查看: 3905|回復(fù): 0
STM32學(xué)習(xí)之一 - 計頻器設(shè)計原理
ID:51025 發(fā)表于 2014-8-29 17:22 | 顯示全部樓層 |閱讀模式
檢測外部脈沖信號頻率方法有三種:
(1)  TIM3 is configured in Input Capture Mode: the external signal is connected to
TIM3 Channel2 used as input pin.
To measure the frequency we use the TIM3 CC2 interrupt request,
so In the TIM3_IRQHandler routine, the frequency of the external signal is computed.
The "TIM3Freq" variable contains the external signal frequency:
TIM3Freq = TIM3 counter clock / Capture in Hz,
where the Capture is the difference between two consecutive TIM3 captures.
For Low-density, Medium-density, High-density and Connectivity line devices,
the minimum frequency value to measure is 1100 Hz.
For Low-Density Value line, Medium-Density and High-Density Value line devices,
the minimum frequency value to measure is 366 Hz.
(2)  TIM3 is configured in PWM Input Mode: the external signal is connected to
To measure the frequency and the duty cycle we use the TIM3 CC2 interrupt request,
so In the TIM3_IRQHandler routine, the frequency and the duty cycle of the external
signal are computed.
The "Frequency" variable contains the external signal frequency:
Frequency = TIM3 counter clock / TIM3_CCR2 in Hz,
The "DutyCycle" variable contains the external signal duty cycle:
DutyCycle = (TIM3_CCR1*100)/(TIM3_CCR2) in %.
For Low-Density Value line and Medium-Density Value line devices, the minimum
3)對于High-density devices(大容量型)如果檢測脈沖的頻率小于1100Hz,我們可以采用外部中斷邊沿的觸發(fā)方式來計算脈沖的個數(shù),通過定時器準確定時1s所測得的脈沖個數(shù)即為脈沖信號周期。
