB5,0xBD,0xEE,0xD0,0x20,0x03,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xF4,0xEF,0x80,0x3C,0x0E,0xD7,0xFD,0xBF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFD,0xAB,0xF7,0xFF,0xFE,0x10,0x3D,0x37,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFD,0xAB,0x00,0x00,0x03,0xD2,0xB8,0xAF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFD,0x6D,0xEE,0xFB,0x7F,0x90,0x25,0xDF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFC,0xED,0xC5,0xF9,0x06,0x4A,0xBD,0x9B,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFD,0xEF,0xF8,0xF6,0x7F,0xDA,0xBC,0x6B,0x7B,0xEF,0xBD,0xF8,0x00,0x00,0x00,
      0xFF,0xFD,0x8F,0x07,0x2F,0x03,0x1F,0x31,0xF3,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xEA,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE1,0xFF,0xFD,0xFF,0xF8,0x00,0x00,0x00,
      0xF1,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x3F,0xDC,0xFF,0xF8,0x00,0x00,0x00,
      0xC0,0x2F,0xFF,0xFF,0xF3,0xFF,0xFF,0xFF,0xFF,0xBD,0x8C,0xFF,0xF8,0x00,0x00,0x00,
      0xF1,0xFF,0xFF,0xFF,0xC7,0xEF,0xFF,0xFC,0xFF,0xB9,0x04,0xFF,0xF8,0x00,0x00,0x00,
      0xE8,0xFF,0xFF,0xFF,0x07,0x1F,0x7F,0xFF,0x3F,0xF0,0x20,0xFF,0xF8,0x00,0x00,0x00,
      0xDB,0x7F,0xFF,0xFC,0x0C,0x1C,0x7F,0x7F,0xCF,0xEE,0x71,0xFF,0xF8,0x00,0x00,0x00,
      0xFB,0xF7,0xE3,0xF8,0x00,0x10,0xDF,0x8F,0xF3,0xFE,0x7D,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFB,0xC1,0xF0,0x00,0x00,0x97,0xC1,0xF8,0xFE,0xFF,0xEF,0xF8,0x00,0x00,0x00,
      0xFB,0xEB,0x98,0xE0,0x00,0x39,0x10,0xF0,0x3C,0x3F,0xFF,0xBF,0xF8,0x00,0x00,0x00,
      0xFF,0xF1,0xA4,0xE0,0x00,0x04,0x10,0x1C,0x06,0x1F,0x8F,0x97,0xF8,0x00,0x00,0x00,
      0xFF,0xD1,0x8A,0xC0,0x00,0x00,0x30,0x00,0x01,0x0F,0x07,0x8F,0xF8,0x00,0x00,0x00,
      0xFF,0xE0,0x8A,0x00,0x00,0x00,0x30,0x38,0x00,0x06,0x33,0x1B,0xF8,0x00,0x00,0x00,
      0xFF,0xA0,0x44,0x00,0x00,0x00,0x50,0x40,0x00,0x06,0x4B,0x17,0xF8,0x00,0x00,0x00,
      0xFF,0xC0,0x60,0x00,0x0F,0xC0,0x48,0x00,0x00,0x02,0xA2,0x05,0xF8,0x00,0x00,0x00,
      0xFF,0x40,0x70,0x00,0x3F,0xE0,0x88,0x00,0x00,0x00,0xA2,0x03,0xF8,0x00,0x00,0x00,
      0xFF,0x80,0xF8,0x00,0x00,0xF1,0x04,0x07,0xE0,0x00,0x44,0x01,0xF8,0x00,0x00,0x00,
      0xFE,0x81,0xE8,0x00,0x01,0xC2,0x04,0x4F,0xF8,0x00,0x0F,0x03,0xF8,0x00,0x00,0x00,
      0xFF,0x00,0x08,0x00,0x01,0x84,0x02,0x3E,0x00,0x00,0x1F,0x82,0xF8,0x00,0x00,0x00,
      0xFD,0x00,0x10,0x00,0x00,0x88,0x01,0x06,0x00,0x00,0x10,0x41,0xF8,0x00,0x00,0x00,
      0xFE,0x01,0xE0,0x01,0x13,0x08,0x00,0x87,0x00,0x00,0x10,0x01,0xB8,0x00,0x00,0x00,
      0xFF,0x06,0x20,0x00,0x88,0x10,0x00,0x43,0x00,0x00,0x10,0x01,0x18,0x00,0x00,0x00,
      0xFD,0x0A,0x10,0x01,0x44,0x10,0x00,0x22,0x00,0x00,0x18,0x01,0xB8,0x00,0x00,0x00,
      0xF8,0x11,0x10,0x00,0x80,0x10,0x00,0x21,0x91,0x00,0x14,0x01,0xF8,0x00,0x00,0x00,
      0xFC,0x10,0x88,0x70,0x00,0x10,0x00,0x10,0x22,0x03,0xE0,0x00,0xB8,0x00,0x00,0x00,
      0xFE,0x20,0x84,0x4C,0x00,0x20,0x00,0x10,0x45,0x05,0x31,0x00,0xF8,0x00,0x00,0x00,
      0xF4,0x20,0x43,0x8B,0x80,0xC0,0x00,0x10,0x02,0x08,0x88,0x80,0xB8,0x00,0x00,0x00,
      0xFC,0x20,0x40,0x08,0xFF,0x00,0x00,0x10,0x00,0x18,0x40,0x40,0x78,0x00,0x00,0x00,
      0xF6,0x20,0x40,0x08,0x80,0x00,0x00,0x08,0x00,0x68,0x40,0x00,0xD8,0x00,0x00,0x00,
      0xFC,0x20,0x40,0x08,0x80,0x00,0x00,0x06,0x03,0x90,0x20,0x20,0x68,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
void delay(uint z)  // 延時函數
uint x,y;
for(x=0;x<z;x++)
  for(y=0;y<110;y++);
//寫指令數據到LCD
void write_cmd(uchar cmd)
LCD_RS=0;
LCD_RW=0;
LCD_EN=0;
P0=cmd;
delay(5);
LCD_EN=1;
delay(5);
LCD_EN=0;
//寫顯示數據到LCD
void write_dat(uchar dat)
LCD_RS=1;
LCD_RW=0;
LCD_EN=0;
P0=dat;
delay(5);
LCD_EN=1;
delay(5);
LCD_EN=0;
//12864初始化
void lcd_init()//12964初始化
LCD_PSB=1;    //并口模式
write_cmd(0x34);  //基本指令操作
delay(5);
write_cmd(0x0c);  //顯示開,光標關
delay(5);
write_cmd(0x01);  //消除所有顯示
delay(5);
//主函數
main()
uchar i,j;
delay(10);
lcd_init();    //初始化
for(i=0;i<32;i++)
  write_cmd(0x80+i);
  write_cmd(0x80);
  for(j=0;j<16;j++)
  write_dat(table[i][j]);
for(i=0;i<32;i++)
  write_cmd(0x80+i);
  write_cmd(0x88);
  for(j=0;j<16;j++)
   write_dat(table[i+32][j]);
write_cmd(0x36);    //打開繪圖模式
write_cmd(0x30);    //基本操作模式
while(1);     //沒有的話 會一直閃爍 甚至不顯示
參與人數 2威望 +10 黑幣 +10 收起 理由
xiaoou + 5 + 5 很給力!
hujia + 5 + 5 共享資料的積分獎勵,希望大家多多發(fā)布各種.
ID:26188 發(fā)表于 2014-8-28 16:49 | 顯示全部樓層
好東西  樓主能共享一下 電路圖嗎
ID:63839 發(fā)表于 2014-8-28 17:07 | 顯示全部樓層
hujia 發(fā)表于 2014-8-28 16:49
好東西  樓主能共享一下 電路圖嗎
12864的電路圖
ID:57234 發(fā)表于 2014-8-28 17:10 | 顯示全部樓層
贊一個啊,樓主的這屏  是帶字庫的 還是不帶字庫的呢?
ID:63839 發(fā)表于 2014-8-28 17:12 | 顯示全部樓層
xiaoou 發(fā)表于 2014-8-28 17:10
帶字庫 不過不能顯示漢字“三”和“庚”這是我用的keil4的bug
ID:65477 發(fā)表于 2014-8-29 09:53 | 顯示全部樓層
樓主,你用的是12864 那個型號的?
ID:63839 發(fā)表于 2014-8-29 13:51 | 顯示全部樓層
淺墨畫青梅 發(fā)表于 2014-8-29 09:53
樓主,你用的是12864 那個型號的?
QC1602A
ID:65477 發(fā)表于 2014-8-29 13:54 | 顯示全部樓層
我讀書少,表要騙我,12864和1602是同一碼事?!
ID:63839 發(fā)表于 2014-8-29 17:45 | 顯示全部樓層
淺墨畫青梅 發(fā)表于 2014-8-29 13:54
看錯了 我以為是我的另一個有關1602顯示時鐘的帖子呢  12864就是在網上買的普通的  后面只有QC PASS
ID:64246 發(fā)表于 2014-9-5 12:57 | 顯示全部樓層
去隔膜就好了唄!
ID:66181 發(fā)表于 2014-9-15 12:21 | 顯示全部樓層
謝謝分享
ID:66016 發(fā)表于 2014-9-15 21:49 | 顯示全部樓層
謝謝樓主分享。。
ID:60805 發(fā)表于 2014-9-28 21:51 | 顯示全部樓層
沒貼張圖嗎?
ID:66787 發(fā)表于 2014-9-30 15:58 | 顯示全部樓層
沒有圖呀
ID:69318 發(fā)表于 2014-11-24 14:19 | 顯示全部樓層
什么意思不懂那個是什么字模
ID:69215 發(fā)表于 2014-11-25 00:54 | 顯示全部樓層
感謝樓主了! 已下載,作個參考資料很不錯的.
ID:71359 發(fā)表于 2014-12-30 13:25 | 顯示全部樓層
謝謝樓主
ID:71795 發(fā)表于 2015-4-6 20:37 | 顯示全部樓層
這程序寫的不錯
ID:80273 發(fā)表于 2015-5-17 17:51 | 顯示全部樓層
感謝樓主的分享
ID:80272 發(fā)表于 2015-5-17 18:37 | 顯示全部樓層
額,主函數里初始化后面的幾個for循環(huán)放while(1)后面吧,你的程序執(zhí)行一次就死循環(huán)了
ID:84566 發(fā)表于 2015-7-3 17:18 | 顯示全部樓層
使用樓主的程序確實可以顯示圖片,但是有幾點建議
1、可以使用指針 ,不使用二維數組
2、將不必要的延時去掉,可以加快圖片刷新的速度
3、我經過修改后,圖形顯示的速度還是很快的,而樓主的程序要經過2--3秒的時間才可以顯示出來
ID:94867 發(fā)表于 2016-3-23 07:17 | 顯示全部樓層
最近正在弄12864顯示圖片
ID:153199 發(fā)表于 2017-1-1 12:31 | 顯示全部樓層
感謝分享
ID:184803 發(fā)表于 2017-7-21 22:53 | 顯示全部樓層
注釋寫錯了  write_com(0x34)是擴充指令
ID:222006 發(fā)表于 2018-5-22 15:22 | 顯示全部樓層
測試過沒毛病老鐵
Powered by 單片機教程網
